Old 10-17-2012, 09:15 AM   #26
Mr.Hyde
Re: Mr. Hyde's Ride
Originally Posted by 50bomb View Post
I can see that is gonna be a cool truck when your done. Don't give up. Get it done. Enjoy!
Thanks I plan on breaking it into a few smaller projects. Frame and suspension, drive train, body work, interior work
Mr.Hyde is offline   Reply With Quote
Old 10-17-2012, 04:57 PM   #27
Mr.Hyde
Re: Mr. Hyde's Ride
Ya I'm just breaking it into smaller parts frame,drivetrain,body, interior etc each one is a seperate project haha
Old 10-17-2012, 09:32 PM   #28
Tinkermc
Re: Mr. Hyde's Ride
smaller task make benchmarks for completion that will help keep morale up and spirits high.
Tinkermc is offline   Reply With Quote
Old 10-18-2012, 08:06 AM   #29
Mr.Hyde
Re: Mr. Hyde's Ride
Oh an just as a idea what do you guys think about flat black with gloss black racing stripes?
Old 10-18-2012, 08:26 AM   #30
trac209
Re: Mr. Hyde's Ride
I doubt that would show up well maybe try a grey gloss imho
trac209 is offline   Reply With Quote
Old 10-18-2012, 04:08 PM   #31
Mr.Hyde
Re: Mr. Hyde's Ride
That's kind of the Idea behind it is the subtlety. Also wondering I anyone knows where I can find the dust cover for the hanger bearing or is there only one in the front?
Old 10-18-2012, 10:50 PM   #32
Mr.Hyde
Re: Mr. Hyde's Ride
ok so i was rushed at work to type this stuff, let me clarify. Is there only one bearing dust cover or two on the hanger bearing? and is there any guides on building the stock transmission?
Old 10-18-2012, 11:19 PM   #33
trac209
Re: Mr. Hyde's Ride
Idk about the dust cover but as far as rebuilding your trans which from the pic looks like a sm465,I would not go into that if your not familiar with them. The clutch and stuff is straight forward though if your mechanically inclined. It all depends on your automotive skill level. But there are books on how to rebuild them to be read. Those transmissions are about as bullet proof as they get. Do you know it to be in need of rebuilding or do you just want to as a precaution.
Old 10-19-2012, 08:24 AM   #34
Mr.Hyde
Re: Mr. Hyde's Ride
More or less so I can get the linkages right and make sure I build that portion of the drive train correctly. He said the transmission was rebuilt but we all know what that means.. And as for the support bearing ill post a picture to give you guys an idea of what I mean.
Old 10-20-2012, 10:33 AM   #35
Mr.Hyde
Re: Mr. Hyde's Ride
I was wondering if anyone has blue prints for the hidden hitch?
Old 10-20-2012, 06:23 PM   #36
Mr.Hyde
Re: Mr. Hyde's Ride
Just got the motor it's a 283.. Not what was expected but o well. What's the best I can do for this motor for hp torque or high reving? I want to squeal some tires
Old 10-20-2012, 06:45 PM   #37
trac209
Re: Mr. Hyde's Ride
Well 283's aren't really known as torquey engines. The worst thing you can do to a 283 is over cam them. I built many in the 90's and they are awesome power plants. My advice is an rv style camshaft of 420 or less lift and some 305 small valve heads. This will give the best throttle response and still be able to smoke the tires some. Your granny sm465 isn't the best choice for a fast shifting tire smoking truck anyway IMHO.
Old 10-20-2012, 06:54 PM   #38
Mr.Hyde
Re: Mr. Hyde's Ride
ya I`ve already started looking for a 4 speed transmission and a guy at work has one for sale for 300$ so i might just on that in a bit. I`ll ask him what kind of transmission it is monday. in the mean time here are some pictures.
the dust cap I`m looking for, i assume its fairly important
and some pictures of the motor, what would be a good cleaner for this greasy thing
Old 10-20-2012, 07:02 PM   #39
trac209
Re: Mr. Hyde's Ride
To me it looks as though that engine might need an overbore due to the rust and galling in the cylinders. So I would not bother to clean it,the machine shop will have to hot tank that block anyhow.
Old 10-20-2012, 07:06 PM   #40
Mr.Hyde
Re: Mr. Hyde's Ride
how much is it roughly for that type of work?
Old 10-20-2012, 07:30 PM   #41
trac209
Re: Mr. Hyde's Ride
Well if you want my advice,if your not dead set on using the 283 and your trying to cut costs I would try to find a running powertrain out of another car or truck. I look for vehicles in the 1970 to 1975 for 350's or up to 1985 for 305's.
By the time you have the machine work to block and crank and get new pistons,cam and bearing set you'll be in over 1200 bucks easy. A used engine in good condition can be had for just a couple hundred.
Old 10-21-2012, 04:48 AM   #42
Mr.Hyde
Re: Mr. Hyde's Ride
Hmm well I'll look into it I just need something in the truck for the time being. To get it goin
Old 10-29-2012, 11:08 PM   #43
Mr.Hyde
Re: Mr. Hyde's Ride
Managed to get a second hanger bearing dust cover off eBay, now the next portion is to find interchangeable parts that bolt on. I'm looking for power steering and front disc brakes which have been previously mentioned I believe. Also a gas tank I've seen some threads on using ones from camaros etc but I want to put on a hidden hitch aswell. If I can get dimensions of a hitch and tank I might even be able to weld then up out of stainless an mild steel
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Old 11-12-2012, 05:28 PM   #44
Mr.Hyde
Re: Mr. Hyde's Ride
I'm seeing a bit of an issue here. Is it me or does this not look right?
Old 11-12-2012, 05:31 PM   #45
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Mr. Hyde's Ride
I agree - that mobile device notification is annoying just one time, much less twice.
Zoomin is offline   Reply With Quote
Old 11-12-2012, 05:49 PM   #46
Mr.Hyde
Re: Mr. Hyde's Ride
i thought it was going to post a picture here i'm doing it via computer now.
it seems the transmission and motor doesnt exactly um match up.
and heres some casting numbers i took pictures of as i went
couple mock up pictures also an easy way to clear some room in the garage, but i will be mocking up the exhaust while i work on the funds to get my front disc conversion kit leaving the rears as drum i will also more then likely pick up my drop springs at the same time. front end is all apart an i am looking into a way of doing a p/s set up for cheap
Old 11-12-2012, 06:14 PM   #47
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Mr. Hyde's Ride
It looks like the bellhousing fits fine. Does the transmission not fit the bellhousing?
Old 11-12-2012, 06:29 PM   #48
Mr.Hyde
Re: Mr. Hyde's Ride
really? is that top bolt not used for mounting then?
Old 12-24-2012, 07:21 AM   #49
Mr.Hyde
Re: Mr. Hyde's Ride
Well I have a 4 speed with an aluminum bell housing lined up for 400$ complete just waiting on casting numbers and I'm looking into the machining work for the 283. Also I might stick with the 6 bolt and have this as a small welding rig too so it might even get patinad, what component would I need for a front disc conversion specifically if any has the knowledge or has done this?
Old 12-24-2012, 10:20 AM   #50
orngsikL
orngsikL's Avatar
Re: Mr. Hyde's Ride
ive got some jeep coils i'll sell ya for $50, give you a 4-5" rear drop.
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
