10-21-2012, 11:28 PM | #26 |
Re: Oil capacity of 350 V8? Also, what say you about synthetic?
Zinc is still there at just under 1200 ppm. If the zinc was gone, they would have to change the classifications, and would not be certified for use in motorcycles. Diesel and motorcycle engines do not have roller valvetrains and still need the zinc.
10-21-2012, 11:37 PM | #27 | |
10-21-2012, 11:41 PM | #28 | |
10-21-2012, 11:46 PM | #29 |
In diesel oils the amount of zinc has plummeted in the last few year because modern diesel are getting roller cams.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
10-22-2012, 08:43 AM | #30 |
The levels have not plummeted, but yes they have been reduced. The levels are still way safe for use in older gasoline engines, and motorcycles. Unlike what is available in car oils today
10-22-2012, 08:59 AM | #31 |
I will never touch the stuff again! I decided to try it out in my mower first... Finally got around to changing it and ran it only one time. I seemed to all of the sudden just blow up. Black smoke chugging, knocking rough running shut that thing down !!! I thought oh shoot it's done. Took that oil out and put some 30w in with some Lucas Lube and a new plug for kicks. Has been just fine since. So it sure as HELL is not going in my truck!!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-22-2012, 10:09 AM | #32 | |
Posted via Mobile Device |
10-22-2012, 10:13 AM | #33 |
20' Daredevil (Ret)
Lawn mowers? Nothing but Mobil 1 in mine (Honda OHC engine) since I bought it new several years ago. No problems....
10-22-2012, 10:30 AM | #34 |
HMMM. I thought they were the same.ROTFLMAO! Anyway, it's not going in my apple OR my orange!
10-22-2012, 10:32 AM | #35 |
Honda Mowers are the shizz. Mine has a Kawasaki engine..Maybe that's the problem.
10-22-2012, 11:02 AM | #36 | |
10-22-2012, 11:09 AM | #37 |
Much discussion about zdp on several of the corvette forums. From what I read 0-40 still has elevated levels of zdp. Many are moving to 0-40
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
10-22-2012, 01:56 PM | #38 | |
Even though the failure came with several thousand miles on the engine, I thought that I must have not broken the cam in correctly, even though I had built several engines in the past, and broke the cam in the same way. I pulled the engine and built a 383, with another flat tappet hydraulic Comp Cam. I did the cam break in as usual, and ran Castroil oil, still not knowing about the ZDDP being taken out. As soon as all of this oil situation came to light, I started running the ZDDP additive. Unfortunately it was too little to late as a few months ago, the cam went flat in this engine as well. I have not pulled the engine yet, but I am afraid that it ruined the crank and pistons as in the 350. THis is a lot more expensive proposition, as the rotating assembly in the 383 is forged and balanced, and the 350 was all cast and not balanced (other than from the factory). Thanks for the heads up, oil companies! This only cost me a few grand! Moderm oil seems to be OK in engines with stock valve spring pressures, but in anything with a flat tappet and higher than stock spring pressures, I reccomend using the additive, or if you can afford it, I believe most cam companys offer and nitrided or similar process to their cams. |
