Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-18-2009, 05:18 PM   #26
dave brode
dave brode's Avatar
Re: Need some engine advice and suggestions...
Originally Posted by Hart_Rod View Post
Thanks again Dave. Since I already have an electric pump, I will probably stay with one.
[COLOR="blue"]Great Site! That's what I've been looking for, . I'm going to have a long night tonight......
glad to. There are site sponsers there that probably offer pumps. Mallory has two bypass regs that are popular. If the pump isn't too far an overkill, the smaller one works. By-pass side of system must flow enough to cover the pump's output at low fuel need times [idle, cruise etc]
Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108.
dave brode is offline   Reply With Quote
Old 11-18-2009, 05:35 PM   #27
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Wild83C10 View Post
Aeromotive makes some good stuff.
The x02 BOV can be purchased from VSracing.net
AFR: look at the Innovate LC1 w/digital gauge or the AEM model
If you want to learn more theturboforums is a good rescource also checkout yellowbullet.com/forum
http://www.vsracing.net/catalog/prod...43aaf05a7d8c53
This BOV installed where I have the arrow in the below picture? Do you know how much boost it can handle? I didn't see it listed. What are your thoughts on the location of the air filter?
Originally Posted by ProStreet71 View Post
Sorry for the bad info.
No worries. We're all here to learn, .
Originally Posted by dave brode View Post
glad to. There are site sponserd there that probably offer pumps. Mallory has two bypass regs that are popular. If the pump isn't too far an overkill, the smaller one works. By-pass side of system must flow enough to cover the pump's output at low fuel need times [idle, cruise etc]
Dave
Thanks again for the info. I think I'm going to go with the Aero stuff. I've heard nothing but good about them.
Hart_Rod is offline   Reply With Quote
Old 11-18-2009, 08:00 PM   #28
Alex1
Alex1's Avatar
You won't be able to hook up the blow off valve on the set up you have now. Normaly they're located on the pipe towards the carb. You would have to change the rubber elbow for a steel or aluminum one.
I don't think you want to cut a hole in the box!
Did you get a wideband 02 yet?
Alex1 is offline   Reply With Quote
Old 11-18-2009, 08:12 PM   #29
Alex1
Alex1's Avatar
Sorry I forgot to mention.
Get a good fuel pump like an Aeromotive a1000 I think it is - Its good quality and will give you all the fuel this combo needs - you will need an adustible fuel pressure regulator and a return to the tank.
Also a like others have mentioned, a cold air set up would help too.
Also you need colder plugs with a blower - I'm not sure if thats what you're using or not
Is that flywheel HP or RWHP your making? I wasn't sure.
Old 11-18-2009, 10:54 PM   #30
Wild83C10
Wild83C10's Avatar
Yes the BOV would be located in that section of the pipe, but you need the aluminum pipe, not the rubber.
The BOVs aren't rated for certain boost levels it all depends on how much air you are pushing. A 50 mm BOV should be sufficient. I'm not exactly sure how to calculate the size.
Like Alex1 suggested the A1000 is a good pump and will work well with your combo.
It's so easy spending someone else money. Although I just bought a few of these same items.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 11-18-2009, 11:20 PM   #31
Hart_Rod
Hart_Rod's Avatar
I'm using AR3933 plugs. Flywheel HP.
Looks like I'll do the BOV first and then the regulator and pump. Can I cut out a section of the rubber and then add a piece of pipe in between with the BOV?
Old 11-19-2009, 05:54 PM   #32
Hart_Rod
Hart_Rod's Avatar
Here's the pump and fuel regulator I think I'm going to buy:
Aero 1000 Fuel Pump Part Number # 027-11101
Areo FPR Part Number # 027-13204
http://www.jegs.com/webapp/wcs/store...rderItemDelete
Thoughts?
r/
Old 11-20-2009, 07:59 AM   #33
Wild83C10
Wild83C10's Avatar
Thoughts?
r/
Those two items will work great, but lets take a step back. You say you have a 10AN line from the tank. What type of line is it? Is your fuel tank setup for a return and a pusher fuel pump? Does it have a sump? I know everyone doesn't run a sump and gravity feed their electric pumps, but it's ecommended and the pump will like it. Also keep in mind that you need a pre filter (100 micron) and a post filter (10 micron). Aeromotive sells a sump kit with built in filter and a1000 pump.
turbo=
Old 11-20-2009, 10:07 AM   #34
Alex1
Alex1's Avatar
Square advice.
Did you get a wideband yet?
Old 12-01-2009, 11:05 PM   #35
Hart_Rod
Hart_Rod's Avatar
Square advice.
