Old 05-13-2011, 01:54 PM   #26
bollybib
bollybib's Avatar
Re: Jim's 1969 Custom/20
REMOVING THE BED (1 of 2)
So I bit the bullet and took the bed off yesterday, solo.
The eight holddown bolts came out cleanly, no spinners. I had a couple of minor load shifts on the way up, but by moving slowly and checking constantly, I got there safely. It took me about six hours for the lift. This job was a freebie, I had everything on hand.
*Things to watch for: slide the bed back a bit before lifting to avoid hitting the cab; load distribution and balance.
Size:  69.0 KBName:  000_0014 8pct.jpg
Size:  66.3 KBName:  100_4650 8pct.jpg
Size:  62.0 KBName:  100_4654 8pct.jpg
Size:  67.6 KBName:  100_4655 8pct.jpg
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
Last edited by bollybib; 06-09-2011 at 11:04 AM. Reason: fix a few words here and there...
bollybib is offline   Reply With Quote
Old 05-13-2011, 01:55 PM   #27
bollybib
bollybib's Avatar
REMOVING THE BED (2 of 2)
Size:  70.6 KBName:  100_4659 8pct.jpg
Size:  68.9 KBName:  100_4660 8pct.jpg
Size:  69.8 KBName:  100_4667 8pct.jpg
+ + + + + + + + + + + + + +Name:  100_4664 8pct.jpg
Size:  70.2 KB + + + + + + + + + + + + + +
- Jim -
Last edited by bollybib; 05-14-2011 at 09:10 PM. Reason: fiddling around nothing better to do
Old 06-02-2011, 12:03 PM   #28
bollybib
bollybib's Avatar
DRIVE PINION OIL SEAL, EATON H052 (Part 1 of 6)
I wasn't getting minor drips from the rear end, it was more like a gusher. It needed a new seal. After some research, this didn't seem to be too difficult to do. I just needed bigger tools, some education, and decent access, that’s all.
A fairly simple procedure according to the 1969 Chevrolet Truck Chassis Service Manual, Series 10-60, Rear Suspension and Drive Line 4-32 (whew).
Drive Pinion Oil Seal (Fig. 66)
Replacement
NOTE: The pinion oil seal may be replaced with the carrier assembly installed in the vehicle.
1. Disconnect propellor shaft and remove pinion flange and deflector.
2. Remove bolts retaining the oil seal retainer to carrier, and withdraw retainer from pinion.
3. Pry old seal from bore, using care so as not to damage the machined surface of retainer.
4. Thoroughly clean all foreign matter from seal contact area in retainer.
5. Pack the cavity between the seal lips with a high-melting point bearing lubricant, position seal on installer Tool J-22231 so that seal shoulders against installer drive surface.
6. Press seal into retainer until it bottoms against shoulder.
7. Carefully position seal retainer over pinion to prevent damage to seal, and torque retaining bolts to specifications.
8. Reinstall pinion flange and propellor shaft.
Name:  100_4795 15pct.jpg
The Story follows:
Eatin’ Piñon Nuts
(by Jim H., title suggested by special-K)
In Service Manual order:
*NOTE: The pinion oil seal may be replaced with the carrier assembly installed in the vehicle.
But not on the ground with the bed on ! Personally, I wouldn’t want to try doing this with the vehicle on the ground and the bed in place…uh uh.
*1. Disconnect propellor shaft and remove pinion flange and deflector
Disconnecting the propellor shaft presented no problem. Removal of the pinion flange (aka yoke) involves removing the pinion nut. I found a couple of threads that discuss the issue of removing this stubborn fastener.
http://67-72chevytrucks.com/vboard/s...d.php?t=275286
http://67-72chevytrucks.com/vboard/s...d.php?t=197837
Thanks especially to JAKES 68GMC (#14, Deep Creep), phantom dually (#15, heat), and special-K (#16, for eatin’ piñon nuts ! )
I decided to be conservative and gave myself four days to heat and soak before attempting to loosen the nut. I bought a can of Deep Creep (DC) and used a MAPP gas torch to heat the nut. I concentrated the heat on the nut as much as possible after which I applied DC. I periodically soaked the nut in DC until the next heat. I did this four times over the following days.
