Old 07-30-2012, 07:02 PM   #26
Laser145
Re: Engine runs better with MAP sensor unplugged?
I've done the test where the voltage drops with my vac gauge. Came out perfect.
Timing I checked a month ago. Spot on...
Seriously though... Thanks for all this help I'm learning a lot!
1987 R10
1976 K10
Laser145 is offline   Reply With Quote
Old 08-05-2012, 08:14 PM   #27
Laser145
Found a crack in the MAP sensor VAC line at the back of the TBI... taped it up and my engine is much happier!
Not perfect though... It idles a little rougher. Before today it was idling so smooth you couldn't tell it was running...now it idles more like an old truck. Acceleration is much improved. Still a small hesitation at the first sign of throttle, but it overcomes very quickly and runs out.
My timing is slightly retarded... but we're having some trouble getting a wrench on the bolt to loosen the distributor... welded a bend in a 9/16th wrench then broke it. It's on really tight.
The smoking has been reduced greatly... I pulled the valve covers and the drivers side was pooling oil near the rear. Ran a rod through that valley and it drained down into the motor. I cleaned up with valves, and changed my oil again, adding Marvels this time.
I'll change again in a hundred miles or so.
We're getting there I suppose...
1987 R10
1976 K10
Old 08-05-2012, 08:58 PM   #28
TheApocalyptican
TheApocalyptican's Avatar
For the timing wrench....I took one of the regular ratchet wrenches you can buy, and heated it up with a torch, and bent it with a vise and pliers. Made it so without the coil being attached, I can use the wrench by hand. Might not work with it being so tight on you, but just another idea to consider.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 08-05-2012, 09:37 PM   #29
Laser145
That's what we did... And broke it... I'm going to loosen that nut when I pull the TBI to replace a gasket next week.
I won't put it on so tight again.
1987 R10
1976 K10
Old 08-05-2012, 11:09 PM   #30
rfmaster
rfmaster's Avatar
This is what you need for distributor nut
http://www.ebay.com/itm/Pro-Value-2p...3fa34b&vxp=mtr
Just replace MAP line with 1/4" hard vacuum line.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 08-06-2012, 01:35 AM   #31
TheApocalyptican
//RF
See...I went and forgot to add distributor before "ratchet wrenches". The link above is what I was talking about. Worked, barely, then I heated and bent the correct size one, and it works great.
