Old 07-16-2012, 01:55 PM   #26
67cheby
67cheby
67cheby's Avatar
Re: Project: Rufus Restoration
Great progress !!
67cheby is offline   Reply With Quote
Old 07-16-2012, 02:03 PM   #27
shearjs
shearjs's Avatar
At least one pic for finally making it to the 2nd page...
shearjs is offline   Reply With Quote
Old 07-16-2012, 02:07 PM   #28
shearjs
shearjs's Avatar
Originally Posted by bigguy69 View Post
looking good
Thanks!
Originally Posted by 67cheby View Post
Great progress !!
Thanks 67cheby. Can't wait to see some paint on that cab of yours!
Old 07-16-2012, 03:10 PM   #29
Tinkermc
I don't want 2 sound like a know it all but in pic 7 the spring on the right looks to be a bit short, looks a lot like the new ones I just got and all 4 of mine are 2 short. can't wait 2 see how they look. Your truck is looking good and I like the color
Tinkermc is offline   Reply With Quote
Old 07-16-2012, 04:50 PM   #30
shearjs
shearjs's Avatar
I'm assuming that you're referencing post 7 where the 2 springs are sitting side by side on the rear trailing arm. The spring on the left is the stock spring that came on the truck and the spring on the right is a 6" drop spring that came with my ECE 4/6 drop kit. It really helped the looks of things, but I can not attest to how they feel on the road yet. Some day....some day. Thanks for checking things out. I always appreciate some feedback.
Old 07-17-2012, 12:10 AM   #31
mcmlxix
Collector of Projects
mcmlxix's Avatar
Originally Posted by shearjs View Post
How is the hood clearance? I have the same setup with CaptainFabs bracket and a 2005 GMC hydroboost / MC combo.....
Also, what are you doing for a proportioining valve/block? I picked up a Wilwood adjustable piece because I swapped to rear disc brakes. That MC uses a 7/16x24 fitting and most are 3/8x24.
Rich
1972 K5 Blazer CST Click HERE
Old 07-17-2012, 08:29 AM   #32
shearjs
shearjs's Avatar
With the hood latched, there's enough room to stick the tip of your fingers between the fill spout on the MC and the bottom of the hood, so I'd guess maybe 3/8"-1/2" clearance. I'm going to keep the 04 MC for now but I've been considering changing to a more period correct MC for the hydroboost. I haven't decided what to do with a proportioning valve yet, but was considering the Wilwood adjustable that you used. Thanks for the heads up on the fittings. I was unsure of the size. What did you do for your hoses?
Old 07-17-2012, 09:17 AM   #33
mcmlxix
mcmlxix's Avatar
www.Kore3.com makes a really nice braided hose that I'll be using. I was thinking that I will probably run them from the proportioning valave to the frame as well to replace the coils in the hard line. It would absorb any amount of chassis flex and look cleaner. Still trying to figure out the specifics. AutoZone had a 3/16 hard line with the correct end on each side to go from the MC to the Wilwood valve....
Here is a link to some good brake tech ....CLICK HERE
Rich
Old 07-17-2012, 11:25 AM   #34
shearjs
shearjs's Avatar
Kore3 makes some nice stuff. Did you make your own pressure hoses to run from your ps pump to hb to steering box? I was able to use the stock hoses but plan on taking the hose from the hb to the steering gear to a shop to have a different fitting put on to fit the steering box inlet. Thanks for the brake tech link...good stuff there.
Old 07-17-2012, 05:13 PM   #35
mcmlxix
mcmlxix's Avatar
My power steering hoses were hacked off. I ended up buying -6 AN fitting for the HB and steering box. I'll have a local hose place make some AN hoses when I get to that point....
Rich
Old 07-25-2012, 08:45 AM   #36
shearjs
shearjs's Avatar
No real progress lately, as things have been a little hectic. However, my soon to be grandmother-in-law, has temporarily handed me the keys to her 54 F*rd truck to cruise around in for our upcoming wedding. I know it's not a Chevy, but it does give me some motivation to get kicking on my own project and get it back on the road. Plus, anytime you can put some miles on a classic, it's a good day.
Old 07-25-2012, 09:54 AM   #37
True 67
Sweet...just keep the small projects going and eventually it will be done....
True
True 67 is offline   Reply With Quote
Old 07-26-2012, 01:21 PM   #38
shearjs
shearjs's Avatar
True
Thanks! Still plugging away at it. Thanks for checking in.
Old 07-26-2012, 02:53 PM   #39
Tinkermc
nice lookin F*rd. May not be a GMC but I think I would drive it anyway, once in a while
Old 07-26-2012, 10:21 PM   #40
tsali39
tsali39's Avatar
Like your project. Four eyes rule!
Eddie
tsali39 is offline   Reply With Quote
Old 07-27-2012, 12:16 AM   #41
VA72C10
VA72C10
VA72C10's Avatar
Great looking project!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-27-2012, 06:45 AM   #42
missinfishin10
Amazed Member
missinfishin10's Avatar
Looks Great, I'm subscribed...
71 LWB Fleetside
1950 3100 Original Project!
missinfishin10 is offline   Reply With Quote
Old 08-01-2012, 03:49 PM   #43
shearjs
shearjs's Avatar
Not too bad for an old heap. It's fun to get out and beat around in.
Thanks!
Thanks!
Thanks! I'm hoping for more frequent updates in the next few weeks.
Old 09-24-2012, 01:01 PM   #44
shearjs
shearjs's Avatar
So it's been ages since I've posted any real progress. This past week I've dove head first back into my LS engine wiring harness. With any luck, I hope to have it wrapped up by the end of the week, and ready for a test fit on Saturday. I'll post some pictures soon.
Old 09-24-2012, 10:04 PM   #45
Rusbuilt
Rusbuilt's Avatar
Man your project is looking great! We will be having a swap meet in Nashville soon if you would like to come.. here is the link for the info..
http://67-72chevytrucks.com/vboard/s...d.php?t=541395
Rusbuilt is offline   Reply With Quote
Old 09-25-2012, 04:35 PM   #46
shearjs
shearjs's Avatar
Thanks man! I appreciate the feedback. A swap meet in Nashville sounds like a great idea. Always good to meet some local truck fellas. I'll check the schedule to see if I can make it. Thanks again for the invite.
Old 09-25-2012, 09:02 PM   #47
Rusbuilt
Rusbuilt's Avatar
Yes sir! Hope you can make it!
Old 10-01-2012, 07:57 PM   #48
shearjs
shearjs's Avatar
Update!
I've finally been able to squeeze in a little time with the old girl again. The past week or so I've been back into the wiring. I have my wires ready to start creating a fuse box, and recently laid them out on an old 5.3 I have lying around to see how things are going to fit. Unfortunately I forgot to snap a picture of that.
Also had a chance to stick on new calipers and pads and mount some new tabs for the brake hoses.
And finally, I followed along with Hart_Rod's mounting of the gas pedal and created a bracket to mount it up. My brake pedal needs to be bent over slightly, but I think it fits under there pretty well.
Old 10-01-2012, 08:13 PM   #49
slosteve
Is that a 'drive by wire' throttle assembly?
slosteve is offline   Reply With Quote
Old 10-02-2012, 03:20 AM   #50
mcmlxix
mcmlxix's Avatar
Yes. look close and yo uwill see the connector on top... This looks like where mine will be as well....
Rich
