Old 06-25-2011, 10:35 AM   #26
bubba327
HOW long until spring??
bubba327's Avatar
Re: Rods 57
Is the "the local guy from Idaho " that does the front clip over in Kuna??
I talked to somebody at a swap meet a while back about it and that looked like it works really well.
My uncle is getting ready to combine a '58 3/4 ton cab to a '56 1/2 ton frame with a '57 box.
He had plans to go rack and pinion , but has found a Camero Z-28 front clip on CL so is now going that route.
I still have 77 nova front clip, that I was told, would work also.
If anybody local wants it , My wife would be excited to see it leave the premises
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 06-25-2011, 12:47 PM   #27
Rods57
Rods57's Avatar
Re: Rods 57
Yes he is in Kuna, his name is Jay Young and he has adds on CL for the clips.
Rods57 is offline   Reply With Quote
Old 06-26-2011, 01:41 AM   #28
OrrieG
OrrieG's Avatar
Re: Rods 57
Jay is a good guy, I've gotten parts from him over the years.
OrrieG is offline   Reply With Quote
Old 06-26-2011, 02:13 AM   #29
BC Toy chest
BC Toy chest's Avatar
Re: Rods 57
Awesome job can't wait to see her when she's done.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 06-26-2011, 12:24 PM   #30
Rods57
Rods57's Avatar
Re: Rods 57
Thanks, here are some pics of the first fitting of the cab.
Old 06-26-2011, 12:26 PM   #31
Rods57
Rods57's Avatar
Re: Rods 57
Originally Posted by hammerdog57 View Post
Very nice build. My camaro clip install is close to yours. How much clearance do you have from distributor to firewall? I see you used the stock motor mounts, which i plan on using if i can. Keep the pics coming.
Here is a close up of the motor mounts you can still see one of the original holes.
Old 06-26-2011, 05:41 PM   #32
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Rods 57
Sweet looking build! The clip install looks very similiar to the way mine was done. Keep the updates coming!!
ChuckDriver is offline   Reply With Quote
Old 06-26-2011, 07:58 PM   #33
hammerdog57
hammerdog57's Avatar
Re: Rods 57
Attachment 766172
Thanks for pic.
hammerdog57 is offline   Reply With Quote
Old 06-26-2011, 10:30 PM   #34
kgmunro
Re: Rods 57
I'd swear in the one pic with you sitting in the cab I can hear you making engine noises!
kgmunro is offline   Reply With Quote
Old 06-27-2011, 12:44 AM   #35
OrrieG
OrrieG's Avatar
Re: Rods 57
I have that same pic of me sitting in my cab when I got the seats in for a trial fit. I think everyone has it.
Old 06-27-2011, 01:53 AM   #36
Rods57
Rods57's Avatar
Re: Rods 57
Ha Ha thats funny. i am probably singing fat man in a little truck...
Old 06-30-2011, 12:24 AM   #37
Rods57
Rods57's Avatar
Re: Rods 57
Here are the pics of the cab after the first fit of the fenders, doors and core support
Old 06-30-2011, 02:33 AM   #38
longbike
longbike's Avatar
Re: Rods 57
Man that looks great!
longbike is offline   Reply With Quote
Old 06-30-2011, 04:19 PM   #39
Kim57
Kim57's Avatar
Re: Rods 57
Looking good.
Kim
Kim57 is offline   Reply With Quote
Old 06-30-2011, 05:48 PM   #40
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Rods 57
Looking great, keep up the good work.
Kabwe is offline   Reply With Quote
Old 06-30-2011, 07:25 PM   #41
Rods57
Rods57's Avatar
Re: Rods 57
I decided to use a firewall mounted master cylinder so I used the stock brake pedal mount out of the same 78 camero in the truck. here are the mount holes.Name:  close brake.JPG
I didn't like it.....so I made some mods to the firewall, cut and drilled the studs so the bolts would reverse and look better and got a different booster that is smaller and fits nicer. I had to move the hole for the booster down and I cut out part of one of the ribs and made the end look different.
Old 06-30-2011, 09:44 PM   #42
ChuckDriver
Re: Rods 57
Looking good!
Old 07-01-2011, 05:49 PM   #43
Rods57
Rods57's Avatar
Re: Rods 57
So at some point this cab was laid on its back, hard and it tweaked it. in order to get the doors to close I used a small bottle jack in the door frames. It split the drip rails and i had to fix-um, but I didn't like the way they curved in do I made them straighter than original.
Old 07-01-2011, 08:13 PM   #44
Kim57
Kim57's Avatar
Re: Rods 57
Interesting. I got rid of mine and don't remembering them curving in.
Kim
Old 07-01-2011, 08:31 PM   #45
hammerdog57
Re: Rods 57
Interested in how you jacked the cab back into place. How was door aligned prior to jacking? And from what point on cab did you push from?
Old 07-01-2011, 08:56 PM   #46
Rods57
Rods57's Avatar
Re: Rods 57
I used the point where the striker plate bolts on for one end and the front post for the other point. I needed to move it about 1/2 inch to get the door to close.
Old 07-01-2011, 09:00 PM   #47
Rods57
Rods57's Avatar
Re: Rods 57
Kim
here is a pic of the drip rail before, I blew it up sorry for the quality.
Old 07-01-2011, 09:03 PM   #48
Rods57
Rods57's Avatar
Re: Rods 57
This was the worst side and this is right after i got the door to close for the first time.
Old 07-03-2011, 12:27 AM   #49
Rods57
Rods57's Avatar
Re: Rods 57
Did some painting on the underside and behind the fenders, used bed-liner first then painted it.
when i put in the cab corners i added some bracing to make it stronger.
Old 07-03-2011, 12:06 PM   #50
Kim57
Kim57's Avatar
Re: Rods 57
That looks good Rod. I like the idea of the bracing on the corners.
Kim
