12-15-2009, 06:27 AM | #1 |
Re: Disc Brake Upgrade Reference Thread
This is a great thread I am busy adding an updated cross member to my ToDo list.
66 GMC 1500 Series LWB |
12-15-2009, 09:03 AM | #2 |
The Beach Cruiser
Subscribed and filed. Thanks Guy's for all the write ups.
1999 Silverado DD 1966 Panel Truck 2003 Harley Road Glide 1967 Schwinn Tandem Single Speed |
12-15-2009, 12:57 PM | #3 |
here is some 60-60 disc info for keeping the torsion bar
torsion bars and disc brakes http://67-72chevytrucks.com/vboard/s...d.php?t=375432 On the c20 spindle swap I used c20 upper joints in 62 arms, and centerlink tierods etc from c20
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) Last edited by 62gmc910; 12-15-2009 at 01:02 PM. |
01-13-2010, 05:36 AM | #4 |
What are the advantages of swapping the crossmember to 73-87 unit (ground clearance, better geometry, ...)?
Is it in some way better then 63-66 crossmember? I have some options on some available parts. I already have upper and lower control arms, rotors and calipers in a box from the PO, though I don't know what year they are from yet. I might get some tubular upper control arms to correct some of the geometry and I'll be using dropped spindles and springs. So if the only advantage to the 73-87 crossmember is that it already has everything bolted to it and can be installed as a unit I'd probably be better off just switching out parts.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
01-14-2010, 12:48 AM | #5 |
60-66 Nut
To my knowledge the '73-'87 front suspension crossmember is basically the same as the '63-'72 crossmember. The only difference that I can think of is the '73-'87's use a larger diameter U-bolt to attach the LCA shafts. So consequently the holes in the crossmember are larger to accomodate. The older crossmembers can obviously be drilled out. I would recommend upgrading to the later model larger LCA shaft U-bolts.
12-28-2017, 04:12 PM | #6 |
So after I read almost the complete 17 pages , Is the six lug front conversion viable without a cross member swap?
I have a 1963 I would at least like to add power front disc brakes and more over 4 wheel power disc brakes, but the question remains is the aliment issue resolved and am I clear on what parts I need to hunt up Thanks Happy new year |
12-29-2017, 12:07 AM | #7 | ||
60-66 Nut
If you are wanting to keep your torsion bars, then yes you will have to purchase the aftermarket dropped spindles specifically for converting a '60-'62 to disc brakes
As for converting your rear to disc brakes, that is not easily done with a '63 12 bolt as the backing plates are pressed onto the axle tubes. That is why my rear disc brake brackets are designed to be used on the '64-'87 truck 10 and 12 bolt differentials. There is nothing on a '63 12 bolt to bolt the brackets to. If at some time during the past 55 years, the differential has been changed to a '64 and newer differential, you are in luck Quote:
01-02-2018, 12:21 PM | #8 |
Thanks Cap'n. I was also wondering why the oem 15" steelies wont fit if I swap to disc. Is the diameter not enough to clear the calipers or is there not enough backspacing? Would I have to go up to a 16" wheel or could I find a 15" aftermarket steely with enough backspacing?
12-25-2009, 03:23 PM | #9 |
Good info. thx
12-26-2009, 08:57 PM | #10 |
HOW long until spring??
subscribed!! Thanks for assembling all this info. Great stuff to know..
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
01-02-2010, 12:54 PM | #11 |
Thanks for the great info, looks like i'm going with new ball jointsfor 73-87 and junkyard donor steering components and spindles. Great job!
Slowly but surely getting it done. Last edited by onequickchevy; 01-02-2010 at 12:55 PM. |
01-02-2010, 01:30 PM | #12 |
more ideas than money
Thanks for the great collection of information. I am filling this one for referance for later.
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
01-02-2010, 06:41 PM | #13 |
THE DAMN YANKEE
Question for the disc brake conversion savvy. i have a 65 C10. i got 72 spindles & rotors,w/ new calipers,new balljoints & hoses. will they fit my 65 trucks A arms??? any help would be aprechiated.
02-22-2010, 04:46 PM | #14 |
nice info
1990 Chevy C2500 4x2 350TBI 1997 Chevy K1500 4x4 350Vortec |
02-27-2010, 03:31 PM | #15 |
Ive Got a 65 1/2 ton Chevy LWB and I have a 66 3/4 ton that I bought as a parts truck. I was planning on using the 3/4 ton frame and suspension to do a frame-up build then swithch the 65 body over to it.
My question is can I use the 3/4 upper and lower control arms interchangeably with the 1/2 ton control arms? or are they different. I was planning on just using a bolt on kit, but after going through this thread...WOW! I was avoiding doing late model parts swapping because I thought I would be in the dark on my own and end up f**ing it up. Thanks for organizing this! any help is greatly appreciated. also, how do i add this thread to favorites? Cheers! |
02-28-2010, 02:06 AM | #16 | |
60-66 Nut
If you are going to be building a frame from the ground up, I would suggest just swapping a complete '73-'87 C10 front suspension.....crossmember and all. Of course you can rebuild it all but that's what I would do. The only time you would want to use the C20 LCA's is when you use the '88-'98 spindles when going with 6 lug discs. The '66 C20 LCA's use a flat style shaft that bolts directly to the crossmember. So consequently there is no saddle to accept the C10 or later years C20's LCA's with round shafts.
To save this thread to your Favorites, just click on your 'Favorites' when viewing this thread, and when the drop down appears, click on 'Add to Favorites'. Then click on 'Add' in the next window that appears. Quote:
02-28-2010, 06:06 PM | #17 |
Awesome, Thanks for that response, It was totally what I was thinking by the time I got done reading the thread. I was able to pick up an 81 1/2 ton crossmember with disks and all steering linkage for $125 on my local craigslist.
Im so excited to upgrade the whole system at once and I will save a ton of cash using the oem late model suspension rather than bolt on CPP parts! I still might splurge on some aftermarket cross-drilled rotors though! Thanks again for a great Thread! |
02-28-2010, 06:44 PM | #18 |
Happy to be here
I would considering rebuilding it before you do the conversion. It may be in great shape, but the parts are reasonable and you know everything is fresh.
03-01-2010, 12:14 AM | #19 | |
60-66 Nut
Yep that will work good for you. I have to agree with N2TRUX that a rebuild of the front suspension and brakes would be a good idea. If the complete rebuild isn't in the budget, at least do the important and hard to do later parts. Keep me in mind for your steering box and brake booster mounting
03-02-2010, 09:51 PM | #20 |
here is a question I have not found answered yet. I have a 60 torsion bar truck. I want to convert to spring with discs. I read the write up on putting the late 70's early 80's subframe in but it requires some drilling and time. My question is will a 63 to 66 sub frame bolt right up to mine so then I can swap to the later disc conversion?
03-03-2010, 01:07 AM | #21 | |
60-66 Nut
A '63-'72 front crossmember isn't going to make any difference to speak of. There will still be a number of holes to drill. I would just go with a complete '73-'87 front suspension. I prefer those over the earlier years.
03-03-2010, 03:31 PM | #22 |
well I figured if I used a 63-67 front crossmember then it would bolt straight on my frame then I could upgrade to the newer a arms and brakes. just figured if it would work then It would be easier.
03-03-2010, 11:52 PM | #23 |
from what I have read the 73-87 crossmember requires drilling even on a 63-67 so this means it bolts up different on that frame also. seems to me that the frame on any 60-67 should be the same. so a 63-67 crossmember should bolt straight on??? can anyone confirm?
03-04-2010, 12:06 AM | #24 | |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-04-2010, 12:11 AM | #25 | |
