01-09-2010, 07:10 PM | #26 |
Re: how much horsepower does your truck have
here is another 553hp
http://www.chevyhiperformance.com/te...ild/index.html |
01-09-2010, 08:06 PM | #27 |
hey, boost is addicting. no doubt about that!
i would love to do a twin 62-1 setup, but given all the extra weight that would be on the front of the already heavy 2150 lbs of my pickup, i wouldnt hook up period.. im going to be doing a midmount turbo setup with as much stuff moved behind the rear axle that i can get back there. should be fun!
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
01-09-2010, 11:27 PM | #28 |
Horse power, I don't think you can count the engine in either of my trucks as having any horsepower. But enough to cruise at serious highway speeds for hours on end without issues is plenty. |
01-10-2010, 12:04 AM | #29 |
neb, your going to run a system like STS turbosystems? Very cool. Always interested on how those work. What are you doing for cooling? FMIC? Air to Water?
01-10-2010, 12:17 AM | #30 |
well, the same basic principal as an sts.. try and hide as much as i can...
im going to TRY and mount the turbo where the battery box is now. *original location* and have full exhaust.. as far as intercooler goes, i dont need one unless im really pushing it. carborated systems play their own "cooling" role in the atomization of the fuel. so from what ive seen, i should be good without a cooler for up to 12-14 lbs. if i want to go higher, then ill just install a meth setup to help out there. but i shouldnt have to. 500 wheel should definetally be doable with 93 pump and that snail. ignition, im going with a plane jane HEI with the simple upgrades and curve ket and MSD's new 6AL2. pretty cool, and very simple!
01-10-2010, 02:48 AM | #31 |
Your going to have a hard time spinng those tires on a boat Bernie
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
01-10-2010, 04:05 AM | #32 |
Registered Chevy Owner
I have a '68 307 that's rated at 200 hp and with a couple of bolt ons I'm hoping to get 300 hp; naturally aspirated of course.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
01-11-2010, 02:23 PM | #33 |
Will be running a 383 with 420 HP/450 TQ.
01-11-2010, 05:02 PM | #34 |
c10slim. What truck are you putting in into? Suspension. Frame? Wheels?
01-11-2010, 05:38 PM | #35 |
Sorry mine is going in a 66. I forgot I was browsing the 47-59 thread.
01-11-2010, 06:42 PM | #36 |
no worries, should have figured that based on your screenname (c10), anyway... what is your setup going to be?
01-11-2010, 07:52 PM | #37 |
290hp Goodwrench motor, runs 70 on freeway all day long. On good old regular pump gas, daily driver type rig. 68 Camaro 10 bolt, 273 gears, 70 A body subframe, turbo 350, it just doesn't get any more dependable.
Truck's just for the fun of it. Last edited by pro1955; 01-12-2010 at 09:10 PM. |
01-12-2010, 02:43 PM | #38 |
Should have added this question too.
What suspension? What rear end? What chassis? How does it hold up? |
01-12-2010, 02:44 PM | #39 |
I am running a s10 chassis, leaf in rear, 2" drop spindles in front, 4x4 blazer rear end.
01-12-2010, 02:59 PM | #40 | |
We'll see how well it holds up. |
01-12-2010, 08:32 PM | #41 |
Our 1957 has the original 235 and has probably never even been rebuilt. Runs OK still.... I would guess it 100HP on a good day.
1982 K10 SWB 1987 V20 - Sold - Doh! |
01-14-2010, 10:15 AM | #42 |
I was planning on buying a GM crate motor but I got a really good deal on a freshly rebuilt 350. It was dyno'd at 400 HP and 450 FP tourque at the flywheel with a standard 4 barrel and edlebrock carb, I've probably reduced that with my 3x2 high rise but it should still get out of it's own way
01-14-2010, 01:38 PM | #43 |
Sam, how does it ride?
01-15-2010, 09:26 AM | #44 |
01-15-2010, 10:50 AM | #45 |
with my stock ls1, 4.10's, posi, and 6 speed I can break it loose it 1-3 and chirp hard going into 4 and 5.
I pleed the 5th for the speeds at which I shift haha |
01-15-2010, 03:27 PM | #46 |
Cajun, I was battling with the idea of going LS1 and putting a couple bolt ons, but got too good of a deal on a fully built 327. Was that with your 20x8s? How do you suppose it would grab with a 15 or 16x10 with street slick?
04-07-2013, 04:57 AM | #47 | |
Will a 275 drag radial fit without cutting anything up? I have a little small block in myne and am getting ready to order wheels/tires. I was planning on a 15x10 with 4.5in backspacing and a M/T 275/60/15 drag radial. It looks like I might have to cut some of the bed out to make it fit, but it destroys the stock 225/60's on it now... BTW 500+hp (est) 388 stroker here... |
04-07-2013, 05:02 AM | #48 |
04-07-2013, 09:31 AM | #49 |
It's installed in the wrong end!! I put mine in the correct end and figure a minumum of 100 HP......that's to the rear wheels!
04-07-2013, 10:18 AM | #50 |
56 - autocross
