Old 04-30-2012, 10:50 AM   #26
DorianB
DorianB's Avatar
Re: Original wood beds
Picked up a stepside bed off a 1968 orange donor truck at Pull a part and the wood that was left was painted to match the body color.
(PS, rails were orange also)
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2
DorianB is offline   Reply With Quote
Old 04-30-2012, 11:55 AM   #27
David67
David67's Avatar
My '67 had the very rare invisible wood option.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 04-30-2012, 09:04 PM   #28
Oh yeah,you just reminded me. Many trucks have air colored bed wood.
Old 04-30-2012, 09:59 PM   #29
50bomb
50bomb's Avatar
Wow that is cool. I never knew that info about the wood being painted the same color as body.
50bomb is offline   Reply With Quote
Old 04-30-2012, 10:03 PM   #30
ls1nova71
ls1nova71's Avatar
Original paint on my short bed. Never seen any difference in wheel tubs from wood bed to steel floor.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-30-2012, 10:07 PM   #31
CC69Rat
CC69Rat's Avatar
Wow ! There's one with an invisible cab!
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-30-2012, 10:14 PM   #32
Willys47
Willys47's Avatar
Oh I missed that
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 04-30-2012, 10:16 PM   #33
ls1nova71
ls1nova71's Avatar
Originally Posted by SS Tim View Post
Like to hear someone else chime in on this. Close up pictures of known original wood bed tubs and steel floor tubs are requested. Something tight along the rear flanges should do it.
I pulled these out of pick a parts myself, so I know for a fact that one of these was from a wood bed and one was from a steel floor, but I can't remember which is which. The both look the same to me.
Old 04-30-2012, 10:19 PM   #34
ls1nova71
ls1nova71's Avatar
And the common invisible tailgate.....
Old 05-01-2012, 08:18 AM   #35
You don't see them? They are air colored. There were many made that color,you just don't know when you're looking at one.
Old 05-01-2012, 08:50 AM   #36
kcfirstbuild
How was the bed mounted to the truck, I plan on running it like for a while till i save enough for wood?
kcfirstbuild is offline   Reply With Quote
Old 05-01-2012, 10:34 AM   #37
SS Tim
SS Tim's Avatar
Thanks for the pictures. They certainly do look alike. I'm going to have to dig deeper into this but it appears to be based on incorrect information given to me (see the picture) quite a while back. With GSPP ownership change and the time frame, I'm sure there isn't a way there to trace this out. If there was a difference in production tubs it likely wasn't present in service replacement parts. They were intended to cover as many applications as possible by function. So a parts catalog listing might, but isn't likely, show a difference either. Anyone care to look these up and see if there is a notation relevant to RPO "E81 FLOOR BOARD"?
SS Tim is offline   Reply With Quote
Old 05-01-2012, 10:53 AM   #38
SS Tim
SS Tim's Avatar
These through bolts and gravity. Might have to be a bit creative in the interim.
Old 05-01-2012, 02:00 PM   #39
ls1nova71
ls1nova71's Avatar
The cross sills that go under the wood bolt to the frame. When you bolt the bed sides to the cross sills you will have to shim the sides up the thickness of the missing wood or it will angle down in front since the rear of the bed sits on the frame. With out a floor the bed is very flimsy so care should be used to avoid damaging anything.
Old 05-01-2012, 03:46 PM   #40
SS Tim
SS Tim's Avatar
Very True! Seen more than one bed just flopping the free distance on the through bolts due to missing or pulled through planks. Here are a couple of shots to show how the through bolts go down through the planks and some of the cross sills at the frame brackets. Please note however the strip bolts and washers are missing in the pictures. Some sills/channels just bear on the frame assembly. But the wood planks and strips tie the whole bed together. Pre-shaped wood and new hardware (strips too) make it go pretty quick (don't forget the heat shield/s). Of course some people just wing it all together, like the last picture.
Old 05-01-2012, 11:02 PM   #41
elcaminodragster
I have a 71 C20 and looking at puttin the bed on without he wood temporarily....
So as long as you put spacers where needed (in place of wood). You can run the truck safely without the wood and the bed fully assembled?
elcaminodragster is offline   Reply With Quote
Old 05-01-2012, 11:30 PM   #42
longbed67
longbed67's Avatar
Or just get a couple of sheets of 4x8 3/4" ply and use a jig saw to cut the pattern bolt it up and that way you dont have to strategically place, and you have a surface that is actually useable.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 05-15-2012, 08:54 PM   #43
kcfirstbuild
thanks everyone, I'm going to go with pine and paint it the color of my truck. Did they paint the underside of the wood floor or just black it out ?
Old 05-15-2012, 09:07 PM   #44
litew8
litew8's Avatar
I think they painted the underside black.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 05-15-2012, 09:23 PM   #45
SS Tim
SS Tim's Avatar
The bed boards were sealer dipped prior to assembly (the black color) then they were painted body color on the topside.
Old 05-16-2012, 02:31 AM   #46
SS Tim
SS Tim's Avatar
Meant to add this earlier, sorry.
Old 02-02-2013, 06:05 PM   #47
dads longhorn
dads longhorn's Avatar
original wood bed, used to be painted dark olive, but the paint is long gone mostly. I think dad put used motor oil on it and that's preserved it very well. I like the dark wood color. 1971 custom camper 20 longhorn
dads longhorn is offline   Reply With Quote
Old 02-02-2013, 06:48 PM   #48
50bomb
50bomb's Avatar
I LOVE it!
Stovebolt-It is painted
Old 11-24-2018, 11:17 PM   #49
davischevy
davischevy's Avatar
I had the bed cleaned out on my Longhorn today and took a pic of the original wood bed.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