Name:  100_4717 10pct.jpg
Size:  67.5 KBName:  100_4785 10pct.jpg
- Jim -
Old 06-02-2011, 12:06 PM   #29
bollybib
bollybib's Avatar
DRIVE PINION OIL SEAL, EATON H052 (Part 2 of 6)
The OD of the 1 5/8" socket I needed to remove the nut was too big to slide into the ID of the yoke and onto the nut.
Measured ID of yoke…...…2.18 in
Measured OD of socket…..2.20 in
I ground down the socket until its diameter was slightly smaller than the ID of the yoke and then it slipped right in. I guess I could have got a thin wall socket or bought an el cheapo one to destroy, but this Craftsman socket jumped into my hand and said "Use me" so I had no choice. I used a ¾" drive breaker bar to drive the socket and a 3’ long cheater pipe on the bar. I had to block the wheels firmly at the rear and engage the brake to prevent the vehicle from moving backwards while I applied force. Once the vehicle was firmly fixed in place, I applied force to the end of the pipe. After several tugs, the nut came loose with little complaint. I guesstimate I had to apply about 60-70 lbs of force to break the nut free (3 ft x 70 lb = 210 ftlb). This is close to the specified 220 ftlb tightening torque, so the DC and heat must have done their jobs well.
Name:  100_4779 10pct.jpg
Size:  72.1 KBName:  100_4774 10pct.jpg
Name:  100_4912 10pct.jpg
Size:  70.1 KBName:  100_4913 10pct.jpg
- Jim -
Old 06-02-2011, 12:07 PM   #30
bollybib
bollybib's Avatar
DRIVE PINION OIL SEAL, EATON H052 (Part 3 of 6)
I then withdrew the yoke with a puller and moved on to step two.
Name:  100_4798 10pct.jpg
Size:  70.7 KBName:  100_4802 10pct.jpg
Size:  73.2 KBName:  100_4806 10pct.jpg
It’s possible that I could have got the bloody thing off without going through all this heat and soak monkeymotion, but I like to try new ways of doing things and the end result was acheived cleanly and without swearing.
*2. Remove bolts retaining the oil seal retainer to carrier, and withdraw retainer from pinion.
This was straightforward. The bolts came loose OK using a ½" drive breaker bar and a ¾" socket. The retainer was a little stubborn coming off so I got it started with a bit of tapping and prying and then a puller to get it off. There is a convenient lip on the retainer on which to engage the puller claws.
Name:  100_4810 10pct.jpg
Size:  72.2 KBName:  100_4811 10pct.jpg
- Jim -
Old 06-02-2011, 12:13 PM   #31
bollybib
bollybib's Avatar
DRIVE PINION OIL SEAL, EATON H052 (Part 4 of 6)
*3. Pry old seal from bore, using care so as not to damage the machined surface of retainer.
I was a little unsure of myself on this at first because GM used the word "pry". I tried prying it out from the rear but that dint git it. I found if I drove a punch against the forward metal surface of the seal, it drove out easily and I didn’t touch the machined surfaces at all.
Name:  100_4847 10pct.jpg
The rubber on the old seal was hard and brittle as expected. It had a GM part number on the metal ring so it could be the original 42-years-old-or-so seal.
*4. Thoroughly clean all foreign matter from seal contact area in retainer.
More cleaning wash wash wash. I like to use odorless mineral spirits in combination with a spray bottle, lots of different kinds of brushes, various sizes of pans, and lots of good quality paper towels. Cleaning car crud is always messy but I manage to keep my work areas ungreasy this way. I keep the sensitive-to-dirt parts protected as well as I can.
