#26 |
Re: Good 70 SWB
Began assembly of the front suspension. Replace upper and lower ball joints, went with 2.5 drop spindles and 1" drop springs. Disc's are new but have some surface rust that should clean off when it hits the road.
#27 |
Re: Good 70 SWB
Well I am back on my 70 SWB project. I needed more room so built as shop that I could put it in to give it the attention is deserves.
I replaced all the break lines with new SS ones. I now have the frame inside the shop and have put the engine and transmission back in. Next for the chassis, I will be ordering fuel tank and installing SS fuel line. |
#28 |
Re: Good 70 SWB
I am new to welding so last night I decided I would work on the firewall. I can say I certainly learned a lot putting this patch in... but here are some before and after picts. I was concentrating so much on this I did not get any in progress picts...
#29 |
Project collector
Re: Good 70 SWB
That looks really good. Awesome job!
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
#30 |
Re: Good 70 SWB
Looks Good! I just got mine in the garage and am about to get started. I hope mine goes as good as yours.
#31 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Good 70 SWB
Nice truck, nice progress, and you are doing a great job! Are you installing a vintage air kit on it?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#32 |
Re: Good 70 SWB
I am looking at both Vintage Air and Old Air. I am leaning to the Old air with the electric controls.
#33 |
Project collector
Re: Good 70 SWB
Brad,
You may want to check on Old Air. I heard somewhere that they went out of business. Steve
#34 |
Re: Good 70 SWB
Ok did some more work on smoothing the firewall. Filled this one and it come out pretty good.
#35 |
Re: Good 70 SWB
Got the clutch and emergency brake holes filled.
#36 |
Re: Good 70 SWB
I like things symmetrical so filled this in also.
#37 |
Project collector
Re: Good 70 SWB
Good work. Looks like you will be ready for me to help with that gutter cap before long....
![]() Steve
#38 |
Local Redneck Authority
Re: Good 70 SWB
Very nice welding for not having experience! I don't have any body experience but will definately be learning soon. Much different than tool steels and heavy fab that I'm used to. Nice work so far
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#39 |
Still Learning
Re: Good 70 SWB
Very nice work on the chassis and the firewall! Awesome!
#40 |
Re: Good 70 SWB
Finished couple more things over the past couple days. I filled in the holes for the wiring harness connection and also speed odometer cable hole. Now I just need to figure out how I am going to run the wire harness. I am open to ideas!!
#41 |
Re: Good 70 SWB
Had a small hole under the drip edge. I got it cut out using a dremmel tool and was able to bend a piece to fit back.
Got a little more grinding to do but overall it should do the job. |
#42 |
Re: Good 70 SWB
Awesome work!
#43 |
Re: Good 70 SWB
Yea looking very good, What size tires wheels you got?
1980 1/2 ton shortbed project 1978 grand prix project Never stop trying... Last edited by Dusty4x4; 06-29-2010 at 01:42 PM. |
#44 |
Re: Good 70 SWB
I bought a cab with the firewall shaved, so I am also curious of how to run the wiring. Also what do you plan on doing for an E- Brake and Spedo cable?
#45 |
Re: Good 70 SWB
Appreciate the comments. These are 275/60 15 tires 5 bolt .
#46 |
Re: Good 70 SWB
Wiring is still in planning but looking at the option to run the wire harness through the open air vent the up under the drivers fender. Probably run the spedo cable through similar location. As for the E-brake since I will be just removing it.
#47 |
Re: Good 70 SWB
Be sure to take plenty of pics of how you run the wires. Don't you have to have an E-Brake to get an inspection sticker? Keep up the good work.
#48 |
VA72C10
![]() Join Date: Mar 2008
Re: Good 70 SWB
cool project and nice progress so far!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#49 | |
Re: Good 70 SWB
#50 |
Re: Good 70 SWB
Cut out the radio and ashtray from the dash and filled it in. I will be installing a 2 Din DVD,NAV,CD Audio system and also the After market AC vent in this area.
Cut out the entire section. Easier for me to fill this way. Got a nice fit and after grinding down the welds looks pretty good. Now just need measurements for the 2 Din Audio system and AC vent to cut them out. |
