Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-07-2011, 09:39 AM   #26
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Big Block Monster Stroker
Well, why a 555? Why not just buy a crate 572? Or built 502? Both have good hp for under $15K.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 07-07-2011, 09:45 AM   #27
djracer
djracer's Avatar
Big inch Big Block Chevy motors are easier on parts and cheaper to maintain. I will argue all day that small blocks are great for the street and big blocks are for the track. You can buy parts for a big block off the shelf where the faster small blocks usually have allot of custom pieces. I ran my stock block, stock crank 468 forever before I finally killed it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-07-2011, 09:47 AM   #28
thirdstreettito
Resident of Here
Ah ok, that sums it up, gracias!
~Bradley~
Miss having a truck
Old 07-07-2011, 05:32 PM   #29
1971ls1longbed
1971ls1longbed's Avatar
Originally Posted by thirdstreettito View Post
I have a question, why do you want to go 555? Why not add a turbo or supercharger to make good power?
As much fun as turbo or SC is the added cost of upgrading my fuel system, getting a turbo and all the accessories, changing the exhaust, and so on is the same as building a big motor and there is less to go wrong
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 07-07-2011, 06:25 PM   #30
ripdog28
ripdog28's Avatar
A 555+ with some 335 AFR cnc heads or better can make over 800hp pump gas....... Figure $4500+ for shortblock, $3300+ for heads, $1000 roller cam, $8800 thus far so say close to $10k (Depending on reusable parts) for 800 is sick. This is if you assemble of course. About $13000+ if not. A base turbo engine that will last and makes this power is easily $15000 and requires much more tuning and for this $$ figure it is done cheaply. Most quality Turbo builds i have seen are easily $23000-$30000+. I cringe when i think that I just put 10k into my yard and i think, Man i could have had some CNC afr heads, 540+ci, roller cam....
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 07-08-2011, 09:31 PM   #31
PGSigns
PGSigns's Avatar
Don't forget the cost of everything to make all that power work. For a driver motor you need to look into how much power you drive train can hold and just build to that. My 555 made 908hp and 760tq and I would never put something like that in a truck that is street driven, because if you are worried about the cost of the motor wait till you see what the cost of putting a truck together is to hold a pump gas 598.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-08-2011, 10:46 PM   #32
70shortwide
i am the guy the board member that told the op that. i had a 555 built with a 427 tall deck block. no filler material was put in i drove it on the street all the time and it was pump gas. i had a 4.750 stroke crank. i believe the rods were 6.535 made by oliver. pistons were srp off the shelf. and i had a set of 1000 dollar pro comp heads. all solid roller. truck went 11.20's at 115 and weighed about 3950 with me in it. cost of building a tall deck is not more expensive. there are quite a few motors like this one around town that work great. i would suggest a vaccuum pump. and most people like me dont have 10 grand to spend on a crate motor so we have to cash flow it even if the end result is the same price. not tryin to offend anybody so please dont take it like that im just giving my experience with the same motor hes talking about.
70shortwide is offline   Reply With Quote
Old 07-09-2011, 08:00 AM   #33
djracer
djracer's Avatar
I totally understand it being easier to buy a few pieces at a time than to buy one built. Personally I would do a pump gas 496 in a standard 454 block or buy an aftermarket block. A friend of mine built a pump gas 496 with patriot heads that went 6.30's in the eighth in a fairly heavy car. In the 496 build he used a later model 454 block and did very little clearancing to clear a 4.25 stroke with steel rods.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-10-2011, 06:23 PM   #34
1971ls1longbed
Not to piss on anyones parade but i talked to my engine builder, who has been in business for over 35 years and is a very competitive racer at englishtown nj, atco nj, and cecil county md, has confirmed that a 555 using a tall 427 and a 4.750 crank is nothing new and when done with a cnc machine is totally fine for street use. So i will be starting the engine that will power a true street brawler later to come.
Old 07-11-2011, 10:00 AM   #35
pockets
pockets's Avatar
You wouldn't happen to recall where you got your crank or what brand it was do you?