Name:  100_4858 10pct.jpg
Size:  67.8 KB Name:  100_4871 10pct.jpg
*5. Pack the cavity between the seal lips with a high-melting point bearing lubricant, position seal on installer Tool J-22231 so that seal shoulders against installer drive surface.
The new seal is a National 411330N. I didn’t pack the cavity so I hope GM will forgive me. There isn’t much room to get in to pack on this seal design. I’m not sure why GM wants you to do this, maybe as a method of priming the seal until the oil fully circulates. The grease eventually dissolves anyway. Instead, I thoroughly wetted the seal with gear oil (and the yoke surface, too in No. 8, below).
I made a tool to press in the seal from a piece of ¾" plywood instead of searching for years to find and paying a fortune for an original Tool J-22231. I cut it to a diameter of 3.8 inches.
Name:  100_4863 10pct.jpg
- Jim -
Old 06-02-2011, 12:20 PM   #32
bollybib
bollybib's Avatar
DRIVE PINION OIL SEAL, EATON H052 (Part 5 of 6)
*6. Press seal into retainer until it bottoms against shoulder.
I oriented the new seal with the thin lip forward as was the old seal. With my plywood tool diameter as such, I had full engagement of the seal ring and when pressed, it couldn’t go all the way to the bottom. I thought this was a good idea to prevent me from going too far and damaging the seal. When pressed in as far as the plywood tool allowed, I placed the old seal between the plywood tool and the new seal, being careful to align everything in a kopasetic manner. Then for the last push to bottom, I pressed slowly, making several visual checks along the way so as not to damage anything.
Name:  100_4866 10pct.jpg
Size:  63.6 KBName:  100_4864 10pct.jpg
Buying the press I mentioned in Post #11 above was a good investment. I used to try doing this sort of job using a bench vise. With the press, I had much better control. The seal wasn't cheap so it got treated with respect.
*7. Carefully position seal retainer over pinion to prevent damage to seal, and torque retaining bolts to specifications.
Ya, be careful not to whack your new seal on the splined shaft, dude. The bolt torque chart calls the seal retainer a "pinion bearing cage" which confused me a little. Now I had a chance to use my new torque wrench, a CDI 30-250 ftlb, for the first time ! My old torque wrench was an el cheapo Craftsman and the plastic handle fell off recently after only 20 years of service. I torqued the five ½-13 bolts with new Grade 8 lockwashers to 95 ftlb.
The Service Manual doesn’t mention cleaning the yoke, the carrier surfaces or using a gasket, but these are necessary, too. The yoke cleaned up nicely and the sealing surface was nice and smooth, what luck! I made an O-shaped insert from flexible plastic to keep crud from getting into the carrier guts while I cleaned the gasket surface and bolt holes. I cleaned and chased all the bolt hole threads. They were full of junk and took several passes of the tap to get out all the debris.
Name:  100_4883 10pct.jpg
Size:  67.4 KBName:  100_4879 10pct.jpg
I didn't find a precut gasket readily available so I used Permatex Ultra Black RTV on the advice of BCOWANWHEELS (#6 in this thread à http://67-72chevytrucks.com/vboard/s...l+gasket+eaton). The pic below was taken at the finger-tight, ooze-out, beginning-to-cure stage of the RTV.
Name:  100_4888 10pct.jpg
- Jim -
Old 06-02-2011, 12:21 PM   #33
bollybib
bollybib's Avatar
DRIVE PINION OIL SEAL, EATON H052 (Part 6 of 6)
*8. Reinstall pinion flange and propellor shaft.
I squirted a lot of gear oil on the seal and wetted the yoke, and then inserted the yoke. I had to tap it in with a wood block and a hammer, the seal offering some resistance to insertion as it should. Then the fat pinion washer and pinion castle nut went on, ready to snug up. I torqued the nut to 220 ftlb per Specifications 7 section under 5200 Lb. Capacity Bolt Torques in the Service Manual. At this torque, the castle nut covered the cotter key hole, so I backed it off a tad. The nut ended up in the same position that it started according to the marks I scribed before I removed the nut. I installed a new cotter key and then spun a wheel by hand for a while to get the juices flowing inside the differential again.
