09-20-2011, 04:08 PM | #26 |
Re: Sacto67 Build diary
Well we started with the cab by serving any of the creatures left over from the move with an eviction notice. I emptied the old bad gas from the fuel tank. Is there anything else I should do to the tank before reinstalling it?
1968 Chevy SWB stepside original USAF truck http://67-72chevytrucks.com/vboard/s...d.php?t=483462 |
09-20-2011, 06:21 PM | #27 |
Grandpa in the rustmobile...
Clean wash rust preventative work maybe wax the area back there re install
if its a solid truck you might drill some holes back there somewhere (cab corner areas for water to drain?) Looks great!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-24-2011, 08:39 PM | #28 |
Okay where can I get one of these without paying $37? It along with the stud it self is missing. For that price I'll just build one.
Carb air cleaner stud bracket. http://cgi.ebay.com/ebaymotors/68-72...m=380318462797
09-25-2011, 05:14 PM | #29 |
Okay so I'm reading up on subframe swaps and column swaps. I would like to buy a complete truck or van I could pull the engine, trany, front suspension, power steering/brakes, and column from to swap into my truck.
From what I've read the 73-87 (88 and 89 burbs too) subframes are interchangable with slight modifications. This would get me front disc. Are the rear ends interchangable too? If I do the disc upgrade I'd have to change out the rear axle to make it a 5 lug. As far as the steering column swap it sounds like up to 81 columns are the way to go. So here is my question......are the 73-81 van subframes interchangable? There is a running 77 van with an auto and V8 local for $600. I don't have the budget right now to go crazy on the truck but I would like to get it safer to drive with power steering/brakes and an auto for the wife. Thanks
10-04-2011, 12:25 PM | #30 |
It runs but it will not take throttle. It will idle for no more than about 2 minutes before it just dies. If I add throttle slowly I can get the rpm’s up but then it will just quit. Sometime with a little backfire/popping through the carb. I can keep it running when it tries to die at idle by spraying carb cleaner so I’m pretty sure the carb is the issue and not my timing, compression, or spark. I’ve never worked on these 1bbl carbs and this kind of stuff isn’t my cup of tea. It only has one adjustment screw for idle. I’ve already rebuilt the carb which seemed to have gone fine. Any help please.
The seat is back in and the bed is stripped of the old rotted wood.
10-04-2011, 12:33 PM | #31 |
VA72C10
Sounds like either the accelerator pump or something to do with timing?
carb backfire leads me to believe timing as it'll idle...maybe it's off a tooth?
Looking for a 67-72 swb or blazer project in or around VA. |
10-13-2011, 12:59 PM | #32 |
Too funny, great looking ride, have fun.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
10-17-2011, 01:39 AM | #33 |
Well I guess I'm about out of options for trying to narrow it down without spending the bucks for a new carb. I replaced the fuel pump tonight and it does the same thing. So I've waisted about $100 now trying to get this thing running.
I really don't want to spend another $100 on a carb when I'm just going to pull it and throw in a 350. Problem is I really needed it running this week since the fam will be down another car as of Tuesday. SIGH
10-17-2011, 08:23 AM | #34 |
Did you check the timing, if its retarded it will run poorly. Not sure if you have one on there but look at the egr valve, see if its opening at idle or stuck open.
10-17-2011, 11:11 AM | #35 |
Yup, I checked the timing already. I'm pretty sure I don't have an EGF valve.
10-17-2011, 03:33 PM | #36 |
fat old dude
egr is emissions pump
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
10-17-2011, 11:46 PM | #37 |
Might try checking for a restricted exhaust pipe/muffler
Posted via Mobile Device |
10-19-2011, 08:38 PM | #38 |
Well I just bought the subframe disc to disc, rearend, and rollers from this for my project.
84 Suburban with drop spindles. I also picked up some seats from a 2004 Silverado.
1968 Chevy SWB stepside original USAF truck http://67-72chevytrucks.com/vboard/s...d.php?t=483462 Last edited by sacto67; 10-19-2011 at 08:58 PM. |
10-20-2011, 02:43 PM | #39 |
Your accelerator pump is dried out. Backfires are usually from either lean conditions or serious timing issues. Chevy sixes have gears on the cam and crank instead of a chain. They can and do go bad, but the design makes it difficult for them to jump a tooth.
Rebuild kits are about 14 dollars. The average guy can do the job with a little patience. THey are simple carbs. Best of luck. |
10-20-2011, 03:03 PM | #40 |
Pic of my six. Everyone stops and stares
10-20-2011, 03:20 PM | #41 | |
10-20-2011, 05:33 PM | #42 |
Accelerator pump is internal to the carb. It squirts gas into the venturi area when you mash on the gas. The extra gas is necessary as to give the fuel mixture enough fuel over air to keep the engine from stalling.
I know this is basic, but did you remove the brass inlet (place where you attach the fuel line?). This contains a filter, either stone or paper, that can be clogged. The carb may not getting enough fuel to run other than on the idle circuit. |
10-20-2011, 07:20 PM | #43 |
Got it, I looked up accelerator pump and saw the part. That was replaced when I did the carb rebuild (was included in the kit). I replaced the fuel filter inside of the carb also when I rebuilt it.
10-20-2011, 07:40 PM | #44 |
Anyone know if my 3 on the tree will bolt up to a 96 LT1? I've read it will mate with a SB 350. Thanks
10-21-2011, 03:36 PM | #45 |
Disregard the last post, on a side note there is a 96 LT1 in Sacramento, already set up for a stand alone application (dude has it in his 74 C10) for $800 complete with motor mounts headers new optispark, more.
What year 1bbl carbs will work on my 68 292? I've found more 75-79 carbs more then anything else.
11-03-2011, 09:56 PM | #46 |
Where is the best plae to get a 1.25" hub/rotor for the 73-87 spindles with a six lug patter? Is there a vehicle these came on or is this a specialty part? So far I've only been able to find them from vendors who sell disc upgrades. Thanks
11-20-2011, 03:41 PM | #47 |
Well I got another carb for my truck. I haven't had time yet to rebuild it but I installed it and it ran the same way. Same problem with not running past idle. Any suggestions? Thanks
11-20-2011, 04:53 PM | #48 |
accel pump is very easy to check. With the engine off, look down the throat/barrel of the carb and pull the throttle; if you can see a visible squirt of fuel, you're good. If not, your pump is bad or the orifices are covered/plugged.
When you start the engine... do you have to pump the gas? Does it start easier if you pump the gas once or twice? Or more?... that's also your accel pump at work. |
11-20-2011, 10:27 PM | #49 |
I'll check that. Thanks. I don't have to pump it to start.
12-09-2011, 03:46 PM | #50 |
So I bought a new HEI dist., new plugs, and wires.........still has the same problem. Here is a video in case it helps.
Sigh, I'm about DONE with this POS 292! The whole truck almost too just because of it! Please help!
1968 Chevy SWB stepside original USAF truck http://67-72chevytrucks.com/vboard/s...d.php?t=483462 Last edited by sacto67; 12-09-2011 at 03:54 PM. |
