Old 07-17-2013, 04:06 PM   #26
QBA
Proud Americano
Re: Manual Air Ride Valves!
hey Dloe
wanting to get a couple of these.I'm local to you.
can I get these from you or would you want to ship.
please let me know.
thanks
Tattooed Cuban Trailer Trash.
putting the cart before the horse since 1964.
QBA is offline   Reply With Quote
Old 08-17-2013, 12:13 PM   #27
pedro6371
hi dloe I bought your valves a while back they work great so I need 2 more sets please contact me back thanks.
pedro6371 is offline   Reply With Quote
Old 03-07-2014, 12:57 PM   #28
UncleMatt
Hi DlOE,
Your valves look exactly like what I need. I want to order 4 of them with fittings. I sent an email to the address on your website but didn't hear back yet. How do I place an order? Thanks!
UncleMatt is offline   Reply With Quote
Old 10-14-2014, 06:51 PM   #29
zipper
I plan on running these valves w/ a porterbuilt stage 1 front and stage 2 rear kit. However, in terms of compressor, tank, what size line, fittings, etc I do not exactly know everything I need. If somebody could list ALL the parts needed, even the individual fittings I would really really appreciate. Thank You!
zipper is offline   Reply With Quote
Old 10-12-2015, 09:11 AM   #30
jondancer
Any way you could pair these with a couple gauges and sell me a complete set of 4 valves and two gauges plumbed together?
jondancer is offline   Reply With Quote
Old 10-29-2015, 05:09 PM   #31
lsjrl07
lsjrl07's Avatar
Are these still available?
lsjrl07 is offline   Reply With Quote
Old 03-28-2016, 05:22 PM   #32
inkfamous13
How much would it be for complete switch panel exactly like this all together ready to hook up lines?
inkfamous13 is offline   Reply With Quote
Old 04-04-2016, 05:48 PM   #33
jondancer
Got mine mocked up today . They are awesome .
Old 04-19-2016, 09:35 PM   #34
jondancer
Does it matter which hole on the side you use for inlet outlet as along as they all mount the same?
Old 04-22-2016, 08:34 PM   #35
hotrodsinner
hotrodsinner's Avatar
Doesn't matter, long as they are all routed the same.
hotrodsinner is offline   Reply With Quote
Old 04-22-2016, 08:35 PM   #36
hotrodsinner
Looks good!
Old 06-10-2016, 12:43 PM   #37
C1ph3r
hey dloe65. i am planning my air ride out and if i go manual i want to use your valves. probably get it all from you, valves, gauge mount, fittings and so on.
i have a couple questions. i see you have a screw in muffler. can an air line be ut in there and the exhaust ran outside the cab?
also, do you have a fitting to run one supply per pair of switches so i dont need to run 4 supplies in and 4 out to the bags?
last, can you get me a quote for everything i need plus shipping to 28027? we can discuss in PM if you would prefer.
1970 C-10 LWB Build Thread
C1ph3r is offline   Reply With Quote
Old 06-10-2016, 12:46 PM   #38
C1ph3r
how easy is it to operate so you get a smooth motion from both sides of the front/rear at once? I like how you have these mounted but not never having operated air ride before, not sure is what I am wanting is possible. basically i dont want to have to lower/raise each corner individually if i can avoid it. so if these valves are as smooth as i am thinking they will be, operating 2 valves at once should be pretty smooth.
Old 04-20-2017, 01:06 AM   #39
staydubbin
Does Dloe make these? can these be purchased anywhere else? not trying to build/sell my own. just out of curiosity
staydubbin is offline   Reply With Quote
