#26 |
Re: Making My Own Bed Wood-Equal Width Boards?
Get some 3" or so bolts, dimple the top of the cross sill where the bolt would go through, put the bolt through and tack the head. Make some spacer/washers out of 1/8 x 1 1/2 flat stock. Put the washer on the bolt from the bottom, center the bolt in the lower hole which is way too big and way too thin to support the bed and weld the washer to the bottom of the sill. Weld the bolt to the washer from the inside of the sill so the mounting surface stays flat.(one side is all you can get) Then weld the bolt head and dimple on the top of the sill and grind flat so the wood will sit right. There should be enough thread for the stud to fit through the bed mounting gasket and frame and be secured with a nut and washer from the bottom. IMO, six of these are more than strong enough to hold the bed in place. I haven't found a down side to this yet but I did put my bed on as a unit and my truck is more of a toy than a work truck. It won't make any trips to the dump.
#27 | |
I pity the fool with only 2 headlights! ![]() Last edited by Green 1959; 08-20-2013 at 12:06 AM. Reason: addiing |
#28 |
you can also just double nut a carriage bolt and relieve the underside of the wood.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#29 |
That is just what I was thinking of doing. Is there a mount or do you bolt the bracket directly to the frame?
I pity the fool with only 2 headlights! ![]() Last edited by Green 1959; 08-20-2013 at 12:17 AM. Reason: because |
#30 |
![]() ![]() Join Date: Nov 2008
Stands for "Task Force" - it's what GM called the '55.2 through '59 trucks. Much like the '47.5's thru '55.1's were called Advanced Design, or AD.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#31 |
Thank you, I didn't know that
I pity the fool with only 2 headlights! ![]() |
#32 |
Should I do maple or oak if I were to do it with plywood?
#33 |
I can't even remember what mine is now. I just went to Home Depot and looked for a grain pattern I liked. I knew my stain color already. Be aware that the plywood is too narrow in sheet form. I glued and dowled a piece of
1x2 pine to each side of mine and sanded to fit. The addition is almost completely hidden by the angle strip when installed but it gives you the correct height and something for the angle strips to bolt to+ it gives a finished look. I've seen sheets installed without doing this and it just doesn't look good IMO. Good idea with the carriage bolt but you know us fabricators with a welder in our hands.? |
#34 |
Moderator
![]() ![]() Join Date: Aug 2011
There is a bracket under the cross sills that sits on the frame. Use a smaller length bolt for them instead of using the long one and going thru the board. I did it also. Takes a few minutes before you install the wood but it works.
#35 |
4 beds in now over 65 years
Original 54-69 Cheap Plywood, two piece, top oil stained, 1969=1999, reused rails Marine Plywood, two piece, painted both sides, 99-2017 reused rails and finally Choicedek 12" , with recesses for underneath for carriage bolt mounting, all SS rails and hardware, holes drilled as needed. Used a forstner bit to cut 1" x 3/8" for recesses. Added cross sills where needed. Last edited by vintovka; 11-06-2018 at 12:01 PM. |
#36 | |
Now I have to go back and look to see if he used the strips with hidden bolts. OOPS SHOULD HAVE READ ALL THE WAY THROUGH THE COMMENTS.
#37 | |
#38 | |
Moderator
#39 | |
good looking bed vintovka, looks vaguely familiar
![]() Quote:
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#40 | |
![]() i did similar on my truk, bolted the rails down before the bedwood i used a router to cut the bolt head recess, cuz i had it handy nice thing about this method is you can bolt down 1x4 on the ends of the rails and set your bed on for modifying it
#41 |
Moderator
I AM ON THE WRONG FORUM!
![]() How did I get on this year/series forum? I apologize for my answers should they lead you astray. ![]()
#42 |
your ok, same bed, fenders and steps 55-66
#43 |
the original request asked about equal widths, If you did make them all equal widths, wouldn't you have problems lining up the top strips that hold the wood down? I'm a fan of the original design so I stayed with that. I bought all my wood at the local home depot, took longer to find good straight boards than it did to finish them. Used my router to run along each edge to get the right depth for each strip.
![]() 1940 Ford Dlx Coupe 1969 Mach1 Last edited by my56chevytruck; 11-06-2018 at 07:40 PM. |
#44 |
ditto!!
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#45 |
![]() Join Date: May 2007
I have done a few, some with a steel bed floor under and some with just crossbars like the original. my advice is not to worry about the exact profile of the wood as original, you might be able to find a special bit that has that profile but recently I have just been doing it with a rabbiting bit and there havent been any consequences except that it used to take a couple hours on a table saw (no dado) to cut the J profile and I can do all the boards in about 10 minutes with the router and rabbit bit.
![]() ![]() ![]() ![]() I even did a 65, so you dont feel out of place, rocknrod! ![]()
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 11-06-2018 at 08:05 PM. |
#46 | ||
![]() Quote:
#47 |
White oak is a closed grain wood. If you make a barrel out of red oak it will leak. If you have a local saw mill get it there. By making your own you have many more options. Also if you have the time tung oil is a good choice. Tung oil is a drying oil but it takes some time. It is an awesome finish that goes back 3000 years. It's a in the wood finish and not on the wood so can't peel or chip. Also quarter sawn lumber is much more stable. Again get it from you local saw mill. You will also want to straight line saw it. Get it close and use an 8' level or some other straight edge and do one edge and then you can table saw the other edge. Don't try to take too much when you straight line it or it can move on you again. Hope this helps.
#48 |
The ones that fall into mouth or ear not too bad. Bouncing parts off my "brand new" eyeballs - nooo!
