Old 07-22-2012, 12:19 PM   #26
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Recommended headers (ls) for dropmember 67-72??
Do the Pacesetters have o2 sensor bungs welded in already?
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 07-22-2012, 08:49 PM   #27
paul66c10
paul66c10's Avatar
i believe they do but not 100% sure
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy
paul66c10 is offline   Reply With Quote
Old 07-23-2012, 12:30 AM   #28
gringoloco
A guy with a truck
gringoloco's Avatar
They do. Aimed towards the inside, unlike the Kooks.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-23-2012, 11:37 AM   #29
paul66c10
paul66c10's Avatar
placed my order today for the pacecetter trailblazer ss headers will get them on and snap some pics when i get them in. (crossing fingers they work) lol
Old 07-23-2012, 09:34 PM   #30
jtp67-72
jtp67-72's Avatar
I'll wait to see yours..would love to see a good closeup of each header loose....thanx jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 07-23-2012, 11:50 PM   #31
gringoloco
A guy with a truck
gringoloco's Avatar
There's a few pics of the Pacesetter TBSS headers both loose and on the engine stand in my engine 'build thread' here in the LSX forum. Not in the truck yet though...
-Chris
Old 07-24-2012, 07:45 PM   #32
jtp67-72
jtp67-72's Avatar
the 70 or the 72 blazer
Old 07-25-2012, 11:27 PM   #33
paul66c10
paul66c10's Avatar
got the tbss pacesetters in and put on tonite, pass side is good clears everything, driver side clears the control arm, it contacts the bottom edge of the frame a tad by the collector. the steering linkage might have issues, might have to modify a tube to clear.
Old 07-26-2012, 12:03 AM   #34
gringoloco
A guy with a truck
gringoloco's Avatar
I have a 6.0 slated for install in my '70- the Blazer is sold... The thread in the LSX forum is named 70 C10 LQ4.
Paul66: Do you have a close up of the collector hitting? How's the ground clearance?
-Chris
Old 07-26-2012, 10:08 AM   #35
paul66c10
paul66c10's Avatar
ill try to snap a pic tonite and ground clearance was good i think i'll check and snap a pic of that also.
Old 07-27-2012, 12:12 AM   #36
jtp67-72
jtp67-72's Avatar
Yeah Paul...before I order the coated set ...need to get a flange to bottom of collector measurement...don't want to hang below frame with this extreme d.m. thanx jim
Old 07-27-2012, 08:36 AM   #37
paul66c10
paul66c10's Avatar
no problem, i got tied up yesterday ill get some pics after work today. the steering linkage might work if you had a 3 joint set up i think im just gonna get the one header tube modified then send them out to get coated.
Old 07-27-2012, 06:25 PM   #38
jtp67-72
jtp67-72's Avatar
Without the cab on can U see the problem already?....That may throw me a loop...will take pic of mine this evening and we will compare notes.....jim
Old 07-28-2012, 10:09 PM   #39
jtp67-72
jtp67-72's Avatar
Here is a pic of how close cab is..............jim
Old 07-29-2012, 07:31 PM   #40
paul66c10
paul66c10's Avatar
finally got some more pics sorry for the delay
clearance pics couple of where the driver side hits the bottom of the frame
how they tuck under the frame, definately enough ground clearance
driver side
pass side
hope it helps some. looking at your firewall picture i think im still going to just have my one header tube modifed. Ill know more when i get my cab back on the truck. Im going to stick with these headers cause i like how they tuck under the truck and clear the control arms. After i get the one tube modified i'll send the headers out to get coated.
Old 07-29-2012, 07:50 PM   #41
jtp67-72
jtp67-72's Avatar
I'm like U....frame hickey is easy fix...looks like #1 tube could turn up and rearward and then reweld????
Old 07-29-2012, 10:03 PM   #42
paul66c10
paul66c10's Avatar
i was gonna get #1 tube cut and rerun to follow along the bottom of #2 tube then back into where it is bent.
Old 09-25-2012, 08:15 PM   #43
dkauffman05
dkauffman05's Avatar
I don't have a dropmember in the truck i am doing but it looks like these might work on a non dropmember truck i hope. What you guys think?
dkauffman05 is offline   Reply With Quote
Old 09-26-2012, 09:12 AM   #44
paul66c10
paul66c10's Avatar
i think they would work in your application with no issues the headers seem to be pretty far back away from the stock crossmember.
Old 09-26-2012, 06:43 PM   #45
dkauffman05
Whst are you going to use for the collector connection?
Old 06-15-2016, 04:58 PM   #46
Parishchief1
Parishchief1's Avatar
I'm running a pb mild dropmember with a 5.3, and I'm liking the firmest of those tbss headers. So to make the steering linkage to work a pipe would defiantly have to be modified?
67' C-10 PBFAB suspension,Accuair, Baer Pro+ 14" big brake kit F&R, Narrowed moser 12 bolt,Boyd Slayer 24x9's & 24x15's. 405 GANG500HP Ls "Da Green Beast"
Parishchief1 is offline   Reply With Quote
