Old 01-23-2014, 11:30 PM   #26
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Alright chummins or stick with chevy???
Looking good! I have a couple 2wd core transmissions. One is supposed to be good, but how good, IDK. I removed the top plate and everything looks good in it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-28-2014, 11:26 PM   #27
Ryan Duke
Got a little done with cutting, also stuffed her back in and started drawing on the frame rails to cut out for the steering pump and the A/C compressor. I think I found a way to make some stock mounts to work!
Ryan Duke is offline   Reply With Quote
Old 01-29-2014, 08:20 PM   #28
Dieselwrencher
Looking nice! You're going to have the engine way down there.
Ryan
Old 01-29-2014, 09:18 PM   #29
ryanroo
ryanroo's Avatar
Thats how the cool kids do it!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-30-2014, 01:23 PM   #30
vegadesign
vegadesign's Avatar
Hell yeah! Makin some progress, looking good!
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 01-30-2014, 11:35 PM   #31
Ryan Duke
I have off on Friday so now I cant get something done!!!
Old 02-01-2014, 12:24 AM   #32
Dewey72
Love to see all this. I'll put a Cummins in anything!
Name:  72 chevy 001.jpg
Dug fresh out of the scrap bin. Converted my nv4500 to 4x4. Its not the new updated shaft with the spilt collar but was in the trash. Mounting holes could use some work.
Dewey72 is offline   Reply With Quote
Old 02-11-2014, 08:25 PM   #33
Ryan Duke
well i dont know yet how to put text over each picture so i have to talk about a little ahead of time. I managed to get some crap done. front end boxed in, engine craddle boxed in, motor mounts made, tore the tranny down so it was lighter to mock up.
Old 02-11-2014, 08:30 PM   #34
Ryan Duke
Oh by the way my welder is so much nicer when i have the right gas! I'm going to take all the good news I can, so when i saw where the tranny sat and realized im not going to have to touch the fire wall or floor I drank a beer with a smile! Anyone have a good idea what kind of pitch i should have with the drive shaft?
Old 02-11-2014, 09:15 PM   #35
legendman
legendman's Avatar
Another Cummins swap in progress Nice!!!
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 02-11-2014, 10:17 PM   #36
ryanroo
ryanroo's Avatar
how close are the engine mounts to the framerail? looks real close in the picture. the OEM rubber will tear on a lot of trucks, making them move more than they otherwise would. if the mount is to close, you may have some sweet sweet love being made.
also, i do not know if the dodge mounts are cast or forged, but i would be they are a casting. i am curious about the method used when welding them to the mild steel plate. if not done correctly that may cause an issue down the road.
72 K20 12v build
Old 02-12-2014, 12:09 AM   #37
Dieselwrencher
To address the movement of the mounts mentioned by Ryanroo, you can get poly bushings to press in the centers that help a lot with the vibrations. Those mounts are cast and I would be very careful of doing them that way unless you preheated those cast pieces before welding them. I'd hate to see one of them brake on you during a road trip or something. Also, since you cut your cross member so low, why not bring the engine down to utilize all that room? It might require pan clearance issues, but your drive line angle may be better if you plan on lowering the truck in the future. On driveline angle I try to get it close to 3* on the shaft.
Ryan
Old 02-12-2014, 10:58 AM   #38
Ryan Duke
well i would love to use a diffewrent style mount for sure cause i heard about the stock mounts, but when i was looking for different mounts nothing seemed to look like it would work! any ideas?
Old 02-12-2014, 04:47 PM   #39
Dieselwrencher
Here are some options. First, on 24v dodge cummins engines, they have a short and long mount. Get a couple short ones and see if you can use them. Here is my 76 when I re did the engine mounts.
Here I used poly first gen dodge cummins mounts on a 89 V2500 suburban. These mounts can be used in your set up pretty easily.
If you want to prepare for bigger power, you can put 2 per side.
Some people use stock SBC clam shell mounts, but I feel they aren't strong enough and allow the engine to vibrate excessively.
You could also use t bushings like Ryanroo used on his truck as well.
Ryan
Old 10-07-2014, 11:11 AM   #40
Ryan Duke
Whoow its been awhile. A little update for everyone. I got my mounts I think figured out. I also picked up new front fenders. A different box. Vintage air. Tubular a arms disk brakes stainless lines all around.
Old 10-07-2014, 05:56 PM   #41
Dieselwrencher
That's looking pretty nice! That bed looks mint!
Ryan
Old 10-08-2014, 01:48 PM   #42
Ryan Duke
Does anyone know how to change the title of my thread. Its pretty clear I am not using the chevy motor.
Old 10-08-2014, 08:58 PM   #43
Dieselwrencher
What would you like it to say? I can change it for you.
Ryan
Old 10-09-2014, 12:40 PM   #44
burnin oil
Back to the gear ratio thing. Stick with what Dodge offered. I would reuse the rearend of the donor truck. The highest gear Dodge hooked the Cummins to was a 3.07 gear in a Dana 61 axle and that ratio is not available anymore. This setup also did not have an OD trans. Most in the second gen body style had 3.55s . Combine that with your .75 OD and it is still a pretty good ratio setup for milage. My twinned 2500 Dodge 4x4 12v had this ratio, pushed 700hp at the wheels, and still got 18.5+ MPG on average. Some of the newer trucks got a 3.42 in the A&M axle but alot of them had 3.73 or 4.10s.
burnin oil is offline   Reply With Quote
Old 10-09-2014, 11:33 PM   #45
shopteacher
Holly Crap another 2WD Chevy with a CUMMINS !!
Subscribed!
I like the idea of cutting out the cross member to get it lower, but I think mine will be low enough with the mounts I got from Auto World in MT. I have to kick my self in the arss and get busy with the replacement of my rocker panels.
Greetings from south west Idaho!
Rock On!!
shopteacher is offline   Reply With Quote
Old 02-24-2016, 12:10 PM   #46
Ryan Duke
Holy crap its been a year and a half since I've last posted!!!!
Im working on steering now and the link from the pitman arm to the idler arm is in the way of my engine pan, does anyone know if I can run a dropped pitman arm and idler arm from a lift kit with a truck that's not lifted? that would drop the whole thing out of my way im just not sure if it safe?
