01-15-2013, 12:05 AM | #26 |
Re: Aftermarket electric fan options for 55-59 pickups
the fan i have is a 16'' puller, the same fan and shroud that denee is using
i can't recommend a minimum cfm but i'd say that for a fan bigger is better this is the shroud i have in the parts4sale for a 16'' fan it is the same shroud that denee and i have on our trucks with one minor exception, the tabs are welded on the wrong edge
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-09-2013, 10:39 PM | #27 |
electric fan problem
Hey folks, ran into a little problem the other night. I bought a complete Spal 16" fan kit from Speedway. The kit includes thermal switch, wiring and relay. I ended up warming the engine up to 200 degrees...........the fan never came on. I checked the temp with an infrared temp gun. The thermostat is rated to come on at 195. I checked all the wiring, directions, grounds, power, etc. The fan physically works when the thermal switch is manually grounded to the battery. It seems the thermal switch is bad. Anyone else experience this before? I assume Speedway or Spal can help me get a new one.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
06-09-2013, 11:13 PM | #28 | |
Elev8r Man
Re: electric fan problem
If so, it maybe working although the sealant maybe preventing it from properly grounding. Sorry i dont mean to sound rude, it is a mistake i have made before.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!! 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
06-09-2013, 11:25 PM | #29 |
Hollister Road Co.
Ground the relay lead to the side of the switch. If the fan comes on its the switch, if not ground to the motor if it comes on it maybe tape on the threads, if it does not come on it maybe the ground to the motor.
06-09-2013, 11:49 PM | #30 |
Not sure if this sounds right...........
Originally I installed the switch with NO sealant of any kind. I was thinking that sealants would affect the grounding of it. I filled the radiator with coolant and found coolant seeping through the threads.........tightened it up a bit...........still seeping. Took it out and applied "indian head" gasket sealant. No more leaks If this type of sealant is affecting the grounding of it........how can I get a good ground while making sure the fitting doesn't leak?
06-10-2013, 03:33 PM | #31 |
Flex-a-lite in Fife makes a great switch and they are easy to install, they use sensor that slides into radiator fins. I have used tons of these and they work killer. I buy them direct and will continue to use them with my fans from pull a part, the fans that most aftermarket are designed after.
06-10-2013, 04:06 PM | #32 |
like dwcsr said; ground the sensor wire, the fan should turn on. if not you have a wiring problem.
you can check the sensor by immersing it in water on the stove with an ohm meter hooked to it you can check the water temp with a thermometer, the sensor should go to ground at 195* +5* if you have a 195* thermostat, hang it in the same water by a thread stuck in the opening part. when the thermostat drops into the pot, the water is 195* i would test it and if it's bad, you'll have some proof of badness otherwise speedway will think you fubar'd the wiring
06-10-2013, 11:28 PM | #33 |
I have verified that the sensor wire manually grounded does make the fan go on. I can also hear/feel the relay box "click". The wiring all looks correct and seems sound. It's just hard to believe the sensor threads are so sensitive to sealants of any kind if a lack of "ground" is causing the inoperative fan. I am wondering if some kind of grounding device can be attached to the sensor housing???
06-11-2013, 12:31 PM | #34 |
you must have a bad sensor
teflon tape can insulate the ground but i've never seen dope insulate the sensor
06-11-2013, 12:47 PM | #35 | |
Hollister Road Co.
06-11-2013, 03:54 PM | #36 | |
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
06-12-2013, 01:08 AM | #37 |
Update!
Tonight I was running my engine and allowing the engine to get warmed up in the range associated to the thermostatic fan switch. This time the darn thing came on! I continued to top off my transmission and tune the engine and again........the fan kicked on when it was supposed to. I let it do this several more times. I guess it just needed to be worked a few times? Works great now! This 16" puller really cools the radiator down fast.
06-12-2013, 01:29 PM | #38 |
good, glad it's working
