Old 02-25-2010, 12:29 AM   #26
low86c10
Re: door hard to close
Originally Posted by 78-5.3 View Post
To replace the pins does the door need to come off ????
yes
low86c10 is offline   Reply With Quote
Old 02-25-2010, 07:38 AM   #27
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Anybody have a web link to the striker and plastic bushing?
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 02-25-2010, 09:14 AM   #28
nlped
nlped's Avatar
^^^The striker and plastic bushing come as one piece, but it can be had at any local parts store that has a HELP section. I paid $6.99 each for mine.
Yes, the doors need to come off to replace the bushings. It isn't really very tough at all though. 6 or 7 bolts per door ( don't remember exactly) and if it has power windows &/or locks you need to fish the wiring out of the door before removing said bolts. Once the door is off, just cut the pin in half with a cut off tool, saw zall, air saw (you get the picture) and pop the upper piece out of the hinge...the lower piece will just fall out. This is MUCH easier than trying to beat them out with a hammer, and plays less havoc on the hinge assembly. Next, knock out the the existing little bushing and just replace in the opposite order...minus cutting anything
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-25-2010, 11:23 AM   #29
bumslie75
bumslie75's Avatar
I changed the door pin on mine yesterday works like a champ now
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
bumslie75 is offline   Reply With Quote
Old 02-25-2010, 02:04 PM   #30
78-5.3
78-5.3's Avatar
Originally Posted by low86c10 View Post
yes
so i remove the door but leave the hinge on the piller
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 02-25-2010, 05:34 PM   #31
nlped
nlped's Avatar
^^^yepper
Carter
Old 02-28-2010, 11:38 PM   #32
C10Silverado79
I love the info that comes across this board. Thanks to the responses from this thread my doors close great now. I picked up some new strikers with the plasticbushing at Pep Boys an put them on this morning. What is difference. I would not have thought the fix would be so simple.
Thanks Guys.
1979 C10 Silverado
1998 Camry 5spd
2005 Harley ElectraGlide
C10Silverado79 is offline   Reply With Quote
Old 03-01-2010, 11:15 AM   #33
78-5.3
78-5.3's Avatar
i have to remove the door the hinge is alittle sloppy moves up and down!!
Old 03-03-2010, 12:30 PM   #34
nlped
nlped's Avatar
Fear not, it's pretty straight forward. Just be sure and have some help to take the door off and especially to put it back on.
Carter
Old 03-04-2010, 10:20 PM   #35
Oldschool82
Balls to the wall!
Oldschool82's Avatar
I got mine at Advanced Auto Parts. They had the striker bushing combo which was about 7-8 bucks each ( they only had one on the shelf) or just the bushings for like 3-4 bucks for a 4 pack, which I bought and put on my old strikers.Worked like a charm, however I had to grind down the diameter of the striker for the bushings to slide on...good thing I have a bench grinder...lol. Can't believe the change that ,that little plastic piece made. Thanks for the info guys!
1982 swb 1/2 ton
Also have a 2001, 400+ Hp T-top Camaro SS
Loving my old Chevy truck and my new square body family on here!Thanks for all the help,tips and ideas I have gotten already guys.
http://67-72chevytrucks.com/vboard/s...d.php?t=388836
............_________{\___
............l_(0),,,______(0)l
Oldschool82 is offline   Reply With Quote
Old 03-04-2010, 10:51 PM   #36
C10Silverado79
The only bushings I could find were for FORDs so I ended up buying the new striker/bushing. I wonder if the bushings you got were the Ford ones?
1979 C10 Silverado
1998 Camry 5spd
Old 03-05-2010, 02:34 AM   #37
Oldschool82
Balls to the wall!
Nah , they were for chevy... I think they are just a generic one size fits most type thing...not very model specific , but thats ok...they worked out.
1982 swb 1/2 ton
Old 03-05-2010, 02:06 PM   #38
nlped
nlped's Avatar
^^^You are correct sir
Carter
Old 03-05-2010, 08:01 PM   #39
86 Rado
86 Rado's Avatar
Big ThANK YOU to all involved. I purchased bot sides at Autozone today $8.99 each. Doors shut great. Man, I thought it was more than that. KUDOS. They only had one set for GM vehicles and it worked perfect. They did not sell the sleeves by themselves like they did for the Fords, but mine strikers were wore anyways. Can't beat it for that price.
