Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 06-07-2011, 04:27 PM   #26
robnolimit
robnolimit's Avatar
Re: 63-87 rack and pinion
Next we cleaned all the greese and grime off of the main crossmember. A piece of tape on the crossmember will make it easier to see the center line marks.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-07-2011, 04:30 PM   #27
robnolimit
robnolimit's Avatar
Using the lower A-arm u-bolts as a guide, measure and mark the center of the crossmember-make 2 or 3 measurments and double check your center from both sides.
Old 06-07-2011, 04:45 PM   #28
robnolimit
robnolimit's Avatar
Set the main mounting bracket onto the crossmember and line up the center hole with the center line mark. Locate the hole center and mark it.
Old 06-07-2011, 04:47 PM   #29
robnolimit
robnolimit's Avatar
Center punch and drill with a 3/8 bit
Old 06-07-2011, 04:50 PM   #30
robnolimit
robnolimit's Avatar
Re-mount the main plate and bolt in place. Reach through the large port in the crossmember behind each spring pocket,
Old 06-07-2011, 04:57 PM   #31
robnolimit
robnolimit's Avatar
Using the bracket as a guide drill the remaining 4 holes with a 3/8 drill bit.
Old 06-07-2011, 06:48 PM   #32
robnolimit
robnolimit's Avatar
Assemble the rack to the rack mount. Start with the drivers side rack mount bolt.
Old 06-07-2011, 06:50 PM   #33
robnolimit
robnolimit's Avatar
For the passenger side use the two supplied u-bolts to mount the rack to the bracket.
Old 06-07-2011, 06:52 PM   #34
robnolimit
robnolimit's Avatar
Test fit the rack mounting bracket. Our rack hit the lip of the crossmember-mark the interferance.
Old 06-07-2011, 06:54 PM   #35
robnolimit
robnolimit's Avatar
Use a grinder to cut the lip down for clearance.
Old 06-07-2011, 06:57 PM   #36
robnolimit
robnolimit's Avatar
Next is the spindle modification using a 5/8 drill bit. Drill out the tie rod mounting hole. Start from the top side. Try to drill it straight down throught the original hole.
Old 06-08-2011, 05:59 PM   #37
robnolimit
robnolimit's Avatar
Next it's on to steering shafts and u-joints. This bearing mount comes in the kit and must be fitted into the frame rail.
Old 06-08-2011, 06:01 PM   #38
robnolimit
robnolimit's Avatar
Using the diagram provided you will need to drill two new holes in the chassis both 5/16". Then open up the factory hole to 7/8".
Old 06-08-2011, 06:04 PM   #39
robnolimit
robnolimit's Avatar
This shows the holes drilled out. We also did a little die-grinding for steering shaft clearance. You'll see why next.
Old 06-08-2011, 06:06 PM   #40
robnolimit
robnolimit's Avatar
Here you can see the shaft support bearing in place.
Old 06-08-2011, 06:10 PM   #41
robnolimit
robnolimit's Avatar
To get the Flaming River u-joint (supplied with the kit) to fit. The lower lip of the frame needs to be ground back about 3/8" to clear.
Old 06-08-2011, 06:13 PM   #42
robnolimit
robnolimit's Avatar
Before final assembly, we noticed that one of the u-bolts was hitting the crossmember, so the excess thread was cut off. You will need to check this.
Old 06-10-2011, 12:49 AM   #43
SCOTI
SCOTI's Avatar
I haven't seen it asked so what are the chances of this working on larger 3/4-1 ton trucks too?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-10-2011, 04:31 PM   #44
robnolimit
robnolimit's Avatar
Yes, it will, no differences in the install.
Old 06-12-2011, 02:49 PM   #45
ebfabman
robnolimit, how much road time has this kit got? I'm intrested but would like a little more feedback.
ebfabman is offline   Reply With Quote
Old 06-13-2011, 11:26 AM   #46
robnolimit
robnolimit's Avatar
Three trucks are road testing. 2500, 5000, and 9000 miles. We have puller the tie rod ends off of the two higher mileage trucks and tested them against new ends, and have not been able to find any measurable wear. We are using a dail indicator at .0001". So far there are no problems, and no wear issues. Thanks for the interest
Old 06-14-2011, 07:02 PM   #47
robnolimit
robnolimit's Avatar
Here is a shot of the rack mounted in place.
Old 06-14-2011, 07:04 PM   #48
robnolimit
robnolimit's Avatar
Next we put the first u-joint onto the rack
Old 06-14-2011, 07:08 PM   #49
robnolimit
robnolimit's Avatar
The supplied 3/4 DD shaft fits through the support bearing and into the u-joint.
Old 06-14-2011, 07:11 PM   #50
robnolimit
robnolimit's Avatar
On the top side the second u-joint and the upper steering shaft go on.
