Old 03-21-2012, 12:52 PM   #26
Indyuke
Re: $1800 and a weekend later.......
What?! All that work and no front eq bar?
Indyuke is offline   Reply With Quote
Old 03-21-2012, 07:57 PM   #27
Rob68c10
Originally Posted by Street3285 View Post
Sweet. The best part is driving it afterwards and feeling the major difference!
I still have to finish the power brake conversion, but I can not WAIT to run this thing down the road!
Originally Posted by duallyjams View Post
Nice upgrade.
Check out the Md forum http://67-72chevytrucks.com/vboard/s...d.php?t=510952
Thanks man! I will def check that out.
Originally Posted by doubleb's69 View Post
Looks great Rob! Are you going to notch the frame?
Not to hijack but does anyone have a 4" drop in the rear without a notch and do the axle tubes make contact with the frame at all while driving? I want to lower mine 2/4 and didn't know if I should notch it.
The truck could use a notch, but bouncing on the bumper I couldn't get the rear to hit the modified bump stops. But if I were to put anything in the bed and drive it would probably hit.
Originally Posted by CC69Rat View Post
Aren't those upper balljoints fun ?
A cut off wheel put an X in the rivet and an air chisel popped it out. Was cake. The lower's were actually harder!
Rob68c10 is offline   Reply With Quote
Old 03-21-2012, 09:17 PM   #28
RCbowtie69
RCbowtie69's Avatar
Looking good,hope to see finsh product with wheels,keep up the work & keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 03-21-2012, 09:37 PM   #29
Ackattack
Ackattack's Avatar
There for a second I thought you just turned the truck around in the garage
"No buck" has 4" drop springs in the back without a notch. Haven't had any problems with it.
Ackattack is offline   Reply With Quote
Old 03-21-2012, 09:40 PM   #30
Pro Performance
Pro Performance's Avatar
You should be Ok in the back without a notch. Anything lower and I would c-notch.
Pro Performance is offline   Reply With Quote