Project Bad Karma
pockets is offline   Reply With Quote
Old 07-11-2011, 02:31 PM   #36
El Campo
El Campo's Avatar
I have a 535 (or thereabouts) BBC that is made by a 4.5 inch stroke and a 427T block .100 over. Street driven but I beat it hard on the track sometime too. Got the whole block and rotating assembly from Competition Products in Osh Kosh, Wisconsin. The block sonic tested, decked, bored, polished, honed and clearanced went for $1250. And the good thing about this is that they have it figured out how to use dime a dozen 454 pistons with longer rods so that you dont have to get custom pistons. Got JE pistons in mine that I think cost only about 400 something dollars. Have had no problems with it. Only bad thing with getting stroke this long is that HP and torque start to fall off fast. After about 5000 though it starts to fall off fast and I imagine that it would be "worse" with that longer stroke.. Don't get me wrong, I LOVE cubic inches and would def put the bigger stroke in one if it would fit. I just personally would not wind it to the moon for obvious reasons. These engines are AWESOME on the street though and it feels like you are driving a rocket (esp at stop lights against imports) If you have never checked out CP you should, they get a lot of factory blems too from Dart, Merlin, etc that they sell dirt cheap sometimes. I have always been a Summit man but CP is damn good. Bottom line is ANYTHING over 500 CI is kick ass to drive
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-11-2011, 03:19 PM   #37
Marv D
Registered Truck Offender
Marv D's Avatar
Mine makes 518 HP/666lb ft of T at 1500 RPMs (this was the lowest RPM reading the dyno took)
not trying to start any or anything but,,, ummm there is DEFINATELY a typo in there ElCampo,, 666 pounds of torque at 1500rpm is only 190.2HP
and 598 pounds at 5100 is 580hP,, something is amiss with the numbers there.
TQ and HP are identical at 5252rpm
The formula is simply (torque x rpm) / 5252 = HP,, there ain't no other way to do it.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-11-2011, 03:21 PM   #38
pockets
pockets's Avatar
just a guess, but maybe the hp quoted was max and the torque was at 1500. that extra "/" maybe be confusing us readers (?).
Project Bad Karma
Old 07-12-2011, 08:42 AM   #39
70shortwide
i think it had a callies crank. but i cant remember for sure
Old 07-12-2011, 10:42 AM   #40
El Campo
El Campo's Avatar
The jokes on me!!! I could have swore that's what the dyno sheet read. I guess that's what I get for not doing my homework. All I know tho Is that regardless of all my ignorance in the HP/T curves and how to read dyno sheets it's fast as hell!! Effortlessly blows those big tires off at 50mph
Hook em Horns!!!
Old 07-12-2011, 10:56 AM   #41
pockets
pockets's Avatar
and in the end, that is probably all that matters
Project Bad Karma
Old 07-12-2011, 11:12 AM   #42
El Campo
El Campo's Avatar
I don't mean to jack this thread so I'm going to start a new thread about HP/T and I would appreciate the experts to check it out and comment. Thanks!
Hook em Horns!!!
Old 07-12-2011, 06:18 PM   #43
ripdog28
ripdog28's Avatar
71LS1: Just a little insight. Im sure the eng builder is more then capable but if your spending $1500 for the block and all the work, the $300 extra will reveal more power. 555ci=555ci however, the larger bore allows the valves to breath better which makes more power. It also allows for a better Con rod/stroke ratio which will help you RPM and is not such a wear on the parts. That extra 1/4 in stroke means faster piston speed and more chance for a problem. Piston speed is very important if racing. I know it is your choice but just if you did not know.
69 c-10 BBC
Old 07-12-2011, 08:53 PM   #44
1971ls1longbed
Well i called today and he is giving me the 427T for free and is only charging me $500 to cnc the block. I do appreciate everyones advice and concerns. You do bring up some valid points that i have taken up with him. but like i said this engine is going into a pure street drive brawler that will see track time but only for bragging rights.
Old 07-12-2011, 09:28 PM   #45
ripdog28
ripdog28's Avatar
Well for that price I would take it also.
69 c-10 BBC
Old 07-12-2011, 10:21 PM   #46
1971ls1longbed
I do always try to get what i need on the cheap. I love these trucks and everything that goes with them, but i do feel that b/c of the economy and constantly rising prices it makes it harder for your average working class guy to afford to build one of these and that is a damn shame. So as this motor goes together i will keep a tally of costs and where i got the stuff from to give hope to those of use who work like slobs just to buy a few parts
Old 07-16-2011, 10:15 PM   #47
nomrlz
nomrlz's Avatar
and here i was gonna suggest just getting a 1005ci sonny motor. they're cheap right now at $125K
but seriously. i love the 555's if you have the money
nomrlz is offline   Reply With Quote
Old 07-17-2011, 09:41 AM   #48
AirMale
AirMale's Avatar
Smile Re: Big Block Monster Stroker
just down the road from u longbed, hit me up if u need anything
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 07-18-2011, 04:29 PM   #49
1971ls1longbed
yea u know anyone that does body work
Old 07-18-2011, 07:26 PM   #50
AirMale
AirMale's Avatar
I know a guy who does amazing body work but doesn't do the paint if that helps.
86 SWB 9.0 LITER