.......................after.....................................................and before.......................
Name:  100_4903 15pct.jpg
Size:  84.9 KBName:  100_4679 15pct.jpg
The next day I found a small drip on the pavement, residue I hoped. Maybe this is why GM says pack the seal with grease, to avoid this situation. I sprayed around the yoke area with my mineral spirit sprayer and wiped everything off good. I drove the truck up and down the street a few times. I also ran the drivetrain with the rear wheels removed and the axle on jack stands several times while I was working on the driveshaft (future project post). As of 6/2/11, no evidence of a leak so I hope my installation will be good for another 40 years or so.
This job was labor intensive. I worked on it from 5/13 - 5/23/11. I haven’t been keeping track of the hours I spend because I get so much pleasure out of working on this truck. However, if one had a shop perform the work I’ve been doing so far, I guesstimate the total costs I’ve itemized in this thread thus far would be double, at the very least.
As a do-it-yourselfer, it doesn’t always seem like I’m spending much as I go along, but it sure adds up. I’ve been including the cost for tools and consumables if they are first purchased for work on the truck.
Pinion seal, Deep Creep..………….....……$.35.87
Lock nuts…………………..……..........………....1.36
1 5/8" socket…………………………........…....21.74
Permatex Ultra Black RTV…………........….…7.60
Mineral spirits (1 gal., ran out again)......16.80
Total……………………….............………….…$.83.37
While the bed has been off I've had a chance to evaluate the condition of the driveshaft bearings and support, the frame, the shocks, and the exhaust. I've cleaned up the frame, installed new driveshaft bearings and supports, new shocks, and I'm working on the exhaust now. I'll post more about these later.
Thanks for reading and keep on truckin'.
Jim
- Jim -
Old 06-05-2011, 06:38 PM   #34
69-72
69-72's Avatar
Nice write up, my 69 Custom Camper 20 is almost identical except for the upper trim.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 06-05-2011, 10:39 PM   #35
bollybib
bollybib's Avatar
I like it. Yours looks real straight and unmolested. Where was yours built ? Mine came from St. Louis. She's a bit tired but I hope to freshen her up little by little.
Thanks for your comment and the pic. Brothers-in-arms we are.
- Jim -
Old 06-06-2011, 09:27 AM   #36
69-72
69-72's Avatar
Mine came from Oshawa, Ontario Canada 70,000 miles and only used to haul a camper. Never winter driven, which means more up here then it would down there Unfortunately the other difference I have is the leaf spring rear.
My speedo has been running too fast ever since I got it and I have 4:10 gears also, I will have to try the speedo gear combo you have in yours to see if that will make it right
Old 06-06-2011, 10:27 PM   #37
bollybib
bollybib's Avatar
I wanted a coil spring rear, so I'm good on that, and Utah is pretty dry, so it's not very rusty.
While wading through the numbers today, I discovered that my transmission doesn't look to be original equipment, so take that into consideration (I'll be posting more on this soon).
- Jim -
Old 06-07-2011, 05:18 PM   #38
bollybib
bollybib's Avatar
NUMBERS (Part 1 of 4)
This truck came to me without the benefit (or detriment) of prior owners’ input or documented history. As I’ve been working on it, I’ve recorded information that provides clues to its origin, production date, and degree of originality. I’m not a stickler for originality, but it’s interesting to discover the story that all the various numbers on the vehicle can tell me. As the codes are deciphered, a clearer picture of the history of the truck emerges.
I’ve had some practice at this. The "numbers match" thing is a big deal in the Vette world, and as the owner of a Sting Ray since 1987, I’ve dug through a lot of numbers on it. It would be nice if there were an acknowledged authoritative source on originality for classic Chevy trucks (like Nolan Adams on Vettes), but there doesn’t seem to be. I read somewhere that a lot of GM documents about these trucks were destroyed in a fire so that could explain it ( urban myth or fact ? source info on the fire anyone ? ).
