04-22-2013, 10:39 PM | #26 |
Re: modified lca's (crazy?)
This mine. Drums in front. 3" cups welded into lower arms. Control arms are about 2" off the ground in this pic. I have 2" cpp modular drop spindles and brakes to install so it will lay on the ground when it's done. 215/70R15 front tires.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
04-22-2013, 11:17 PM | #27 | |
1971 chevy c10 cheyenne. Bagged. New paint and some other mods. 1999 ford f350 superduty 7.3 powerstroke everything banks 1975 c10 swb "parts runner" <----SOLD NorthWest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ |
04-23-2013, 04:30 AM | #28 |
Any backing plate issues with the spindles?
"its not a hobby, It's a Lifestyle" . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
02-07-2015, 10:55 AM | #29 |
If your aired out in this picture something must be wrong ??? It still looks like you need a step ladder to get in the thing. Look at the next picture of the guy in the blue and white truck, that's what you should look like aired out.
02-07-2015, 11:23 AM | #30 |
You talk about safety but hacking up a-arms and re welding them ? I,d hate to see that go bad on the freeway.
02-07-2015, 02:10 PM | #31 | |
No worries, fairly old thread. I have learned a lot since I posted this. I actually run my own thing bagging cars and trucks now. Funny how that works out lol Here what it looks like now. Only 2.5 - 3 staggered cupped lowers to keep the bag symmetrical when at ride height Still doesn't lay rockers but the body drop will fix that
02-07-2015, 08:44 PM | #32 |
Never Ending Projects
Back 20 years ago, there was no dropped spindles for pre '72 trucks. I had bought dropped A arms from a company called SoLow Suspensions (long gone). They worked great. Now I do dropped spindles for everything.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-16-2015, 04:08 PM | #33 |
Funny that this old thread came up. I'm actually modifying my lower and upper control arms now, like the one in Chevy Mike's picture above.
If they work out, great. If not, all I've lost is some time, welding wire, Argon. I can throw them away and buy new arms. I'm doing the lowers 2" with a correct angle, and the uppers also 2" to resolve ball joint binding. I don't have any pics yet because they're just tacked now but I'll update my build thread when they're closer.
____________________________________________ My build thread: Project Moonshiner Bagged & Z Frame 63 http://67-72chevytrucks.com/vboard/s...d.php?t=659205 "I love the smell of grinding metal" |
02-16-2015, 05:58 PM | #34 | |
the stock wheel?
1967custom |
02-16-2015, 07:47 PM | #35 | |
The stock wheels, iv been trying to find more stock steel 6 lugs and apparently they are impossible!
02-21-2015, 07:17 PM | #36 |
Hey Robert, you need to come by my place and check out how I'm doing the new build on my c10. I have been modifying a lot of stock stuff. I have gotten 5 1/2" of drop with out touching springs in the front. For everybody else, sorry I don't have pictures yet.. i haven't uploaded any on the computer.
02-21-2015, 09:49 PM | #37 | |
I'm game bro, just let me know when your in town and I can swing by.
02-23-2015, 01:35 PM | #38 | |
To prove this I have a '64 VW with all factory manual, single circuit drum brakes. Only upgrade is it has wider/sticky 195 wide tires instead of the stock 165 wide tires. From 60 mph it will peak at .97g stopping, right at the limit of locking up. Even with the grippier tires I could still stab the pedal and lock up the front wheels if I wanted. I also have an '87 Mitsubishi Starion that has 205 and 225 wide tires, and four wheel power disc brakes and rear-only ABS. Looking back at the old Auto Week tests (and others) from when the car was new, it had some of the best brakes available when tested against the other Japanese sports cars it compared to. It also has an old set of tires that were on it when I bought it that don't have a lot of grip. The best I've been able to get is .87g max; it's much harder to keep it from locking up, and its not as easy to recover after they've locked up as the VW. We used to have a '99 New Beetle with fairly grippy 195's and four wheel discs with ABS. It would peak at .99g, only .02g better than the '64 VW with manual drums. I'm not saying disc brakes aren't good at all- they offer less upkeep and easier to change pads compared to changing shoes. From higher speeds they do better for sure. But a good drum system with good tires can be just as good (and just as safe) from normal speeds. __________________
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
02-23-2015, 02:03 PM | #39 | |
love the scallops
1967custom |
