Old 10-01-2012, 06:21 PM   #26
rob32472
Re: Bolt on Rack and pinion
Originally Posted by 65Gregg View Post
I glanced at the website, I couldn't find anything that indicates which waterpump is required.
Short water pump
rob32472 is offline   Reply With Quote
Old 10-01-2012, 09:53 PM   #27
robnolimit
robnolimit's Avatar
Originally Posted by aggie91 View Post
Rob
Do you think that this mounting kit and rack and pinion would clear the bushing on the lower control arm if the lower arms where from a 73-87 C10? I ask because the bushings are much larger in diameter and I know the rack kit from No Limit does not clear them....
Thanks,
It looks like it would clear the stock 73-87 arms OK. This rack is mounted up higher, to have correct geometry with the outer TRE coming in from the top, like the OE. Also, this kit appears to mount the rack a little farther forward, which will give additional clearance. It looks like a nice product. I know what rack it is and they are on the right track. More good parts for C10'ers.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 10-01-2012, 11:00 PM   #28
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by robnolimit View Post
... I know what rack it is and they are on the right track. More good parts for C10'ers...
Rob
I'm guessing that this rack is different then yours. What are the differences? Does it have more or less turns lock to lock or is there more or less range of motion? I already have your No Limit unit and waiting on Porterbuilt's Forward Arms. I'm asking for another project that is in the works that I won't be spending as much money on it...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-01-2012, 11:08 PM   #29
ol_skool_chevy
ol_skool_chevy's Avatar
i like it but I would like to see how your connecting your steering shaft also..I see its moved inside the frame rail now??
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-02-2012, 04:43 PM   #30
rob32472
The steering shaft is moved inside the frame rail and uses a support bracket that bolts on top of the motor mount. Here are some pics of the steering shaft connections.
Old 10-03-2012, 04:04 PM   #31
robnolimit
robnolimit's Avatar
Rob
So far it looks like a good kit. There are some differences, but if properly engineered and installed it should work great.
- Be carefull with the angles of the steering u-joints. 30* is really the max. Adjusting the idler bearing and/or moving the column a bit to make sure your under the 30* mark is very important. Let us know how the drive is. How many turns lock/lock? Does it turn the same full left vs. full right? Is the U-Turn ability better/worse? How is it in town, a parking lot, freeway?
Old 10-03-2012, 06:48 PM   #32
rob32472
The steering is good with no binding at all. I have driven it only around for a short drive. The steering is about 3.5 lock to lock. It appears to be equal both ways. I will post more as I drive.... Just a note the kit was designed with a stock application in mind so my steering shafts are a little different Due to the LS swap. The angles would not even be close using a stock set up they are right at 30 degrees for my application.
Old 10-23-2012, 02:15 PM   #33
Slammit
I have not heard any comments yet about the Unisteer R & P kit fitting a 72 C10 that has been lowered in the front ~3.5" and the rear 5". Do any of you foresee R & P kit fitment issues due to having a lowering kit on these trucks?
FYI, the lower A arms are not tubular - at least not at this point. It currently has lowering spindles and shorter springs/shocks from the lowering kit (installed by previous owner).
I may be asking this prematurely since the kit has not been on the market very long - but I can't picture much of a problem since it hasn't been lowered 'radically'. lol
Thanks for any advice...so glad to see these kits hitting the streets!
Slammit is offline   Reply With Quote
Old 10-23-2012, 06:09 PM   #34
INSIDIOUS '86
INSIDIOUS '86's Avatar
Glad to see a unlisted product actually work. Look online and search how all of the mopar guys are royally pissed at unisteer
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-23-2012, 06:13 PM   #35
INSIDIOUS '86
Replace those joints as well. The fall part and rattle loose overtime just FYI. My dads superbee with a unisteer did this on the highway. Lucky we caught it.
Old 10-24-2012, 07:53 AM   #36
Slammit
Insidious - Did I just hear you say the Unisteer steering U joints *can* fail rapidly? And if you replaced them - what would you replace them with please?
(See pic for u joints in question)
Thanks for any info for all of us.
Old 10-24-2012, 10:11 AM   #37
rob32472
I have had good luck with unisteer u joints in the past. Did the joints fall apart? Set screws come loose?
Old 10-24-2012, 10:23 AM   #38
Scottshotrods
We use Uni-steer u-joints on all of our builds in the shop over the last 3 years and have sold several u-joints to our customers.Never had any problems with them at all.
Please explain what problems you have had with them?
Justin
Scottshotrods is offline   Reply With Quote
Old 10-24-2012, 10:50 AM   #39
Slammit
I'm anxious to hear about this.
IMO...these set screws should have at least Loctite Blue (or similar) and any other screws/nuts up and down the steering shaft and in these bolt on kits that don't have nylon (locking) nuts should be using Loctite Blue.
I'm saying this not knowing if that is even the problem or even if there is a real problem for the C10 installations...
Old 10-24-2012, 12:30 PM   #40
rob32472
I will agree on the loctite.... the main purpose of the thread and the install was for mock up at this point....... the entire truck will be coming apart soon for paint and powder coat
Old 12-26-2012, 01:29 AM   #41
wraprail
wraprail's Avatar
Sorry to drag up an old thread but I am installing this in a friends C10 so what rattled loose over time? How much time? Did they actually fall apart?
wraprail is offline   Reply With Quote
Old 02-23-2016, 02:25 PM   #42
crakarjax
crakarjax's Avatar
Wow what a difference 4 years makes... the kit is now twice the price at $1700!
http://www.unisteer.com/c10/67-72-ch...inion-kit.html
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-23-2016, 05:37 PM   #43
dwcsr
Hollister Road Co.
dwcsr's Avatar
That's the retail on it, You can find it for $1450
dwcsr is offline   Reply With Quote
Old 02-23-2016, 11:58 PM   #44
crakarjax
crakarjax's Avatar
You're right, $1150 at summit... Still pricey though.
Old 03-05-2016, 01:01 PM   #45
1moretoy
Will this work if running bags? Looks like the shafts might hit the frame.
1moretoy is offline   Reply With Quote
Old 03-05-2016, 01:48 PM   #46
crakarjax
crakarjax's Avatar
A lot of people notch the frame to clear the shafts, but since this one is mounted a bit differently it's hard to tell if that would be necessary.
Old 03-05-2016, 07:29 PM   #47
robnolimit
robnolimit's Avatar
No need to notch the frame, as long as you haven't cut up the stock upper coil pocket (upper bag plate mount) there are no problems.
Old 03-06-2016, 02:30 PM   #48
crakarjax
crakarjax's Avatar
Ah right I was thinking about the No Limit kit, which has clearance issues if the crossmember is pancaked or set up into the frame iirc.
This one doesn't have that issue since it's located to the frame, but it looks like it hangs as low as the crossmember such that pancaking the x-member or setting it up into the frame wouldn't gain any clearance, but it's hard to tell give n the angles in the pics. Can anyone confirm that?
Old 03-06-2016, 06:07 PM   #49
1moretoy
I'm just bag plates and portertbuilt upper and lower control arms.
Old 03-07-2016, 10:31 AM   #50
aggie91
aggie91's Avatar
I used No Limit's kit in Sunburn (link is in my sig). I raised the cross member in the frame 1.5". We had NO clearance issues with the rack or tie rod ends clearing the frame rail. We also had air bags in our set up...
Karl
The LST Challenge:
