Old 05-31-2010, 03:56 PM   #26
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: '68 C-10 LQ4 - 4L60e Budget Swap
Why cant you use the original steering column and and shaft and steering box, and just hook up the p/s lines to steering box? Will the stock exhaust manifolds clear steering shaft? I am using ECE motor mounts.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 05-31-2010, 03:59 PM   #27
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Why doesnt' the stock crossmember work with a 4L60? I have the 2004r in it now, but will be removing and selling, I guess.
Old 05-31-2010, 06:25 PM   #28
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
thats what I'll be using...a 200-4r
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-31-2010, 06:46 PM   #29
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Is there a special bracket for the TV cable?
Old 05-31-2010, 07:20 PM   #30
68GMCCustom
there are special TV cables, then I have also seen special arms/brackets that you mount to the carb (2 different styles) to correct the arm geometry.
200-4r bracket
Kurt -
Old 05-31-2010, 07:26 PM   #31
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Those are for carb'd motors though, right? Are you going to use the computer/EFI on your 6.0? I plan on using the whole engine management system. I have the TV cable adapter from www.bowtieoverdrives.com to hook up to my Holley in the truck now, but need to figure out if I can adapt the 200 4r to the 6.0 or just get a 4L60 to run with the computer on the 6.0.
Old 05-31-2010, 07:59 PM   #32
68GMCCustom
I have a brand new LY6 6.0L VVT motor. I am not going EFI for now, and will remove the VVT, EFI intake and use a carb and a 4bbl intake, and the MSD-6LS to fire the coil packs. I'll also swap the cam and springs for a hotter setup, but I am waiting for GM to finally release the LSX dual plane intake for standard decks. Its been in the GMPP catalog since '09. If they don't release the dual plane... I'll get the GM L92/LS3 single plane carb intake and the appropriate cam.
You should be able to tune out the tranny...as if it had a 5 speed stick or something. You may just have to get a ecm/pcm from a truck with a manual trans.
Kurt -
Old 05-31-2010, 08:18 PM   #33
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ahhh, ok thanks for the info. I just found this link which answers a lot of my questions. http://67-72chevytrucks.com/vboard/s...&highlight=lq4 Good luck with your build.
Old 05-31-2010, 08:58 PM   #34
eagleuh1
eagleuh1's Avatar
Good luck with the build. I'm in the middle of mine as well. What year is the gas tank for and how many gallons. Looks like a fairly nice fit. Nice truck to work on as well.
eagleuh1 is offline   Reply With Quote
Old 05-31-2010, 09:08 PM   #35
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
It's a powdercoated 20 gal. Summit tank with GM sender.
Old 05-31-2010, 09:25 PM   #36
joejbal
joejbal's Avatar
My truck was originally a 3 spd with manual steering.
I had to find an auto column, I want to be able to sit three across (two kids).
Joe
joejbal is offline   Reply With Quote
Old 06-01-2010, 07:11 PM   #37
lnwlfbsktbll
lnwlfbsktbll's Avatar
I've got that same, albeit used, LY6 from an '07 2500 HD and was pretty sure you couldn't convert it to a manual tune because GM didnt offer a manual behind the LY6. Removing the efi and VVT would change that though, or so I would think
'87 SWB GMC LY6/6L90E
'70 JEEP CJ5... My new toy
'06 Hyundai Accent... DD
Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1#
lnwlfbsktbll is offline   Reply With Quote
Old 06-01-2010, 07:51 PM   #38
68GMCCustom
I think VVT "for hot rodding" is still a little ahead of its time. I'm not comfortable with the current engineering designs and fear major breakage in a high performance scenario. I am keeing all my EFI and VVT stuff though...incase one day I decide I would like to have the EFI/VVT and want to swap it back.
Kurt -
Old 06-01-2010, 09:33 PM   #39
lnwlfbsktbll
You are probably right about it being ahead of its time. I plan to keep mine at near stock power levels for now and keep an eye on what comes up in the world of VVT. I really like what I've seen from Mast Motorsports though, and VVT seems to be a promising direction to go considering the increase in production engine using the technology.
Old 06-02-2010, 03:23 PM   #40
joejbal
joejbal's Avatar
Why not keep the EFI but can the vvt for now?
Joe
Old 06-02-2010, 03:25 PM   #41
joejbal
joejbal's Avatar
Here are a few pics.
Everything has the original dirt and grime.
Joe
Old 06-02-2010, 03:36 PM   #42
68GMCCustom
I have EFI in our TBSS...I prefer this setup for my '68 truck:
Kurt -
Old 06-07-2010, 10:34 AM   #43
joejbal
joejbal's Avatar
Here is a pic of the engine, everything installed and running except the air box, and exhaust.
Used the stock rad and a pair of dual fans from a k-car.
The thing sounds and runs great. I got too excited to remember to take a video.
Joe
Old 06-07-2010, 11:22 AM   #44
djmachinist
djmachinist's Avatar
Subscribing, Nice truck, interesting conversion. Looks like the thing is relatively rust free.
Dale
1969 GMC SWB FLEETSIDE
ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR
DALE JONES
MY BUILD THREAD: "69 GMC SHORT FLEET"
http://67-72chevytrucks.com/vboard/s...d.php?t=388447
djmachinist is offline   Reply With Quote
Old 07-30-2010, 11:24 PM   #45
smokinstang70
smokinstang70's Avatar
Doing the same swap on my 71.. can you give me more details on the fuel tank... It looks like a great fit!!! you said it came out of a Camaro SS... what year?
Thanks for the info... truck looks great.
smokinstang70 is offline   Reply With Quote
Old 07-30-2010, 11:29 PM   #46
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the install! who did your harness and pcm reprogram?
mcbassin is offline   Reply With Quote
Old 07-31-2010, 12:13 AM   #47
corvetteman10
subscribed! please keep the info flowing. the more i know the easier mine will be. thanks!
'72 cheyenne10 tilt, tach, a/c, posi
'70 custom10- daily grind
corvetteman10 is offline   Reply With Quote
Old 07-31-2010, 07:21 AM   #48
eagleuh1
eagleuh1's Avatar
Is it road worthy yet? Real interested in that gas tank. How many gallons? Has it worked out for you? Where did you buy it? Enquiring minds want to know! Mine was on the road, until I decided to do one of those so called complete truck makeovers. Gutted out the cancer yesterday on passenger side. Hope you like the new powerplant. I do.
Old 08-02-2010, 12:40 PM   #49
smokinstang70
Any updates? Really interested in the tank info.
Old 08-02-2010, 11:13 PM   #50
mcbassin
Still Learning
mcbassin's Avatar
I'm interested in the tank details too?
