Old 11-20-2012, 06:38 PM   #26
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Dana 60 swap done!
Truck looks great as always and more strength - can't beat it. I'm glad to see you are using the raised steering block as I need to do something about my steering issue with my swapped in D60 - I'm using an adjustable dropped drag link and it made the steering pretty sloppy when I put in the D60. I read about the raised steering block but heard they sheering problem was a reason to stay away from them. Seeing your post and you using them made me look at ORD's site. Good to see they offer ARP hardware. I think this gets placed on my Christmas wish list. Did you replace your drag link with new hardware? IF so, purchased locally or online?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-20-2012, 08:57 PM   #27
ryanroo
ryanroo's Avatar
You could look into a dodge steering arm if you want to avoid the block. they kick up instead of down. they just need to be re-reamed.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 11-20-2012, 10:55 PM   #28
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Thanks Yukon Jack!
Yeah, I used to have one of those adjustable S shaped drag links too and hated it as every time I got back from an off-road trip where the suspension got flexed it came home with the steering wheel crooked. That was on the D44 even with a raised steering arm. Just late this summer I got rid of that and just went with a stock straight drag link with fresh joints from Napa. That was the end of the steering wheel constantly being crooked. Too soon to say how things will work with the D60 along with the ORD raised steering block. The new drag link joints used on the D44 also fit the D60 that you can see in the pictures above. Funny, I don't feel as much of the Detroit locker rear torque steer push now either and don't know why added unsprung weight would help with that. Must be in my mind
The next big trip isn’t unit March when we leave for a week of cruising the back country of the Mojave Rd and Death Valley in California. Probably get at least one mountain trip in by then to test things out before leaving on a couple thousand mile trip but I suspect the steering wheel issue will be fixed now. I still need to raise up the rear of the truck to match the front now too. Man, I can't believe how much better it drives now with the added unsprung weight. It just drives better and rides better.
This is the steering drag link I ran from around 2007 to a few months ago. I hated this thing! Don't ever use one of these
DirtyLarry is offline   Reply With Quote
Old 11-24-2012, 01:53 PM   #29
Yukon Jack
Post Whore
Yukon Jack's Avatar
Is installing the steering block as straight forward as it looks - just removing the four bolts, putting in the studs and then the block and stock arm or is there more to it?
Old 11-24-2012, 02:18 PM   #30
DirtyLarry
DirtyLarry's Avatar
Yeah, it is very straight forward. Just take care in tapping the aluminum block over the king pin spring with a rubber mallet then regrease it when assembled. I added gasket sealer on both sides of the aluminum block to prevent any grease leaks. It does take a lot of grease to fill up the aluminum block before the ball joint gets grease so plan on having a fresh tube of grease in the gun. Too soon to say how well this set up will work but it looks plenty durable. Actually, I can’t say I am disappointed in anything I’ve ever gotten from ORD other than their U-bolts. IMHO they need to find a better supplier of U-bolts.
Old 12-05-2012, 03:33 PM   #31
Big Tex
Big Tex's Avatar
Larry-
That's great news about y'all being pregnant! I saw it mentioned in a post in another forum, but didn't know if you'd mentioned it, or if it was public knowledge.
They are a lot of fun. You're on the right track trying to get all your projects squared away before they arrive. Hold on a second.....
"Hey, make sure you're torquing those....."
1990 K5 Blazer (sold)
1983 SWB C-10 to K-20 Conversion
Big Tex is offline   Reply With Quote
Old 12-05-2012, 04:34 PM   #32
DirtyLarry
DirtyLarry's Avatar
Originally Posted by Big Tex View Post
Larry-
That is great! Yeah, good help is hard to find. You have to keep your eyes on them constantly. Looks like he has it under control though.
Thanks BigTex!
Old 12-05-2012, 10:50 PM   #33
DirtyLarry
DirtyLarry's Avatar
Got the rear ORD Zero rate blocks installation wrapped up this evening to level the truck after the front D60 swap raised the front. I find it easier to just pop the spring packs out to work on them on the floor.
Seems like I’ve had these damn springs out of this truck 100 times in the last few years trying to get this thing to sit level. Once I got it level Mosesburb made me install a D60 and screw up my leveling where I had to start all over again.
After installing the block on the passenger’s side spring
Driver’s side
View of how the zero rate blocks allows for the axle to be pushed back by using 1 of the 3 positioning options built into the block. I used the provision to move the axle back 1”
A hole must be made in the spring plate to reposition the center pin locations. Got lucky on this side and got the hole deadnuts in the right spot. Passenger’s side not so much.
Level devil
Rear wheels look more centered in the wheel wells now too
Before zero rate block
After zero rate block install
That’s all for the K10 for a while. Got lots of plans for the Polar Bear Burb in the next few weeks
Old 12-06-2012, 08:31 PM   #34
martindc1
Awesome. You do good work and documentation. I'm not much a fan of the higher in the front look.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 12-06-2012, 08:53 PM   #35
duallyjams
duallyjams's Avatar
much better
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-09-2012, 11:13 PM   #36
Chevrolado
Chevrolado's Avatar
Originally Posted by DirtyLarry View Post
Superwinch hubs. I love these… ¼ turn to lock or unlock, durable and cost much less than Warn hubs.
When I was playing with my truck this weekend I noticed what hubs the PO put on mine... Superwinch. Kinda looking forward to given them a shot whenever the thing is running again.
Dave
- 1977 Chevy K10
Chevrolado is offline   Reply With Quote
Old 12-11-2012, 02:22 AM   #37
Chevymaniac
How do you like those superwinch hubs? Thinking of buying a set for my Dana 60. Are they the 30 spline?