Most of the modifications to the truck that I’ve found are attached to the original engine block (ignition, carb, manifolds, heads, and headers, see Post #16, above). I’ve only included items here that first looked to me like factory original parts with coded information.
Where you see "Ref." Below, I have given the source of my information.
Odometer reading: 21880.7
Hmm. How many times has it rolled over ? Anyone’s guess, I’ll never know for sure. I’d like to think only once. When I get into the engine I’ll have a better take on this.
First sold by Gene Harvey Chevrolet, American Fork, UT according to the dealer sticker on the tailgate.
Name:  100_3646 12pct.jpg
Serial number on cab nameplate: CE249S816458
Name:  100_3444 12pct.jpg
---C = 4x2
---E = V8 gas
---2 = 3/4 ton
---4 = Pickup with Cab and Bed
---9 = 1969
---S = St. Louis
---816458 = serial number
Serial number on frame: 9S816458
Name:  100_4526 12pct.jpg
SPID
Name:  100_4198 12pct.jpg
Service Parts Identification V.I.N. CE249S816458 W/BASE 127
OPTION NO. DESCRIPTION
MODEL = CE20934
4BX2BB.....BODY SIDE MOLDING-W
4C60HF.....AIR CONDITIONING-AL
4LS9KA.....350 CU. IN. V-8 ENG
4N40GD.....POWER STEERING
4U63NA.....RADIO-PUSH BUTTON
4Z62BC.....CUST-COMF&APPEAR EQ
4A11CA.....TINTED GLASS
4B85AB.....BODY SIDE MOLDING
4G50DA.....HEAVY DUTY REAR SPR
4M49TD.....TURBO HYDRA-MATIC
4P03CA.....CHROMED HUBCAPS
4Z53EQ.....AMMETER- OIL GAUGE
4555AD.....WHITE/SADDLE
- Jim -
Old 06-07-2011, 05:19 PM   #39
bollybib
bollybib's Avatar
NUMBERS (Part 2 of 4)
Engine block
Name:  100_5122 12pct.jpg
Size:  85.3 KBName:  100_5121 12pct.jpg
Name:  100_5109 12pct.jpg
Casting number 3932386
Casting date I268 (I=September, 26=day of month, 8=1968, [assuming a straight line I, not the number 1])
Stamp pad V0928WK
V = source plant, Flint, MI
0928 = (09=September, 28=day of month)
WK = 1969 350 tur hydro - 255 4 C-10 to 35
Engine Ref: : http://www.nastyz28.com/chevy-engine-code-stampings.php
Transmission nameplate
Name:  100_4324 12pct.jpg
70M556 (556 = July 10, 1970 )
70-CM-6134 (dunno what 6134 is, serial or part number maybe)
Turbo Hydra-matic 400, 1970, Series 30 mobilehome chassis, w/307 motor ( hmm, this doesn’t look original at all )
Transmission Ref: http://books.google.com/books?id=JJI...page&q&f=false Page 13
http://novaresource.org/trans.htm
Rear end
Name:  100_4682 12pct.jpg
Casting No. 3934635
ID No. JU 0928 G2
JU = 1969 Series 20-G20 4.10 ratio (no Positraction)
09 = September
28 = day of month
G2 = Gear and Axle Plant, 2nd shift
There is also a stamped letter B (two places) and 99 on the housing of whose meaning I know not (inspection stamps if I had to guess).
Rear End Ref: p. 85 Chevrolet Truck Parts Catalog for 1946-1972 Series 10-30, September 1972
- Jim -
Old 06-07-2011, 05:19 PM   #40
bollybib
bollybib's Avatar
NUMBERS (Part 3 of 4)
Rear brake drums
Name:  100_3858 12pct.jpg
GM3857752 KH54189 I248 (I=September, 24= day of month, 8=1968)
The KH number on the drum could be a Kelsey Hayes part number (the OEM).
