Old 11-30-2010, 04:19 PM   #26
MrDude_1
Re: Need more leg room . please help
Originally Posted by Big Irish View Post
looks like you can push that seat right back against the floor suport . Should help considerably . I think I am going to go with the 88-98 Bench . Dont have the toolds or skils to cut the Astro seats .Thanks
if you really want the astro seats, dont let one little cut stop you.
Click Here and you'll find a cheap right angle grinder.. that plus $5 in cutoff wheels and you can cut just about anything.
MrDude_1 is offline   Reply With Quote
Old 11-30-2010, 05:07 PM   #27
Big Irish
Big Irish's Avatar
you make a good point , we will see what i can find . thanks for the help .How much legroom do you think u gained ? Was it a susbstantial difference ?
1955 Chevy 2 door Wagon
1967 Short Wide BAGGED Gone to someone else
1953 Shop truck Clipped and Snipped sold
1951 GMC Bagged and patina
Big Irish is offline   Reply With Quote
Old 11-30-2010, 05:42 PM   #28
duwem
duwem's Avatar
Dont know, never had the stock seat in the truck. Just some cheezy VW bench seats that came with it.
The bottom is bumped up agains the back skirt around the gas tank.
Keep in mind its not just cutting the bottoms off, you still need to bolt or weld something on the legs to attach them to the floor....
duwem is offline   Reply With Quote
Old 11-30-2010, 05:53 PM   #29
Wvgearhead
Does anybody have a pic of a full size bench in an AD. Seems like it would be too wide, I can get one out of a 97 for free. I just didn't think it would fit. This may work out good.
Wvgearhead is offline   Reply With Quote
Old 11-30-2010, 07:55 PM   #30
BlueJeep
BlueJeep's Avatar
Here you go, 1988 Chevy fullsize bench in my 1949 Chevy truck. To get it in there I cut out the factory seat riser but NOT the brace that was in front of the original gas tank. That brace is important and should not be cut, besides it isn't necessary for the 1988 bench. I used the original 1988 seat risers, with no modifications. They sit on the flat parts of the floor, and I drilled 4 holes and bolted it down. Reinforcement is a good idea on the bottom to spread the load should you get in an accident. This is one of the easiest mod's I've done.
I love this seat, I put many, many hours in the one in my 90 Chevy and it was always comfortable.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 11-30-2010, 08:05 PM   #31
Wvgearhead
Thanks, looks like a good fit
Old 11-30-2010, 08:38 PM   #32
BlueJeep
BlueJeep's Avatar
It's a real good fit, close to the doors but never touches.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 11-30-2010, 09:42 PM   #33
Todd68Chevy
Todd68Chevy's Avatar
Originally Posted by Todd68Chevy View Post
I have a buddy that has a 49 with the gas tank behind the seat. He is taller than 6.2 and I know he tried the stock seat and after one trip about 3 hours he bought an aftermarket seat and has since drove the truck 13 hours on one trip. I will check with him and try to get the seat companies name for you.
My buddy is out of town for work and I can not get pictures. He has a Rod Doors seat in a 49 Chevy and says it makes a huge difference. Good luck with your project and I hope you get a lot of enjoyment from it.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 12-01-2010, 12:00 AM   #34
Big Irish
Big Irish's Avatar
You guys have all been an amazing help . I realy appreciate it . bluejeep . how much room do you believe you gained ? Is it much more comfortable for your legroom ? Did you need to remove the tank / thanks again .
Old 12-01-2010, 01:57 AM   #35
Thinkblue4 Evr
Thinkblue4 Evr's Avatar
We used a set out of a 98 Honda and made a Base for it to sit on. Also I am 6 foot 6 almost 300lbs. and almost sit in it comfortably. Also put a center seat in from a 2002 cadi that flips up to make room for 3 or me and two really small people. Although its not a bench seat from a truck or van we made it work.
