Old 11-07-2012, 02:36 AM   #26
Daaaanz67
Re: And so it begins......
I wanted my exhaust to run above the trans x member that's why I went with aftermarket. I know I could have removed the piece that bolts to the upper frame rail but felt better using a trans x member that bolts the same as original. Much cleaner than oem. My exhaust. You can see how much higher than bottom framing rail.
Daaaanz67 is offline   Reply With Quote
Old 11-08-2012, 08:03 PM   #27
cjohnson6772
cjohnson6772's Avatar
I bought a returnless fuel rail to replace the return style rail and when it showed up I noticed the end was kinda dented in. Do y'all think it'll be ok? Will it leak?
cjohnson6772 is offline   Reply With Quote
Old 11-08-2012, 08:06 PM   #28
cjohnson6772
Your exhaust set up looks awesome. I love the way it runs over and through your cross members. What size hole saw/pipe did you use in the trailing arm cross member?
Old 11-08-2012, 08:38 PM   #29
Daaaanz67
I think 3". Had to make 2 hole blanks out of 3/4 plywood then positioned them on the x member bolt the two pieces together to sandwich x member then remove center bit of hole saw now the blanks are your guide kind of have to do it this way because where you will be drilling there's no Metal for the drill to center itself. A plasma cutter would have been easier.
Old 11-09-2012, 09:59 AM   #30
68Stepbed
68Stepbed's Avatar
I used the POL towers and an ECE trans crossmember in my swap. The only issue I'm currently having is a wrong pinion angle. I plan to eventually get a Porterbuilt tailing arm crossmember and tubular trailing arms.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-09-2012, 10:09 AM   #31
cjohnson6772
Great info. I think i may use the POL stands and cross member. What engine mount adapter plates did you use? Where did they place your engine?
Old 11-09-2012, 07:12 PM   #32
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I've had the same issue with completely different mounts. I finally had to raise the tail of the trans as I had mis-read and had about 5.5* of downward tilt. Its got roughly 3* now as does the rear. I may have to get the tall trans hump and raise it some more if I can't settle things down. I've read somewhere that on some vehicles for high speed you need closer to 1* of angle at both ends vs 3*.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-10-2012, 11:25 PM   #33
cjohnson6772
Wow I hadn't considered the drive line angle too much for this swap. What mounts were you using? And would you recommend them?
Old 11-11-2012, 02:13 PM   #34
68GMCCustom
I'm using SBC towers with TransDapt plates, mounted in the forward frame holes. Trans x-member is a CPP tubular with poly mount.
That said....I plan to switch to the POL towers some day as I like the setup better. I've had a bear or a time with vibration. Thinking maybe something got damaged when my rear ujoint broke. Shafts balanced...but something's causing it.
Kurt -
Old 11-14-2012, 11:19 PM   #35
cjohnson6772
I've been busy guys! I know you all love pictures, but unfortunately I don't have any pictures to show, but what I do have is 4 tracking numbers that I am checking obsessively and will hopefully have 5 by the weekend
Didn't know it was possible, but I think this week I have (with the help of LS1tech) melted my debit card. Paypal is sending me self-help emails for crying out loud. Stay tuned for goodies
Old 11-15-2012, 10:43 PM   #36
68Stepbed
68Stepbed's Avatar
I used Trans Dapt plates. I mounted the towers in the rearward 6-cylinder location, so it's kinda hard to say how much it moved everything.
Matt
Old 11-16-2012, 12:50 PM   #37
nlped
nlped's Avatar
68StepBed...that is B-E-A-UTIFUL!!!! Love all the stainless bolts and such...nice touch!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-16-2012, 02:16 PM   #38
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Sorry for the derail... but... 68stepbed... how did you mount the coils? I like that clean valve cover look without the COP.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-17-2012, 12:36 AM   #39
cjohnson6772
I've been out of town for work but when I got back tonight I had some parts waiting for me!
LS3 heads should be here Monday!!!
Old 11-22-2012, 01:18 PM   #40
cjohnson6772
Happy Thanksgiving y'all!
Old 11-23-2012, 12:09 PM   #41
Hart_Rod
Hart_Rod's Avatar
Thumbs up Re: And so it begins......
Nice! Where did u get the heads?
Hart_Rod is offline   Reply With Quote
Old 11-23-2012, 12:33 PM   #42
cjohnson6772
They are BNIB LS3 heads I scored off of LS1tech. I should have a matching L92 intake Monday. I'm about to pull the trigger on a fuelcellguy tank and all POL mounts. Once I measure for the 10th time
Actually that brings up a good question for you: seems like I remember you had done a side marker fill with a cabinet hinge. Are you still happy with it?
Old 11-28-2012, 09:36 PM   #43
cjohnson6772
Well a few new parts on the way. I went ahead a bought the Pacesetter 72C2276 TBSS long tube headers. I'll keep y'all updated on the fit. Fingers crossed. I'm used to 3 bolt flanges or v-band collector connections, but these have slip connections. Any idea how I'm supposed to hook the rest of the exhaust to the collectors? Just a simple swell on the end of the pipe? I know this question has to sound stupid, but I'm not familiar with these style headers.
Also, what do y'all think about running this aluminum line along the frame rail?
http://www.ebay.com/itm/Pro-Series-3-8-Aluminum-Fuel-Line-Tubing-Hose-25Ft-/310514982206?pt=Motors_Car_Truck_Parts_Accessories&hash=item484c229d3e&vxp=mtr
Old 11-28-2012, 09:42 PM   #44
nlped
nlped's Avatar
I ran aluminum fuel line on a fuel injected CJ-5 I built many many moons ago and I abused that thing in the woods and rocks without ever having any worries.
Carter
Old 12-02-2012, 12:59 AM   #45
cjohnson6772
So what do y'all think about running a frame mount trans cooler on the outside of the frame rail beside the trans vs running lines all the way up to the factory radiator? I am going to be running a 4L80e and factory A/C on the engine. I'm thinking about bending up aluminum line for the trans lines and using a trans cooler seems a lot simpler. And I over thinking this? Which way would be better for the trans?
Old 01-21-2013, 11:17 PM   #46
cjohnson6772
So it's official: I've entered the doldrums with this swap. Got everything bought and cam FINALLY arrived tonight. Hoping to take the engine to the engine shop this week for the LS3 top end swap. I was getting some stuff together at the shop tonight and noticed that some of the paint from where I painted the engine orange had started flaking off already. I started looking and all the paint is crap. So now I need to strip the whole engine again and wipe down with lacquer thinner. With an unheated shop and 40 degree highs I can't get the paint to stick. Just delaying the engine and the whole swap even more. It sounds petty but just stupid set backs have been getting the best of me.
Quick: provide me some inspiration.
Old 02-05-2013, 01:47 PM   #47
cjohnson6772
Warning: the images contained below may cause sickness.
Old 02-05-2013, 01:55 PM   #48
no moa
no moa's Avatar
What the !!!!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-05-2013, 01:59 PM   #49
cjohnson6772
Just received that from my engine builder. He was just supposed to be doing a head/cam swap. Now I'm sick and at a loss.
Old 02-05-2013, 02:15 PM   #50
Jon01
Jon01's Avatar
Well, looks like you'll be getting some higher compression pistons out of the deal.
CL motor I assume?
Edit - I'd be very suspect of the trans. That motor has had water in it. I bet it came out of a flood vehicle - do you have the VIN off of what it came out of?
Jon01 is offline   Reply With Quote