Chevymaniac is offline   Reply With Quote
Old 12-11-2012, 04:11 PM   #38
DirtyLarry
DirtyLarry's Avatar
I really like Superwinch hubs. I have not had a chance to actually use these D60 hubs off-road yet but they lock and unlock nice with only a ¼ turn. My buddies and I all run Superwinch hubs on D44 axles and never had an ounce of issues. One friend is even running a fully ARB locked front axle with his SW hubs. Yes, these are the typical D60 30 spline hubs.
Old 01-05-2013, 12:33 PM   #39
Yukon Jack
Post Whore
Yukon Jack's Avatar
My steering block and stud kit came in this week so hope to get some free time in the next day or two to install it. Got to hit the parts store for fresh drag link parts. Do I just get a press in zerk fitting for the block?
Old 01-05-2013, 05:03 PM   #40
DirtyLarry
DirtyLarry's Avatar
Nah, the grease zirk in the steering arm/upper king pin cap should already have a grease zirk in it. Providing it is in good shape you just grease the block through that zirk. That zirk is a screw type and can easily be replaced if it needed. It will take a lot of grease, so have a fresh tube handy! Remember to use gasket material to both sides of the block when installing it to avoid king pin grease leaks.
I like Tough Stuff for jobs like that. Autozone stocks this stuff
Old 01-06-2013, 04:55 PM   #41
Yukon Jack
Post Whore
Yukon Jack's Avatar
When I go to pulling the steering arm/upper king pin cap do I just use a mallet to strike the sides to break it free or does it take more persuasion to get it loose?
I assume I just put two nuts on the existing studs to back them out?
Neither of my caps have grease zerks in them - I'm afraid they must have came out and the holes got covered with dirt and grime causing me to not recognize they were missing when I swapped in the axle. I'll have to get the holes cleared out and zerks installed.
Old 01-06-2013, 07:13 PM   #42
ryanroo
ryanroo's Avatar
you can double nut the studs, or use a stud remover. if you are lucky, they will back out instead of the nuts coming off. if you tap on the drag link end of the arm gently with a rubber mallet up, down, repeat, it should come off. the stud clearance is pretty close so you have to take small bites or it gets twisted on the studs and becomes wedged. i would get some new tapered nuts for the re-install if the kit did not come with them. they are 12"-20 threads and have a 60 degree taper. 78 f-350 lug nuts(and many other applications i am sure) are the correct thread and taper. i have a box laying around because it seems the threads get rough every time you disassemble an older axle and they are pretty cheap to replace.
the zerks are easy to snap off when moving an axle or just in general use over time. you may want to check out the nylon cone bushing in the kingpin while you are in there if its been a while without grease it could be pretty beat. there should be zerks in the bottom bearing caps as well, and if they are gone i would be sure to replace them and get things greasy again. the bearing in the bottom will probably be fine since there isn't a lot of movement there, but i wouldnt want them going dry
Ryan
72 K20 12v build
Old 08-01-2013, 11:58 PM   #43
Projectutah
what should i do keep stock steering or crossover? its a k10 with a 10bolt im have trouble finding out whats best. im making an overland rig
Projectutah is offline   Reply With Quote
Old 08-02-2013, 07:15 AM   #44
Redcap
Why bother doing crossover on a weak axle like a 10bolt?
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 08-02-2013, 08:10 AM   #45
Projectutah
Weak 10bolt? Never had a problem... With 37, it has chromoly axle shafts and ARB locker and it's lighter then D60 also stronger then jeep axles and they run bigger tires then me.
Old 08-03-2013, 01:08 PM   #46
Mr. 250r
Mr. 250r's Avatar
I ran a stock 10b under my suburban with 38.5s and it worked great even ramped it and it still held up, i would go back to it in a heart beat but i got a good price on a D60 so i put that under it but at the end of the day the D60 will be considered king that i cannot argue but i cannot knock the 10b because it did way more than i thought it would
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 08-05-2013, 08:22 AM   #47
24s
24s's Avatar
Hello DirtyLarry Im new here and tommorrow i am picking up a dana 60 king pin to put in my 1990 2500 burb. The guy that i am buying it from does not know the year. So my question is it need brakes and im going to napa but dont know what year the Dana is. What year and truck did they come from?
24s is offline   Reply With Quote
Old 08-05-2013, 10:33 AM   #48
jjzepplin
jjzepplin's Avatar
This is the first time I've seen your trucks and what a nice job you have done sir!
I have the block on my 60 and you will be fine. I did put a double stabilizer on and no death wobble ever again!
I have to ask though...What camper is that and do you like it? I have been considering one and have no one to ask opinion.
I am a little strapped(aren't we all) so I cannot afford to make a "Bad" Purchase.
Oh and congratulations!!!!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-05-2013, 05:48 PM   #49
DirtyLarry
DirtyLarry's Avatar
The difference over the years of brake hoses is more related to the banjo bolt thread in the caliper, 7/16 vs. 10 mm. You need to figure out which thread is in your calipers in order to know what brake hoses to use. I would recommend using a set of the ORD brake hoses if you are running any lift at all. If your Dana 60 is a CUCV axle like mine you can count on it having the 10 MM banjo bolts.
Thank you sir. The camper is a 2011 Phoenix popup. I am on my 3rd season with it and it has been great. It’s been bounced, shaken, twisted, baked and frozen with no issues. Phoenix campers are custom made to the owners specs so no two are alike however, you might find a similar Four Wheel Camper available used. A new camper like this will cost more than twice what the truck cost new in 1978.
A few pictures from a 9-day trip to the Mohave Desert and Death Valley earlier this year.
Old 08-05-2013, 06:35 PM   #50
24s
24s's Avatar
Thanks so much for info and great looking truck!!!
1990 Chevy 2500 Suburban D60/14 Bolt detroit lockers