1952 Chevy 3100
1986 Corvette Suspension
350 motor Tune Port Injected
Thinkblue4 Evr is offline   Reply With Quote
Old 12-01-2010, 10:58 AM   #36
Big Irish
Big Irish's Avatar
Guys ,how did you get the seat skirt out ? I dont have a compressor . Thanks
Old 12-01-2010, 01:20 PM   #37
Houston54
You do not need a compressor. Locate the spot welds and drill them out or use a cut-off wheel on a grinder and trim it out. Wear safety equipment.
Houston54 is offline   Reply With Quote
Old 12-01-2010, 04:13 PM   #38
Big Irish
Big Irish's Avatar
thanks for the input
Old 12-01-2010, 07:00 PM   #39
BlueJeep
BlueJeep's Avatar
Look back at my first post, enough room gained to comfortably seat my 6'9" buddy.
I removed my seat riser by cutting the hulk of it out with the plasma cutter, then drilling out the spot welds.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-01-2010, 09:16 PM   #40
duwem
duwem's Avatar
Those bolts seats directly to the sheet metal floor, are you just using fender washers on the underside?
My pieces I'm welding to the bottom of the seat supports are 1/4" thick x 1.5 They will run the full length of the seat supports. Probably use 3 3/8" bolts per side.
Still may run full straps under the cab as well, instead of just fender washers.
Old 12-01-2010, 10:22 PM   #41
Big Irish
Big Irish's Avatar
Thank you very much .This is the way I am going to go .I am searching out a 88-98 bench seat now . Thanks again .
Old 12-01-2010, 10:24 PM   #42
Big Irish
Big Irish's Avatar
Blue jeep in your pics the seat is not all the way back to the cab support .is there a reason you did that ?
Old 12-01-2010, 11:22 PM   #43
MrDude_1
the top of the seat is further back then the bottom.. look at the first pic he posted. the top of the seat is on the back wall, even though the bottom isnt.
Old 12-01-2010, 11:27 PM   #44
Big Irish
Big Irish's Avatar
Understood makes sense .I assume if I a willing to have the seat in more of an upright position .I could push it back further .
Old 12-02-2010, 12:06 AM   #45
BlueJeep
BlueJeep's Avatar
My seat is as far back as the cab will allow. The top of the seat back can't quite go back all the way because the corners of the seat back hit the rounded corners of the cab, but it's really close. I positioned the seat on the sliders all the way back, with the seat back as far as it would go. Then I drilled the holes and mounted it. That way, if my wife who is shorter wants to drive it or my kids some day, the seat can be slid forward quite a bit.
Right now I've just got big washers on the bottom side of the seat, but when I sandblast the bottom of the cab I'll weld on some plates like new vehicles have, to anchor the seat better.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-02-2010, 12:14 AM   #46
Big Irish
Big Irish's Avatar
Thumbs up Re: Need more leg room . please help
Good info .I assume the same situation with a 5 window ? Do you think u are sitting higher or lower than the factory seat ? Thanks
Old 12-02-2010, 07:06 PM   #47
BlueJeep
BlueJeep's Avatar
I don't know. I just measured, and it's approximately 10" from the floor to the "butt area" of the seat. I assume this is lower than stock.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-03-2010, 01:46 AM   #48
mobileortho
mobileortho's Avatar
At 6'5" 250 I had the same problem. I removed the tank and mounted one in the rear frame rails then installed bucket seats from a full size Chevy. It made a big difference.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 12-03-2010, 08:21 PM   #49
mr48chev
mr48chev's Avatar
The stock seat in my 51 1-1/2 ton is 12 inches high at the front
I've had a lot of seats in my 48 since I chopped it and found that a guy has to be real careful about the seat backs of the seats he tries to put in there. Most high back seats lean back too far and take up way too much room.
On the 88---- seats, if they sit too high a guy could pretty easily section the base by cutting a strip out of it an welding it back together a bit lower. Even if you can't weld or don't have a welder you could trim it down and take the pieces to someone to weld it back together.
Old 12-03-2010, 10:17 PM   #50
Big Irish
Big Irish's Avatar
This looks great also .I hope the bench gives as much room .This great help
