Old 06-11-2012, 06:58 PM   #26
1977K10
1977K10's Avatar
Re: My TH350 rebuild
found a TH350 handbook on Amazon today, and got it, maybe some information in there I can use as well.
Amazon.com: Turbo Hydra-Matic 350 Handbook... Amazon.com: Turbo Hydra-Matic 350 Handbook...
1977 K10 Chevy short box
6.6L - V8 400CI
TH350 3SP Auto on the column
http://67-72chevytrucks.com/vboard/s...d.php?t=525540
1977K10 is offline   Reply With Quote
Old 06-12-2012, 11:10 AM   #27
1977K10
1977K10's Avatar
I am going to be getting some video of some of my rebuild as well, in which I will post up on my you tube channel, when I do I will be putting up a link so it can be found.
being as I don't have to work today, I only have 1 meeting on my schedule, I will be posting my pictures later today so every one can see where I am at.
Again thank you all for the comments and advise, and jokes.
6.6L - V8 400CI
Old 06-12-2012, 11:17 AM   #28
Edahall
Hey, you're going to be putting all the shady transmission rebuilders out of work what that video. Once you get done rebuilding one of these things, you'll never have a transmission rebuilder do the work again.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 06-12-2012, 02:36 PM   #29
1977K10
1977K10's Avatar
Talking Re: My TH350 rebuild
I kinda hope, I know i treat my stuff like its a part of me, I don't allow steangers to touch me, why should i allow them to touch my truck.
Lol,
I am not trying to put honest people out of work, but i know shops don't all the tie give a run down of what they do, if people learn how to take care of stuff then business lose out, but that's what made America strong, people doing things.
If i can help teach and learn at the same time great.
6.6L - V8 400CI
Old 06-13-2012, 05:08 PM   #30
1977K10
1977K10's Avatar
got a call from my other job yesterday, so I didn't get to post, so here are some of my pics.
1. these small bolt/nuts I replaced due to the old bolts vibrated out
so I made sure these wouldn't.
2. I had just removed the three (3) bolts (TH350) connecting my flywheel to
my Torque converter, I was able to rotate the converter with one finger
so I know know that after I rebuild, I should be able to still rotate this easily.
3. The modulator after I just removed the vacuum hose.
4. a shot of the worn down transmission fluid return line.
I found that if I use reinforced hose that allows for some flexibility of routing,
but I want to keep it as straight as possible to keep the fluid dynamics
flowing good, and keep resistance to a minimum. I may look into bending
my own tube to a custom route, because I will be installing a specific
transmission inter cooler in line after going through the radiator cooler.
5. a look at the bottom of the transmission with the pan removed, the filter
clearly visible, after I drained the pan for the second time getting the rest
of the fluid out I am still finding parts of the friction gaskets, and such in
the bottom of the pan, as well as alot of thick burn fluid just hanging
around the bottom of the pan as well.
I will get this cleaned out and looking real nice and get a layer of like
undercoating on the pan so it don't rust and I am going to make a skid
plate for protection of the underneath of the transmission.
As soon as possible, I am also going to be getting new mounts, and other
bushings for everything that the trans oil wore down.
6.6L - V8 400CI
Old 06-13-2012, 06:00 PM   #31
rs72z
rs72z's Avatar
One word of advice. Clean!!!!! You must get everything spotless before going back toghther. Auto trans need to be clean when reassembling.
Ok maybe more than one word.
Most of the tools on the list probably won't be needed. You will need a spring compressor for the low reverse return springs and one for the foward and direct drums. You can get a couple of large hose clamps to align the 2 pump halves. If you dont feel comfortable dropping the pump back in get a couple of long bolts and cut the heads off to use for alignment dowels. You can do the same for the valve body.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 06-13-2012, 06:05 PM   #32
1977K10
1977K10's Avatar
So true, I wouldn't put this back together dirty, it would get particles back in and slowly tear up the parts just replaced
ok, sounds like good advice as well, Thank you
So long as I do this slow like I am and look at everything, I believe that putting it back together will be no problem.
the bolts are a good Idea as well.
6.6L - V8 400CI
Old 06-13-2012, 10:17 PM   #33
Edahall
Be careful with lint from towels. They can wreak havoc on a rebuild. I also dip everything in some clean transmission oil before reassembling.
Old 06-13-2012, 11:43 PM   #34
1977K10
1977K10's Avatar
Smile Re: My TH350 rebuild
Oh yea, i would never use old trans fluid to lube new parts, theres still crap in it that filtering cant get out.
I was thinking about like chamois to do a finishing wipe down before install unless someone found a better alternative.
6.6L - V8 400CI
Old 06-16-2012, 02:12 AM   #35
1977K10
1977K10's Avatar
I got my th350 handbook today, I have more reading material to absorb while rebuilding... COOL
6.6L - V8 400CI
Old 06-16-2012, 11:55 AM   #36
1977K10
1977K10's Avatar
this friday, saturday, and sunday are long days, can't wait until monday the starting of my short days to get back to work on my trans.