Rear wheel hubs
Name:  100_3811 12pct.jpg
GM3763180 I268 (I=September, 26= day of month, 8=1968)
Hub and drums: The last four characters are the date code. The first character is probably a straight line letter I and not the number 1. This would correspond to the other September codes.
Alternator
Name:  100_5131 12pct.jpg
1100839 42A, 8J14 12VNEG
8 = 1968, J = September ( "I" gets skipped on alternators), 14= day of month
This looks like it’s the original alternator which is kind of amazing.
Frame markings
Name:  100_4721 12pct.jpg
Size:  69.3 KBName:  100_4719 12pct.jpg
Top of both frame rails at rear 95
Lower frontmost crossmember 95
Rearmost crossmember B-CE20934
The 95 appears in three places and may have been used as an assembly line sequence number (my guess). CE20934 matches the SPID model number. I have no clue what the "B" might mean.
- Jim -
Old 06-07-2011, 05:20 PM   #41
bollybib
bollybib's Avatar
NUMBERS (Part 4 of 4)
Cowl markings
Name:  100_5126 12pct.jpg
Size:  75.7 KBName:  100_5127 12pct.jpg
Name:  100_5128 12pct.jpg
Size:  70.8 KBName:  100_5129 12pct.jpg
2T CE20934 6 S9KA 49TD T2
2T & T2 = upper and lower trim (? my guess)
CE20934 = SPID model number
6 = ???
S9KA = SPID engine option - 350
49TD = SPID transmission option - Turbo Hydra-matic
Seat Belts
Name:  100_5276 12pct.jpg
Robbins Model #9300
40K68
40=40th week of 1968 (the 40th work week of 1968 is from Sep. 30 to Oct. 4)
K=Manufacturer code (i.e., Robbins)
68=1968
Seat Belt Ref: http://www.camaros.org/seatbelt.shtml
1968 Calendar Ref: http://www.timeanddate.com/calendar/...1968&country=1
The prevalence of late September 1968 codes leads me to believe that this truck was among the first of the 1969 model year trucks out the door, built in St. Louis probably in early October 1968. At that time I was 19 years old and in Navy basic electricity and electronic school in San Diego (beep school we called it), driving a 1958 Ford station wagon, my first car and surf wagon….but I digress.
The TH400 transmission looks to be a 1970 unit, so it was probably retrofitted into the truck later (or installed to replace a failed unit). When I got the truck, I could see that it had been set up for camper and trailer use, so a transmission retrofit (TH350 to TH400 perhaps ?) makes sense and an early failure of the original transmission isn’t out of the question,either. The detent (aka kickdown) wiring and switch for the TH400 look like factory pieces, could be from another truck, could be original to this truck, I dunno. If there was a kickdown cable for a TH350, it’s long gone. So I don’t really know what transmission it had originally. Perhaps some of you transmission gurus could shed some light on this one.
The serial number could provide a clue to the assembly date, but I don’t know of a reference source that shows the range of serial numbers produced in a given month at a specific assembly plant. If you know of one, I’d be interested in seeing it.
Many of these trucks have been scrapped or modified, and the number of intact examples decreases daily. In addition, an agreed-to authority on originality appears to be absent. I offer up this information hoping it will serve as a documented source to those interested in the historic aspect of these trucks.
OK class is over, you can wake up now.
Jim
- Jim -
Old 06-07-2011, 06:51 PM   #42
VA72C10
VA72C10
VA72C10's Avatar
Missed your thread up until now but just read up on it. Cool truck, neat that it's so original, and GREAT writeups!!!! I'm going to recommend them to be used as FAQ material. Keep on trucking.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-07-2011, 07:00 PM   #43
Papa-J
Papa-J's Avatar
Very informative, I love it, keep em coming.
Papa-J is offline   Reply With Quote
Old 06-08-2011, 12:44 PM   #44
69-72
69-72's Avatar
I am big into the history and original stuff too. I finally managed to get an original dealers emblem for my truck at a swap meet a couple weeks back, it snapped right back into the holes that were still there.
