Old 12-11-2017, 09:43 PM   #26
a32axo
Re: 2.25" Leaf Spring Flip and Upgrade
What’s up all, so I just did a flip kit, I left shocks installed where they were and I got a lot of axle hitting, so I relocated them just like u said to the other hole, now it lifted it higher but no axle hitting. The ride is now super stiff any help?
a32axo is offline   Reply With Quote
Old 12-11-2017, 09:49 PM   #27
sKnNyPpY
sKnNyPpY's Avatar
A little extra weight in the back helps as does a rear strut bar. Leaf back is gonna be tight though. Glad your not hitting! I put the cpp rear bar on and it handles better with a little less bump but not much.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 12-11-2017, 09:54 PM   #28
a32axo
Cpp rear bar? Do I need to change the shocks to front shocks?
Old 12-11-2017, 09:57 PM   #29
sKnNyPpY
sKnNyPpY's Avatar
If you are running original shocks yes, they will be too tall and be bottomed out. The easy way is run front shock legnth, but search drop shock legnth on the board for better info. I just did the same front and back.
Old 12-11-2017, 10:00 PM   #30
sKnNyPpY
sKnNyPpY's Avatar
Look at clp-cp7402u-blac at summit racing for the rear bar
Old 01-04-2018, 02:42 AM   #31
a32axo
So put front shocks on rear and now it hits again. Not enough support. How can I fix this with out c notch
Old 01-04-2018, 07:47 AM   #32
sKnNyPpY
sKnNyPpY's Avatar
If it was working with the other shocks I'd just switch back. There is a proper way to measure, I've just never bothered. Search the forum.
Old 01-04-2018, 10:09 AM   #33
a32axo
I measured rear shocks at 18.5 and front shocks at 15.3 so I’m guessing I need something in between. Will that work?
Old 01-04-2018, 11:57 AM   #34
SCOTI
SCOTI's Avatar
What exactly are you measuring when you "measured rear shocks and front shocks"?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-04-2018, 12:27 PM   #35
a32axo
Website measurements when fully expanded
Old 01-04-2018, 03:59 PM   #36
SCOTI
SCOTI's Avatar
You need to know the shock length you require.
Take a measurement between the upper & lower mounts (w/full weight on the vehicle). Then look for a shock where that measurement is as close to the midpoint of the fully extended/fully compressed dimensions.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-04-2018, 06:29 PM   #37
a32axo
With truck fully dropped no shock, measurement is 11.5 inches so what size shock I need?
Maybe the front shock needs to be more heavy duty? Ther rear shock that was installed before was Kyb gas adjust stock shock for rear. It was a really bouncy bumpy ride.
Old 01-04-2018, 07:57 PM   #38
SCOTI
SCOTI's Avatar
I'm not a fan of the KYB Gas-A-Just line of shocks because the ones I've messed with (on C10's & G-body Malibus )were way to stiff/harsh. RCD (Race Car Dynamics) used to offer re-valved Bilsteins but I just chacked their site & they don't list info/dimensions like they used to.
Now that you know your ride height shock dimension, I would add/subtract 3-3.5" from that dimension for your searches. So look for these approximate dimensions:
8" fully compressed
11.5 ride height (mid point)
15" fully extended
Ride tech has some NICE shocks (HQ Series) that are adjustable for rebound so you could dial them in to suit your exact needs. They have a killer warranty but are expensive vs. off the shelf/non-adjustable shocks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-04-2018, 08:04 PM   #39
a32axo
8" fully compressed
15" fully extended
So basically that’s a stock front shock size
Old 01-04-2018, 08:34 PM   #40
SCOTI
SCOTI's Avatar
It's close. Seems I recall 10.5" @ midpoint but that's based on my Bilsteins. Different mfr's do have different dimensions.
Off the shelf shocks might have different valving based on the shocks spec'd position (front or rear). You're options:
A) Some adjustable shocks w/close dimensions.
B) Fab up some different shock brackets to allow the correct app shocks to fit/work.
C) Search catalogs for shocks that have similar dimensions/mounts that should work w/your set-up. If you find some, it could be trial & error on how 'well' they work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