Thanks for the advice guys. I got the BOV today. It looks like a quality part. Hopefully I can get it installed by tomorrow. I'll get the wideband after I get the BOV, FPR and fuel pump installed. I'll post updates soon...
Old 01-17-2010, 11:38 PM   #36
Hart_Rod
Hart_Rod's Avatar
I'll have an update on the blow-off valve by the end of the week. In the mean time, here's a video of some burn-outs,
http://www.youtube.com/watch?v=DIkAs...ayer_embedded#
Old 01-18-2010, 09:59 AM   #37
bigsnookmaster
bigsnookmaster's Avatar
Real sweet ride. I would keep the 3:73 gear if your going to street drive it. I've always ran the same and it gives the best of both worlds, And with that much power, I don't think you need any more. My .02 Where is Pace, Fl?
bigsnookmaster is offline   Reply With Quote
Old 01-18-2010, 12:38 PM   #38
djracer
djracer's Avatar
Just outside of pensacola.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-29-2010, 12:26 AM   #39
Hart_Rod
Hart_Rod's Avatar
I finally got my BOV installed. I still have to route a good vaccuum source to it and then I can go try it out. Is there anything I should double check before putting it to the test?
Old 01-30-2010, 11:27 AM   #40
Wild83C10
Wild83C10's Avatar
Looking good. How you doing with the other upgrades?
turbo=
Old 01-30-2010, 01:54 PM   #41
Hart_Rod
Hart_Rod's Avatar
I still need to finish the fuel system, but the Suburban has been occupying most of my time. Can you describe the normal operation of the blow off valve. As it stands, as soon as I manually move the throttle it starts opening up and releasing air from the supercharger. When does this stop?
Old 01-30-2010, 01:57 PM   #42
ripdog28
ripdog28's Avatar
Cant you adjust the valve? Set it for the PSI you want?
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-30-2010, 03:13 PM   #43
Hart_Rod
Hart_Rod's Avatar
Good question. The instructions said it was preset at the factory and not to adjust it. Makes you wonder why they put an adjustment screw on it....
Old 01-31-2010, 05:48 PM   #44
drag_72
Ready to go fast!!
drag_72's Avatar
i watched the video.... man lay in to the throttle!!! you aint gonna hurt that thing! blow them tires off man!
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 01-31-2010, 08:53 PM   #45
Wild83C10
Wild83C10's Avatar
Suburban looks nice. I will have to check out the build thread.
You need to build boost or pressure in the intake in order for the valve to stay closed. The hose that comes from the intake to the BOV senses pressure or vacuum. Under boost it will close the valve and keep it closed. If there is vacuum in the intake it will open the valve. It appears that the BOV is doing what it is supposed to do. You don't want pressure when you are manually blipping the throttle.
Before you make any adjustments drive the truck and see if how it acts.
turbo=
Old 01-31-2010, 09:18 PM   #46
Hart_Rod
Hart_Rod's Avatar
I know, I know....I'm still babying it. I still need to update the fuel pump and pressure regulator before I get to crazy with it.....
Roger that. It's been nasty weather her for the last couple of weeks so I really haven't gotten to drive it. Tomorrow is supposed to be nice, I'll try to take it out then. Also, what are your thoughts on a PCV setup?
Old 01-31-2010, 09:19 PM   #47
Jim_PA
X2 - and you were using brakes? WTH? ? ? ?
Jim_PA is offline   Reply With Quote
Old 01-31-2010, 10:17 PM   #48
Hart_Rod
Hart_Rod's Avatar
I'm scared.........
Old 02-01-2010, 12:52 AM   #49
drag_72
Ready to go fast!!
drag_72's Avatar
Cool Re: Need some engine advice and suggestions...
I'm scared.........
SCARED!!!??? nooooo you do not use those words in this thread lol you gotta be balls out man! lol
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-14-2010, 09:25 PM   #50
Hart_Rod
Hart_Rod's Avatar
Before I purchase a wideband setup, I need to upgrade the fuel system from the Holley black pump/Holley non bypass, non boost referenced FPR (anyone need to buy a pump and FPR, ) to some Aeromotive stuff. Here's what I'm planning for the fuel system:
A11101 - Fuel pump
A13301 - Boost reference fuel pressure regulator with return
A12301 - 10 micron fuel filter
A12304 - 100 micron fuel filter
The only thing I'm not sure of is the fuel pressure regulator. There seems to be a lot of choices. The 13301 is adjustable from 3-20psi and has a spring that can be changed to make it adjustable from 20 to 65psi if I ever switch to fuel injection. Thoughts?
R/