6.6L - V8 400CI
Old 06-16-2012, 01:15 PM   #37
deth_1970
deth_1970's Avatar
k10 that is a good book I have that one in my library, some of the tools you can make yourself, front pump puller, 2-3" bolts with the same threads as the valve body with the hex head cutoff works to help guide the valve body gaskets plate, and valve body into place, same guide bolts can be used to set the front pump into place
for a pump puller I have a slide hammer with a bolt that threads into the pump itself, if you look closely there will be 2 threaded holes in the pump, at 11 and 4 o'clock if memory serves me right,
correct snap ring pliers make it nice, snapon 350 snap ring pliers, I think blue point makes a pair too, search it online, myself I have used an ice pick and screwdriver on the snap rings,
please do not try to remove the snap rings out of the piston without it being compressed,
78 dualy crew cab wife calls "the beast"
79 silverado "yeller"
99 tahoe
02 Gmc sierra
deth_1970 is offline   Reply With Quote
Old 06-16-2012, 01:20 PM   #38
1977K10
1977K10's Avatar
I do have like 10-15 pair of different type of snap ring pliers, i would try to remove those incorrectly.
i bet someone has before, and endwd up paying for that.
6.6L - V8 400CI
Old 06-16-2012, 01:24 PM   #39
shawno72
C/10 junkie
shawno72's Avatar
Let's rip her open!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 06-16-2012, 01:29 PM   #40
deth_1970
deth_1970's Avatar
yes they have, my spring compressor is a homemade one with a foot pedal I love it better the any snapoff one, it's made out of an old box stapler, it is floor mounted
best word of advice, take your time, think it through, and if it doesn't feel right double check it,
99 tahoe
02 Gmc sierra
Old 06-18-2012, 03:48 PM   #41
1977K10
1977K10's Avatar
With the concrete feeling like a frying pan, i have been reading my manuals, and got my upper and lower trans mounts ordered, so I can compare and make sure it fits like a glove.
6.6L - V8 400CI
Old 06-18-2012, 04:11 PM   #42
shawno72
C/10 junkie
shawno72's Avatar
I understand it's been hotter than heck here the last few days so I haven't been out in the garage working on my engine but today is only like 85 so I'll be out there tonight.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 06-18-2012, 06:07 PM   #43
legendman
legendman's Avatar
Subbed , just picked up a 84 c10 that has a th350 that isn't working correctly.
Good luck on the rebuild
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 06-18-2012, 06:15 PM   #44
1977K10
1977K10's Avatar
if you look into my thread here, I do have a few links that show some books to get, that I have got, and been reading, they are a great help.
Some of the guys here have also posted some great links to some business that have some good products.
I did goto Advanved Auto parts here in Colorado and got a super rebuild kit for my trans, and been tool hunting today, got a clutch spring compressor on its way from O'Reily Auto parts.
I got a bearing and seal driver from Car Quest (STL 12600) $44.11
6.6L - V8 400CI
Old 06-18-2012, 06:28 PM   #45
1977K10
1977K10's Avatar
Cool Re: My TH350 rebuild
We hit 100 degrees today here in Wheatridge, Co, the black top feels like a frying pan that has a fire on high under it, I really don't care for it.
I like temps around 60-75 with a light cool breeze.
this makes me want to hibernate
6.6L - V8 400CI
Old 06-18-2012, 06:43 PM   #46
1977K10
1977K10's Avatar
some pics for today:
1. shows my squishy trans mounts, feel like dry marshmallows
2. shows my lower trans mounts
3. shows my new to me bearing and seal mounting tool
4. shows my (got today) LMC.com magazine summer edition
5. shows the new mounts I got today from Advanced Auto parts
6.6L - V8 400CI
Old 06-18-2012, 07:37 PM   #47
Car'n'Guitars
Car'n'Guitars's Avatar
Cool info here, I'm gonna keep a close eye on this, I hope to do this to my transmission someday.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 06-19-2012, 02:08 AM   #48
1977K10
1977K10's Avatar
I am glad that you found this thread, and that it may help with your rebuild as well, thats one reason why I am doing this, I had great advice, help, comments when I posted my first coment, and allowed to "nose" around looking at others helping others. I hope that you find this informitave
6.6L - V8 400CI
Old 06-19-2012, 06:20 AM   #49
D13
D13's Avatar
Don't undercoat your pan. Not only will it be a PITA to get off and clean next time, the undercoating will hold in heat. A coat of paint, engine black works good, is all you need. I like to do that after it's put on, that way the bolts get some and it all looks pretty.If you want ot drop some coin stainless bolts are good on the pan... and polished stainless - well, now it's a show car!
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-19-2012, 10:42 AM   #50
rs72z
rs72z's Avatar
here's a couple of links that might help.
http://www.nastyz28.com/forum/showthread.php?t=53671
http://turbo350only.com/
___________________
78 ccsb dually
5.3
4l60e
77 k10, rebuild, th350, tranny, transmission
