01-17-2013, 06:21 PM | #26 |
6>8 Plugless........
Re: She is back.
How good of quality is the rubber line they installed? I've seen rubber line sucked shut and not allow fuel to be pulled through it. Maybe you can try a piece of fuel injection rated fuel hose and see if that helps it. By the way, sweet Burb!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-17-2013, 06:29 PM | #27 |
Proprietor of Dale's Corner
Re: She is back.
I never thought of fuel line sucking closed but it's worth a try. Good thought Diesel. If this is the case that new fuel line must be terrible quality. I've also seen fuel line have a pin hole and suck air causing a symptom like this
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-17-2013, 06:40 PM | #28 |
Junior Member
Re: She is back.
I will try this if all else fails. It just sucks because I will have to drop the tank.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 01-18-2013 at 10:45 AM. |
01-17-2013, 08:34 PM | #29 |
Re: She is back.
It does suck, have ya called the shop that did it and tell 'em about it. Maybe they have an idea of where they messed up
01-18-2013, 10:44 AM | #30 |
Junior Member
Re: She is back.
I have been in contact with them and they have been very cooperative. I had taken the filter off Wed night and ran it without a filter to mark that off the list and it did not change things. At this point I had a fuel line in a gas can and it ran great. So last night I relaced the filter and little bit of rubber line and it fired up and I drove it around the block a couple of times. It got dark so I stopped messing with it after that since I do not have a garage. I am interested to see if it starts tonight when I get off work. It ran great Monday night and I ran it for probably 15 minutes while driving around but Tuesday it wouldn't start from the tank again. If it doesn't start tonight I am thinking the must be a hole in the line somewhere.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-18-2013, 11:08 AM | #31 |
Re: She is back.
Well good luck on it starting tonight, let us know how it goes.
01-19-2013, 11:47 PM | #32 |
Re: She is back.
Very nice burb
01-20-2013, 08:31 AM | #33 |
Re: She is back.
Swap the vent line and the fuel pickup line, maybe they hooked them up backwards....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-21-2013, 11:47 AM | #34 |
Junior Member
Re: She is back.
Well I took it into a different shop this morning because I can not figure it out. The truck started Friday night no problem. I woke up Saturday and drove it into town which is about a 15 mile trip and everything went fine. I came home and drove the family all around the area by the house. It was doing great but on the way back it seemed like it was starving for fuel so I just parked it for the night. I get up the next morning and drive into town and it dies once I get into town. I changed the fuel line from the hard line to the new filter thinking it was too short and kinked. It fired back up and I drove home and when I was almost there it backfired. I got it home and parked it. Later in the day I decided to take it for a drive to see if it would act up. I drove it a few miles and it died a couple of times but would start back up. I took it back home and decided I would take it to a new shop Monday morning. I got up this morning and while driving into town it back fires so bad it blew out my brand new muffler. They are going to check it out and let me know what the find. Thery are going to put a fuel regulator on it so they can get a reading. When I changed the fuel line to the filter the fuel came flying out of the line like there was a ton of pressure.
01-21-2013, 12:13 PM | #35 |
Re: She is back.
good luck
01-22-2013, 09:56 PM | #36 |
Re: She is back.
I know these types of problems are frustrating and I hope they get it fixed for you, nice looking burb and I'd like to have a roof rack like that on mine.
------------ Scott |
01-22-2013, 10:16 PM | #37 |
Junior Member
Re: She is back.
Thanks guys. I hope to hear something from them tomorrow.
01-22-2013, 11:05 PM | #38 |
C10 Club Tennessee
Re: She is back.
I'm guessing timing is off or the carb.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
01-23-2013, 09:38 PM | #39 |
Re: She is back.
Good luck with it. That sucks about the new muffler too.
01-23-2013, 11:32 PM | #40 |
A guy with a truck
Re: She is back.
At least it looks good!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-24-2013, 07:45 PM | #41 |
Junior Member
Re: She is back.
Thanks. I took it to the muffler shop and both mufflers were blown. It looked like a stick of dynamite went off inside one of them. It is now back at the shop so they can check it out. I had hoped to already have it back.
01-24-2013, 08:19 PM | #42 |
Re: She is back.
Did you change anything in the ignition at all? This is starting to sound spark related. I say this because Back when I was young (a long long time ago) we used to shut off the key while going down the road. We would wait a few seconds turn it back on and BOOM it would back fire. Sometimes blowing the mufflers up. Just a thought.
01-24-2013, 09:14 PM | #43 | |
Junior Member
Re: She is back.
01-24-2013, 09:24 PM | #44 |
67-72 parts collector,…
Re: She is back.
Carb floats set too high?
01-24-2013, 10:22 PM | #45 |
Junior Member
Re: She is back.
It is a stock 1406 Eldebrock out of the box. I do not think the first shop touched it so hopefully it just needs tuned. I am still thinking I have some sort of fuel pressure problem. I have had trouble getting fuel at times and trouble getting too much. When I was trouble shooting and changing the fuel filter as soon as I released the line it shot all the way up on the underside of the hood. I also am having a vibration in the driveline. I am planning to change gears so if it is the rearend I will not be upset. I am just hoping it is not the 700R4.
01-24-2013, 10:28 PM | #46 |
Re: She is back.
Search Edelbrock carb issues.
Lots of "out of the box" problems. Float too high. Won't take any more that 5.5psi. So a stock fuel pump that puts out 6-7 psi will need to be regulated down. Just a thought. I assume you have the correct gas cap?
01-24-2013, 10:40 PM | #47 |
Junior Member
Re: She is back.
Thanks for the info. They are going to put a gauge on it to check the fuel pressure. It is a vented tank and I even made sure I had a vented cap just in case. It is a fuel problem so it could very likely be the carb. I hope to hear something tomorrow.
01-25-2013, 12:27 AM | #48 |
Re: She is back.
Hey BB72CHEVKT ...
Just wanted to that is one sweet ride
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-25-2013, 12:43 AM | #49 |
Re: She is back.
Just letting ya know I'm watching let us know. I'm starting to think your flooding or losing spark intermittently. It will be interesting to see what they find
01-25-2013, 02:14 AM | #50 |
Re: She is back.
I had an inline filter along with the one on the carb. Took the one out of the carb and it fired up. I want to keep the inline since its see thru for a while so I can see if anything is coming out of the tank. I'll eventually take it out and go back to the carb filter.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
