Old 05-30-2013, 09:25 PM   #26
RANDY COX
RANDY COX's Avatar
Re: Randy & Jakes 64 4x4 SLOW build
#2 Running click pix...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-30-2013, 07:00 PM   #27
RANDY COX
RANDY COX's Avatar
Well let's see I'm off all week and not going anywhere,So I need to get my but in gear and do some work on the ole truck....come on now people get me motivated.....
1964 BBC 402 4x4
Old 06-30-2013, 08:10 PM   #28
67swb72klb
67swb72klb's Avatar
so..make like a firecracker and get crackin !!!
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-02-2013, 08:08 AM   #29
RANDY COX
RANDY COX's Avatar
I did manage to work on the ole truck some but progress is slow,maybe it's me LOL.I'm using a donor door to patch some floor area.Don't worry this door gave up it's life to continue on..to be used somewhere else,it's all vintage metal...but suppose to rain all week here so until next time...
1964 BBC 402 4x4
Old 07-03-2013, 01:13 AM   #30
argonaut
argonaut's Avatar
Making some good progress my friend! That level of rust might scare me off but it looks like you've jumped right in and attacked it without looking back! Can't wait to see how it turns out.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 08-24-2013, 06:56 PM   #31
RANDY COX
RANDY COX's Avatar
Ok finally had some time to work on the ole truck,I got another grill cuz mine was tweaked a little,the top one was the one that came off of truck and the bottom is the replacement even though the top one looks better,oh well It's got patina.ALSO needed to work on the frame horns since the frame is a 70,so I cut the ends off to add the correct ones so I can put the bumper on.the header panel is tweaked,and of course one side of the radiator support is rusted out on passenger sideGot some patching to do on the fender wells near the front,got lucky and only rung off 2 bolts,The front end has never been apart,had to take a hammer and screw driver to chip away the undercoating,the battery box is perfect just needs to be cleaned and painted,I got more done in one afternoon than months considering all the rain and bad weather since the truck is outside..but I still got a long way to go,I'm gonna patch it up for now and prolly go ahead and get tags and put it on road to use as a back up vehicle.atleast if I get all the patching done then it will be easier to redo later...
1964 BBC 402 4x4
Old 09-02-2013, 07:57 PM   #32
RANDY COX
RANDY COX's Avatar
Woo-hoo got the driver floor-toe board all patched up and the rocker all welded up. got the door back on and now done pulled the passenger door and tearing out the rocker and the flooring, hopeing this side will go faster. someone has already replaced the lower fender section but they didn't replace the brace that the bottom of fender bolts to. got a long way to go. then I can start patching up the radiator support and the fender wells. Proly gonna need another hood as this one is pretty toast.. It'll do for now as it will be a while before I start on out side. Gotta replace door bottoms inner and outer, so I've got plenty to keep busy..
1964 BBC 402 4x4
Old 09-02-2013, 10:16 PM   #33
Jeff La
I'm glad your coming along, good to see things done I'm sure.
Jeff La is offline   Reply With Quote
Old 09-04-2013, 04:46 PM   #34
RANDY COX
RANDY COX's Avatar
Here's some latest pixs.Still have a few small quarter sized holes in the driver floor are and side of toeboard, And passenger side tore out PROGRESS,PROGRESS,PROGRESS....
1964 BBC 402 4x4
Old 09-28-2013, 09:31 AM   #35
RANDY COX
RANDY COX's Avatar
Gonna get out there today and work on the ole truck today.PROGRESS PROGRESS PROGRESS
1964 BBC 402 4x4
Old 09-28-2013, 11:00 AM   #36
argonaut
argonaut's Avatar
Hit it hard man! Show is the pics when you're done!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 09-28-2013, 09:03 PM   #37
RANDY COX
RANDY COX's Avatar
Just got to go back and grind welds and primer,very glad to get these done, still got to do rear cab corners and one of the rear floor supports.
1964 BBC 402 4x4
Old 10-05-2013, 06:26 PM   #38
RANDY COX
RANDY COX's Avatar
Got my Rad Support patched up
1964 BBC 402 4x4
Old 10-08-2013, 05:50 PM   #39
RANDY COX
RANDY COX's Avatar
Went out today when I got off work and cut the spot welds out of the front wells wish they made a patch for this area, sure would make life easier..
1964 BBC 402 4x4
Old 10-08-2013, 06:19 PM   #40
argonaut
argonaut's Avatar
You are a brave man, tackling all that sheet metal work!
I wish I had the body work talent to do that, and get it right.
Keep at it!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-08-2013, 06:43 PM   #41
RANDY COX
RANDY COX's Avatar
Thanks Jason, I don't claim to be a body man I don't mind tearing one apart as far as sheet-metal cutting and grinding and welding, It's that fine sanding primer and more primer and more sanding more primer. It's that fine tuning the body for paint. But in the end will be worth it. I've got close to paint on a lot of vehicles, then for some reason another I always have to sell and never see the end product, I vowed that I will finish this one. I'm getting too old to be starting all over again.
1964 BBC 402 4x4
Old 10-09-2013, 11:14 AM   #42
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Nice build!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-13-2013, 09:08 PM   #43
RANDY COX
RANDY COX's Avatar
Originally Posted by T.J. MCCAULEY View Post
Nice build!
Thanks TJ In post #31 you can see it has a later model radiator Just sittin there with no mounts or support on the bottom just sittin on frame so I cut a piece of flat stock and bolted across the frame rails and used some 1x2 square tubing with cutouts for bottom of radiator to sit in,Lined it with some split vacumn hose. So know it has support from bottom. Maybe it will last til I can get a new one the right one..Anywho that's one last thing to worry about..
1964 BBC 402 4x4
Old 10-13-2013, 09:51 PM   #44
RANDY COX
RANDY COX's Avatar
http://cdn1.bigcommerce.com/server40....1280.1280.jpg
Here's the tires I would like to put on the truck. It'll have that ole look..
1964 BBC 402 4x4
Old 10-19-2013, 07:28 PM   #45
RANDY COX
RANDY COX's Avatar
Well got the front end back on and buttoned up for now since winter is coming, I may have to put it on the road in case I need it, still got a lot to do. Just aliitle at a time.
Still have to work out the front bumper.
1964 BBC 402 4x4
Old 11-29-2013, 12:16 PM   #46
RANDY COX
RANDY COX's Avatar
Well not much work on the ole truck lately other than buying a hood my present to myself. rust free...
1964 BBC 402 4x4
Old 11-29-2013, 12:22 PM   #47
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
AWWWWWWWWW MAAAAAAAAAAAN! I am JEALOUS!!!!! LOL!!!! Wish I got a hood like that!!!!!
Old 12-01-2013, 05:21 PM   #48
RANDY COX
RANDY COX's Avatar
got my new hood on
here's pics of old hood
1964 BBC 402 4x4
Old 12-01-2013, 05:24 PM   #49
RANDY COX
RANDY COX's Avatar
I got to get a new park light harness. I bet there were atleast 5 splices from firewall to the lights.. Crazy man crazy.
1964 BBC 402 4x4
Old 12-01-2013, 05:28 PM   #50
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Drool drool drool and drool again....hope Santa gives me a hood like that! lol!
