Old 04-28-2011, 12:00 AM   #26
toeb
toeb's Avatar
Re: dropping
I don't tow with blazer! but I do with my 94 1500 and I have the same notch on it with a 4-6 drop. I tow a 6.5 x12 trailer with a Polaris rzr and a 4 wheeler almost every weekend in the summer. I just bolted the notch in then welded the seams and boxed the back side of the frame. It's a little extra work but well worth it!!
toeb is offline   Reply With Quote
Old 04-28-2011, 10:44 AM   #27
Mkcustums
Mkcustums's Avatar
Re: dropping
Originally Posted by Mkcustums View Post
Be very careful towing with those, a guy on here who I think does engineer work said they lower the strength of the frame at the notch by about 60%. (maybe worse) It was a huge decrease, I remember that!
In his write up he says "Bolt in - This model replicates the popular bolt in notch, it gains you about 3-1/2" additional clearance. It captures the bottom and the outside of the frame and is ¼” thick. The frame is not boxed. FEA reveals the frame is 80% weaker than stock."
Here is a write up he did- http://67-72chevytrucks.com/vboard/s...d.php?t=457037
Mkcustums is offline   Reply With Quote
Old 04-28-2011, 11:38 AM   #28
Liddy71
Liddy71's Avatar
Re: dropping
Thanks MK thats some good infor I have a brother who is a welder by trade and I was going to have him do the back side don't think I will be towing with it just a cruiser
Liddy71 is offline   Reply With Quote
Old 04-29-2011, 12:06 AM   #29
Liddy71
Liddy71's Avatar
Re: dropping
are the springs on the 2wd blazer the same as a pickup center to center
Old 04-29-2011, 12:28 AM   #30
tobiahr
tobiahr's Avatar
Re: dropping
according to google results the length measured along the spring surface is the same for 1973-1987 pickups and blazers of the 2wd persuasion. The difference is the arch and weight capacity. Pickups have a 7 3/4 in arch with 1,290 capacity and Blazers have a 5 3/4 inch arch with 2,110 capacity. with a different arch the eye to eye measurement will be shorter for the pickup springs. also note the springs will compress more when using pickup truck springs on a blazer which will cause clearence issues under compression
tobiahr is offline   Reply With Quote
Old 04-29-2011, 12:45 AM   #31
Mkcustums
Mkcustums's Avatar
Re: dropping
Here is a little more spring info, doesn't list the Blazer though.
http://littlekeylime.com/MrN/mrnimages/leaf_springs.png
Old 04-29-2011, 02:48 AM   #32
tobiahr
tobiahr's Avatar
Re: dropping
the info i got was from the site that info was sorced from http://www.generalspringkc.com/index.php and one other http://www.sdtrucksprings.com/ . even that data isn't eye to eye. its measured along springs surface. the arch will change the eye to eye distance as well as compression.
Old 05-01-2011, 11:22 AM   #33
Liddy71
Liddy71's Avatar
Re: dropping
I guess the easy way would be to do a flip kit on the back which will be about 5-6 in drop and use my 3 in drop spindles and use 1 -2 springs on the front . any Ideal on shocks. I have seen shock extender use on the rear. like I said earlier I have brand new set kyb shocks that came with it front and rear shocks
