Old 05-01-2013, 12:03 AM   #26
rustbucket66
Re: LT1 Burbs 65 Stock SW Build
Cool build, stock everything. That truck is full of options too. That junk on the trans will come off easy with dry ice blasting, and no damage or pitting on the case.
rustbucket66 is offline   Reply With Quote
Old 05-01-2013, 01:11 PM   #27
Low Elco
Wow, heckuva start, nice work!
Low Elco is offline   Reply With Quote
Old 05-02-2013, 09:45 AM   #28
LT1 Burb
LT1 Burb's Avatar
Some updated pics, got the motor and tranny in.
LT1 Burb is offline   Reply With Quote
Old 07-13-2013, 10:33 AM   #29
LT1 Burb
LT1 Burb's Avatar
Dropped the cab off at the media blasters and just picked it up so let the fun begin. I was happy to see the cab corners were nice but there was a few dents I didn't know about. At least the expensive stuff is done, now its just time.
Old 07-13-2013, 11:55 AM   #30
Bomp
Bomp's Avatar
Nice job on the motor and trans sitting in the frame. All numbers matching too
Cab came out clean. Shouldn't be long for primer.
Bomp is offline   Reply With Quote
Old 07-14-2013, 06:52 PM   #31
williamsboys
williamsboys's Avatar
If you don't mind me asking how much did it cost to blast and coat the cab? I'm wanting to do the same.
Williamsboy
williamsboys is offline   Reply With Quote
Old 07-14-2013, 09:00 PM   #32
pdxhall
pdxhall's Avatar
Nice work man! The frame looks great. I'm in the process of installing my brake lines and I was wondering if you would mind showing some pictures of how the lines are routed from the back to the front and across the frame at the front. It would help me a lot. Thanks.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 09-11-2013, 09:40 AM   #33
LT1 Burb
LT1 Burb's Avatar
It was 410 to do the cab with primer and sandblasting.
Old 09-11-2013, 09:52 AM   #34
LT1 Burb
LT1 Burb's Avatar
I have just been working on floors and welding in patch panels. Glad I took the rockers off as the main door pillar was rotted on the drivers side, passenger side was great. Found a rodent nest inside both rockers also, just something to help out the corrosion.
Old 09-11-2013, 09:58 AM   #35
LT1 Burb
LT1 Burb's Avatar
More floor work and welding, learning on the fly., Also ordered some aftermarket rockers but the contour sucked and they were a 1/4" long so decided to fix mine.
Old 09-11-2013, 10:00 AM   #36
LT1 Burb
LT1 Burb's Avatar
More floor work, at least this part is cheap and just requires wire, time and grinding discs.
Old 09-11-2013, 10:01 AM   #37
LT1 Burb
LT1 Burb's Avatar
Sorry, just saw this , LMK if you still need pics.
Old 09-11-2013, 10:56 AM   #38
1963c-10
1963c-10's Avatar
Great progress on the cab & frame
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-11-2013, 10:23 PM   #39
chakah
chakah's Avatar
Wow, this is coming out so nice LT. Great job
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 09-23-2013, 04:29 PM   #40
NEWFISHER
NEWFISHER's Avatar
Looks better in person! Thanks again for the parts for my project.
NEWFISHER is offline   Reply With Quote
Old 09-24-2013, 12:41 AM   #41
pdxhall
pdxhall's Avatar
The patching looks great, man. I know what you mean about the rockers. I was able to use one of mine but the other was too far gone to patch and I had a terrible time getting the aftermarket one to fit right. It might have been less trouble to patch and reuse the old one even though it was in bad shape. I could still use a couple of pics of the brake line routing, especially at the front. Keep up the good work.
Sanity'66
Old 09-24-2013, 01:24 AM   #42
LT1 Burb
LT1 Burb's Avatar
Just welded in a new tunnel.
Old 09-24-2013, 08:15 AM   #43
plainred65
plainred65's Avatar
Looks great! What tires are you running?
plainred65 is offline   Reply With Quote
Old 09-24-2013, 09:37 AM   #44
LT1 Burb
LT1 Burb's Avatar
They are the coker bias plys.
Old 09-24-2013, 10:12 AM   #45
plainred65
plainred65's Avatar
I've been looking at the Coker tires, have a set of Dayton 7.00-15 on my 65 now. Very happy with them but need to start looking to replace. Thanks
Old 09-24-2013, 10:26 AM   #46
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Subscribed! great work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-01-2013, 12:20 AM   #47
LT1 Burb
LT1 Burb's Avatar
Woohoo, just finished my 10000th billionth spit weld. Now to finish final grinding and ready for mud.
Old 10-01-2013, 12:56 AM   #48
NEWFISHER
NEWFISHER's Avatar
Zick zzick zick zzzzzick zic zzick... you'll keep hearing them for weeks
Old 10-03-2013, 12:20 AM   #49
LT1 Burb
LT1 Burb's Avatar
Spent a few hours grinding and cleaning up some spots. Practice has certainly helped as it gets easier the more I do. It's amazing how much work some hackery shifter hole cut caused. I must have 16 hours in that tunnel piece. I guess there was some rust that had to be fixed anyways.
Old 10-03-2013, 12:21 AM   #50
LT1 Burb
LT1 Burb's Avatar
His little brother is relegated to the rain when I am grinding.