If you havent already you might wanna check behind or under the seat, sometimes they stashed a build sheet between the springs.
Old 06-08-2011, 03:57 PM   #45
69cummins
looking good!
71GMC 4X4 6.0 LQ4 NV4500/205 Dana 60 with crossover steering and a 14B in the rear, 69 longbed 4x4 with a cummins and D60 frt and D80 rear.
69cummins is offline   Reply With Quote
Old 06-08-2011, 10:07 PM   #46
bollybib
bollybib's Avatar
Thanks a heap compadre. Sometimes I think it's more work to write about it than do it. I try to give as much credit as I can to other board members who have steered me in the right direction.
Thank you. I need to take a nap first, then I'll write some more.
Finding original parts that fit like that is one of the pleasures of working on old equipment. I have looked under and behind my seat, but no luck. So it goes.
Originally Posted by 69cummins View Post
looking good!
Thank you very much.
- Jim -
Old 06-09-2011, 09:59 AM   #47
oldman3
oldman3's Avatar
Hey Jim, nice detail as usual, you do such a great job on all your post. Catch you next post......Jim
oldman3 is offline   Reply With Quote
Old 06-10-2011, 12:55 PM   #48
bollybib
bollybib's Avatar
Thanks Jim, I get a lot out of your posts, too. See ya'.
- Jim -
Old 06-10-2011, 01:25 PM   #49
bollybib
bollybib's Avatar
INTRODUCTION
I sorta jumped right in with the gory details of my project without introducing myself or telling you why I got this truck in the first place. I think most people put this information near the beginning of their threads, but I didn’t, so I think I’ll say something about that here. Right now, I’m slowly fittting up my new dual exhaust, waiting for parts, etc., and I don’t have enough work on it to keep me busy all day, so I’m free to write stuff here to my heart’s content.
AUTOBIOGRAPHY (with cars and trucks)
I was born in Glendale, California and I grew up in Torrance not far from the beach. My parents bought a new house in Torrance in 1954 where I lived off-and-on for 54 years. My dad owned a Crosley station wagon and a beautiful green and black 1951 Ford Crestliner with a black vinyl top (long gone now). I can remember him letting me steer the Crosley when I was a wee lad while I stood on his lap. Sadly, my dad passed away at the young age of 37 when I was but 9 years old. My mom remarried a few years later and my stepdad put me to work at his place of employment, a muffler shop and gas station. I started out as the janitor and gardener. After a while I was helping remove and install mufflers and shocks, pumping gas, changing oil, fixing tires, all that. When I had enough money, I bought my first car, the service station owner’s 1958 Ford station wagon. I worked at the gas station until I graduated from high school. After graduation, I worked for a year at TRW as a reproduction equipment operator.
In 1968 Uncle Sam called on me so I joined the Navy to avoid being drafted and going to Nam and spent the next five years, ten months, and two days in the USN. The Navy sent me to computer school in Vallejo in 1969 and while there I bought my second car, a 1959 Ford station wagon. On my last Westpac cruise in 1973, I ordered a 1974 Dodge van at the Exchange in Subic Bay and that is what I had when I got out in Norfolk in 1974 as a Data Systems Technician Second Class.
After I came home to Torrance, I sold the van (gas crunch era) and bought an economical 1974 Dodge Colt (made by Mitsubishi) that I kept for the next ten years. I went to college on the GI Bill and eventually graduated with a bachelors degree in engineering (with an electronic specialization) from UCLA in 1980. My first "real job" was as an electrical design engineer with an engineering firm in Pasadena. I worked for them for seven years, spending two years in the office, and then moving on to construction in the field. My field assignments were in Tacoma, Washington building oil and gas gathering equipment for ARCO, and in Jubail, Saudi Arabia building a new refinery for Petromin Shell. While in Tacoma, I ordered a 1983 GMC S-15 Jimmy 4x4 that I kept for the next 27 years. Before I went to Saudi, I bought my mom a 1976 Ford Granada (which I still have).