09 Black Challenger R/T
90 Scottsdale shortbed 4x4
71 Impala Custom
86 Rado is offline   Reply With Quote
Old 09-16-2013, 01:45 PM   #40
swissarmychainsaw
It's not a plastic washer, he means a plastic "sleeve" on the striker itself.
Oh, and I can vouche for the "butta tool" It works great!
Is this the "butta tool"?
http://www.eastwood.com/e-z-store-do...parent_id=2343
The also have one that is about $20 more, but seems fairly similar:
http://www.eastwood.com/door-alignme...and-truck.html
Which one did you like?
thanks!
--Nick
swissarmychainsaw is offline   Reply With Quote
Old 10-20-2013, 12:11 PM   #41
rudey737
I love those little gray bushings. I just replaced both door strikers on my 84 - they looked to be the original 30 year old strikers by the way - and now both doors are easier to close. The best thing is no passenger door rattle when I go over bumps. Now I just need to grease the hinges.
Azulita - 84 Chevy Scottsdale Longbed 305/350
rudey737 is offline   Reply With Quote
Old 10-20-2013, 12:24 PM   #42
Desert1957
Desert1957's Avatar
I replaced all 4 striker insulator sleeves on both my trucks, the doors now shut with one finger.
Desert
Desert1957 is offline   Reply With Quote
Old 10-20-2013, 05:32 PM   #43
Dinos63
chevy only
Dinos63's Avatar
not the best pic. but I went to home depot $3.05 in plastic tube not pvc. and it works like a champ
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 10-20-2013, 05:33 PM   #44
Dinos63
chevy only
Dinos63's Avatar
slip the pipe and install
Old 10-20-2013, 06:59 PM   #45
CoggedBelt75
CoggedBelt75's Avatar
x2 on the pex tubing....works like a charm.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 10-21-2013, 06:56 PM   #46
riz
Dino,
Did you use glue or adhesive of any kind or does the plastic tubing just spin free? Also, the pic is a bit blurry... is the tube 1/2" x 5" and does it come in black too?
RIZ
riz is offline   Reply With Quote
Old 10-21-2013, 07:36 PM   #47
kalbert
Originally Posted by GMC Guy View Post
i'm going to be buying one of the "Butta Tools" pretty soon. but i'm curious on how they work? does it just line up the latch and striker so you can tighten the hinge bolts?
No. Well... Kind of... You stick one end on the striker and the other end in the latch and then whoof on it with a breaker bar and bend the door, hinges, and striker until it closes good. Usually it takes a lot of up, some down, and a tad up again. Feels wrong when you're doing it but it works like magic. Keep an eye on the fender/door gap while you're whoofing on it, things that are way out of whack will let the door move so much that it contacts the fender and chips the paint off.
Using the plastic pipe for a replacement bushing is a neat idea, I'm going to give that a try! I assume it must push the latch just a bit further naturally so it clicks over to full latch and holds? I suppose it also keeps it from rattling on rough roads too.
kalbert is offline   Reply With Quote
Old 10-21-2013, 08:10 PM   #48
CoggedBelt75
The tubing is 1/2". Go to a plumbing supply store and tell them you only need a tiny piece and they might let you cut it and take it for nothing, which is what the guy at Ace Hardware did for me. You'll need a piece 3/4" long per striker. Slit it down the middle, gently spread it open, and push it onto the striker. No glue...just arrange the slit so it is facing away from the door. I have read about this a while back and decided to try it. No more slamming the doors now. Only color around here is white, red, blue, and yellow. Sure bets replacing the striker. If this doesn't do you any good, then there is other problems, like the pins or hinges.
Joe
1975 C10
Old 10-21-2013, 08:41 PM   #49
riz
I have been working on my K5 Blazer for a couple years now and hope to finish it next year if all goes well. I have replaced both door hinge pins and installed brand new door weather strip so everything is pretty tight. I just got back from Home Depot and bought 1/2" x 5' PEX plastic tubing, I cut two 3/4" lengths and put them on the strikers and the doors seem to shut much better now even with the weather strip I just installed over the weekend so I'm pretty happy how this simple $1.77 tip has improved my doors shutting better. These are the types of tips I just love. Thanks.
RIZ
Old 03-30-2014, 10:39 AM   #50
solidaxel
solidaxel's Avatar
I am looking for a used "Butta" tool if you have one laying around let me know.
How many times have you used one after you align everybody's doors?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
