Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 04-28-2011, 07:41 AM   #26
Whittaker
Re: 6 Lug Rear Disc with E-Brake Brackets
The suspension trailing arms are they something you made?
Also can the discs be had in dimpled/drilled and slotted?
I have 95 Camaro Z28 calipers laying around with backing plate/bracket.
Any one ever tried the 98-2002 Camaro Z28 2 piston caliper in front. The so called LS1 brakes. I imagine since the rotor might be thinner may not be very good for a heavy truck.
I think I'm ready to buy the brake booster plate and the hydro boost adapter.
Rob
Whittaker is offline
Old 04-28-2011, 11:53 PM   #27
Captainfab
60-66 Nut
I relpied to your PM......thanks
Rob
Captainfab is offline
Old 05-04-2011, 09:24 PM   #28
Whittaker
THE front or rear for the Chevy truck rotors? Or are they the same?
Old 05-04-2011, 11:18 PM   #29
Captainfab
60-66 Nut
You need the front rotors. The rears won't work with these brackets. These brackets come with a parts list with part numbers for the parts you will need. You should have your parts order in the next day or so.
Old 05-06-2011, 07:48 AM   #30
Last_Paladin
Those look like rear rotors. The 2000 Suburban has an integral parking brake in the rotor hat. Are you sure?
Last_Paladin is offline
Old 05-06-2011, 09:38 PM   #31
Captainfab
60-66 Nut
Yes you are correct, my mistake. I guess I was thinking of the new setup that I'm working on, which uses the front rotor.
Old 08-16-2011, 10:38 AM   #32
Last_Paladin
I am finally at a point where I can use these. Before I buy a set, any idea what ebrake cable to use?
Old 08-16-2011, 11:43 PM   #33
Captainfab
60-66 Nut
I've not done an installation using these Camaro calipers yet, so I don't have a definite answer for you. This question has been asked before and again todat in the 5 lug Camaro caliper bracket thread. So far no one has replied. Someone has to have an idea, since I have sold quite a few sets of these, and glock sold several sets before me. I'm not familar with the factory e-brake cables on the '93-'97 F-body, so I don't know if those can work or not. You might end up having to have a couple cables made by someone like Inline Tube, or one of the other vendors. I'll look around some and see what I can come up with.
Old 09-14-2011, 06:50 AM   #34
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I just stumbled onto this thread today, very neat idea. Any luck with a bracket to allow the use of 15" wheels? I saw you mentioned working on one, but I couldn't see if you had put one together yet. It is late, and I'm crashing hard so I could be missing it.
I do have a question for you though Capt., Going from a disc/drum setup to a disc/disc setup, Would that require a new master cylinder/booster combo? I'm getting ready to do a swap on the front of my '65 to discs, and am just curious if I am going to need to replace the booster/master parts again if I upgrade to rear discs. Booster is off a '89 C1500, and master is off a '79 C10. Thanks Capt.
fryer1979 is offline
Old 09-14-2011, 11:19 PM   #35
Captainfab
60-66 Nut
I just about have a few of the ones that will accept 15" wheels, completed. Right now I'm waiting on an order of lazer cutting, which I should have by sometime next week.
Technically when you switch to 4 wheel discs, you should change your master cylinder and proportioning valve to disc/disc components. Some guys claim they have used the disc/drum components with success. If it were mine, I would switch the master to a disc/disc unit, and then install one of the Wilwood adjustable combination valves. You could actually install one of the Wilwood combination valves with your disc/drum setup.
http://www.summitracing.com/parts/WIL-260-11179/
Old 09-15-2011, 12:39 AM   #36
shortbed70
shortbed70's Avatar
someday...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 11-18-2011, 12:19 AM   #37
Captainfab
60-66 Nut
The 6 lug rear disc brackets for 15 inch wheels are now available here
http://www.67-72chevytrucks.com/vboa...22#post5016222
Old 02-23-2012, 03:02 PM   #38
LDO
LDO's Avatar
Bringing this thread back to life. Anything wrong with keeping the 7/16x20 lugs? Are the holes in the rotors already set up for the 1/2 hole? Will this be a problem?
LDO is offline
Old 02-24-2012, 12:22 AM   #39
Captainfab
60-66 Nut
The wheel stud holes in the rotors are sized for 14mm studs which measure .551". Technically speaking, with the 7/16" studs which measure .437", you should probably have some bushings made to take up the difference. With that said, not everyone does so.
Old 12-25-2012, 11:25 PM   #40
Captainfab
60-66 Nut
Haven't bumped this in a while.......
Old 12-27-2013, 01:47 AM   #41
Captainfab
60-66 Nut
Ttt
Old 02-21-2014, 04:17 PM   #42
Mater/10
Mater/10's Avatar
Are these still in Production? Im interested in a set
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline
Old 02-22-2014, 12:40 AM   #43
Captainfab
60-66 Nut
I have one set left. I'll send you a PM with payment details
Old 06-01-2014, 12:56 PM   #44
Captainfab
60-66 Nut
I am discontinuing this bracket. I will soon be releasing a different bracket for the 6 x 5.5" wheel stud pattern that will work with 15" wheels and also have an e-brake.
Closed Thread