Oil and gas work petered out in ’86 so I came back to Torrance. In 1987, I found work with an engineering firm that provided construction manangement services to the US Postal Service and spent the next two years building a general mail facility in Los Angeles. During this time I bought my 1967 Corvette and took the body off and restored the chassis. When the Postal Service job was over, I hooked up with a buddy and got a job in Cairo, Egypt of all places. I spent the next four years in Cairo as an advisor to the Egyptian army for construction of an M1 tank plant. I bought my house in Carlsbad with the money I saved on that job. When that was over I came back to Torrance and decided I’d had enough drifting around; time to settle down.
I’d hoped to find someone to settle down with, but that didn’t happen. For the next several years I struggled to find steady employment locally. I worked in retail, in sales, and for industrial contractors, none of which lasted long; early 90s in California were not good times. I took many classes at the local community college; welding, auto and machine shop, accounting, & art. I started surfing again, a lot. Eventually I found steady work with a construction consulting firm in Torrance that lasted for 12 years (where I had to do investigations and write a lot of long-winded, detailed reports, does it show ?). After my mom passed on, I fixed up the Torrance house, sold it in 2008, quit my job, and moved to Carlsbad. And here I am now, with a Vette, a Granada, and a Chevy truck, quite content.
WHY A TRUCK ? (http://en.wikipedia.org/wiki/Why_a_Duck%3F)
So why did I buy a 1969 ¾ ton Chevy truck ? Good question. My little Jimmy, although dependable for 27 years, had qualities that I didn't care for. I didn’t use the four wheel drive, it was a bi tch to work on, and at the end of its life, needed a lot of work. So I got rid of it in August 2010 and started looking for something different. I wanted something pre-1976 so I wouldnt have to deal with the smog man and that I could do most of the work on myself. I looked at Rancheros, El Caminos, and Ford trucks at first.
My Vette had sat in a corner of the garage in Torrance and then Carlsbad, unused, for almost 14 years, and with inadequate storage prep, it was kind of a mess when I started working on it again. But I got it running and back to the point it was at when I abandoned it back in 1996 or so. The engine is the original 327. I’ve had it down to the bare block, so I’ve been able to take a few measurements and inspect it. It’s a loosey-goosey motor and needs a rebuild, I doubt it has ever been rebuilt. It does OK around town, but on the road it uses a lot of oil. At any rate, I didn’t want to tear apart an original Vette motor for my first engine rebuild. So that led me to old Chevy trucks because I figured I could find one with an original 327 (at a reasonable cost) and use it for my first rebuild experience instead of fking up my Vette motor.
I discovered this site at about that time and found tons of useful information here. During this time, one of my friends kidded me about wanting an old, full size truck and he started calling me billybob. That name wasn't available when I signed up, and just wanting to be done with the signup process, I became "bollybib".
I found I didn't care much for Chevy truck design prior to 1967, but the 67-72s were quite appealing, 1967 and 1968 even more so among the six years. I found a few trucks available with 327s, but it was limiting my search. I also wanted rear coil springs and an automatic transmission. My upper limit was $4k and even that was kinda high, low $3k’s would be better. So I looked for a 350 or 327 (original to the truck), automatic, with rear coils, 1967 to 1972, and I ended up with what you see in this thread. It’s the first vehicle that I’ve purchased since 1987, kinda blows my mind, that. It’s a pretty cool looking truck and fits my criteria. As I’ve spent more time with it, I have had no regrets in my choice, and I feel I was fortunate to find one in this condition for a decent price.
Thanks for reading
and
THE END
- Jim -
Old 06-10-2011, 02:27 PM   #50
R&K's71
wow with all of that traveling i bet u have some storys to tell to bad im in Missouri id love to stop by and help with the truck and shoot the u know what with ya . Keep up the great work on the truck
R&K's71 is offline   Reply With Quote
