Old 05-16-2011, 11:11 PM   #26
Zoomad75
K5Camper
Zoomad75's Avatar
Re: 4'' lift method 84 K10
I'm a fan of the KISS concept. I get what CSA has stated, but I've found for the type of wheeling I do, 4" rough country springs with a shackle flip out back (even removing a overload leaf per side out back) has given more than enough flex with my tires. I'm running 35x12.50's on a 8" wide wheel. I do mainly mountain trails with some rocks, creek crossings, steep climbs and such. The rear with the shackle flip out-flexes the front for sure. The rough country springs are of a higher spring rate than ez-rides or soft ride springs which does limit some flex, but on the flip side they don't rub the fenders either. It's a balance for sure but for my K5 it's worked out excellent.
I spent about $250 on the rough country kit that included the front springs, rear blocks (didn't use due to shackle flip) steering arm, 4 shocks, hardware and brake line relocation brackets. I spent $100 on used shackle flip brackets (echobit- no longer in business) and bought brake lines for a GMT400 style 3500HD for the front that are longer than stock and fit with a minor size adjustment to the bore on the block end.
52" swaps are great up front don't get me wrong. If you got the fab skills, tools and time to do that. 4" front springs require less work to the point you could pull off the lift in a weekend.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 05-17-2011, 04:12 PM   #27
BallGroundk10
BallGroundk10's Avatar
Thanks to all who commented, I'm still taking it day by day. I'm 100 % on getting a rear shackle flip ($140) As for the front springs, I'm still weighing my options.
84K10 Silverado 33's 3''Lift (being restored)
06 F150 XLT
2010 Polaris 525 IRS
BallGroundk10 is offline   Reply With Quote
Old 05-17-2011, 04:33 PM   #28
csa daddy
csa daddy's Avatar
like i said check out chucks trucks you can get about any spring you want an for cheap usually
csa daddy is offline   Reply With Quote
Old 05-18-2011, 06:55 AM   #29
79bonanza
just go with some stock length front springs that are lift springs, your goin to have to do alot more work and invest alot more money than your goin to want to. the 52's in front are not goin to be very useful for your truck.
79bonanza is offline   Reply With Quote
