Old 09-05-2013, 12:05 AM   #26
Irishbleueyes
Re: Just finished cutting my TREX bed wood!
Originally Posted by jayoldschool View Post
Went well. Thought TREX would be a great choice for a truck that will sit out in the elements. Got a great deal on overstock that was sitting unused outside. Used the dimensions from GMCPaul's site. This is for my LWB 65 C10 Fleetside. The boards were 1"x8"x12'. Took about three hours total for measuring, cutting to length, ripping, and grooving. Boards were cut to length with a circular saw, but all other dimensions were done with a radial arm saw (ripping blade, and a dado blade).
Can't wait to install it!
Wood, non-polished strips/bolts will be a nice upgrade:
Im pretty sure if those boards are left wet for an extended period they will absorb the moisture and they will expand. It happened on a deck I built and it buckled bad. Trek say they are waterproof or water resistant? Maybe use a sealer just to be safe..
Irishbleueyes is offline   Reply With Quote
Old 09-05-2013, 02:59 PM   #27
jayoldschool
Moderator
Thanks for the heads up. Hopefully, they've expanded as much as they are going to. Those boards have been sitting outside for a few years, buried in snow in the winter. I think they'll be ok. I bought them from my country hardware store that had old extra stock.
jayoldschool is online now   Reply With Quote
Old 09-05-2013, 03:45 PM   #28
Sharps40
I bought the cheep trex copy boards, it says no worries. They are intended for fascia and trim but no coating is recommended. No movement yet and I expect none since the point of this type of material is to be very very stable. I wouldn't worry bout it movin due to moisture. Afterall, its pop bottles and sawdust....not much in the way of long sections of wood grain left to expand or contract.
Sharps40 is offline   Reply With Quote
Old 09-05-2013, 04:31 PM   #29
forestb
forestb's Avatar
Is there a way of staining this stuff to make it look nice without effecting the durability?
forestb is offline   Reply With Quote
Old 09-05-2013, 05:43 PM   #30
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Most of the things you can do to it won't really affect durability, aside from things like the Hazing and cracking I've seen occur ONLY IN THE FINISH when some really thick shalaq type stuff was used.
Its just a little harder to prep than wood, since it does absorb somewhat, but not nearly how wood does.
I'll be coating mine with Raptor liner, so I'll have Urea-covered-recycled-plastic-faux-wood....making my faux bed.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-05-2013, 08:14 PM   #31
ChefCy
ChefCy's Avatar
that look great!! i might have to consider this option as well
63 big window lwb bagged and shaved
ChefCy is offline   Reply With Quote
Old 09-06-2013, 12:50 AM   #32
chopper john
chopper john's Avatar
man that looks great. im doing that next
chopper john is offline   Reply With Quote
Old 09-06-2013, 12:33 PM   #33
gofastnut
gofastnut's Avatar
As I said, it looks great!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 09-12-2014, 07:40 PM   #34
jayoldschool
Moderator
Just realized I never posted a pic of the finished project...
Old 09-17-2014, 01:08 AM   #35
Iron-Butt
454 club
Iron-Butt's Avatar
it looks nice.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 09-17-2014, 10:29 AM   #36
earl84
Thanks for the finished pic, that looks great. I milled my own pine and swore I'd never do that again, lots of work. But at the time, I had more time than money and it was very gratifying. If this wears out any time soon, I'm going to mill up some Trex just like yours.
earl84 is offline   Reply With Quote
Old 09-17-2014, 11:06 AM   #37
JWheeler331
JWheeler331's Avatar
Looking good.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline   Reply With Quote
Old 09-17-2014, 11:07 AM   #38
JWheeler331
What did you use to countersink the frame bolts?
Our 1965 Build
Old 09-17-2014, 01:08 PM   #39
scuderia
scuderia's Avatar
in the process of installing new bed in mine and this is what i just purchased..
http://www.ebay.com/itm/Steelex-D285...E:L:OC:US:3160
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 09-17-2014, 03:09 PM   #40
jayoldschool
Moderator
I drilled the mounting hole through, then used a spade bit the same size as the washer to drill the countersunk area, offset. It took a steady hand.
Old 09-17-2014, 03:58 PM   #41
JWheeler331
Thanks yall.
Our 1965 Build
Old 09-17-2014, 08:17 PM   #42
jayoldschool
Moderator
I forgot to add one step. Once I had the mounting hole drilled, I placed the washer over the hole (holes lined up). I then used a pencil to trace the outline of the washer location on the wood so I knew where to cut out with the spade bit. The tip of the bit wanted to walk over into the bolt hole, so I had to keep steady sideways pressure on it to not chew anything up.
Old 09-17-2014, 09:11 PM   #43
66 Burban
66 Burban's Avatar
Suggestion: do the c'bore first with forstner or spade bit and then use the center created by c'bore to drill the thru hole. Should eliminate walking of c'bore bit.
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 09-17-2014, 09:24 PM   #44
jayoldschool
Moderator
The problem with that is the through hole doesn't go where the center of the spade bit goes.
Old 09-17-2014, 10:42 PM   #45
earl84
Check this out for how to drill offset holes. http://www.mar-k.com/Catalog/PDF/Ins...s_3-8_ofst.pdf
Old 10-08-2014, 11:05 AM   #46
Lokin4AReason
Lokin4AReason's Avatar
were these pre cut or did you cut them ...??
Lokin4AReason is offline   Reply With Quote
Old 10-08-2014, 12:00 PM   #47
jayoldschool
Moderator
I cut everything myself, using a radial arm saw, sideways. One blade to cut the groove, dado blade to shave down the lower part next to the groove. It actually didn't take long to do everything, less than two hours. I used the GMC Paul's dimensions.
Old 10-08-2014, 02:08 PM   #48
Lokin4AReason
i will have to do a bit of homework in deciding than on the material i can use ...
im just looking for 0 percent maintenance/ up keep on it, something composite ..
dont want to hear excuses, i want to hear solution(s)
Old 10-08-2014, 02:28 PM   #49
gsxrdoug
1970 C10 six
gsxrdoug's Avatar
That is a great idea! Never have to worry about that stuff. Was it hard to work with?
1970 C10 L6 250 three speeder
gsxrdoug is offline   Reply With Quote
Old 10-08-2014, 06:56 PM   #50
jayoldschool
Moderator
Ridiculously easy to work with. Cuts fast. Way faster to cut and drill than wood. ZERO maintenance. No finish. It sits out in the rain. It sits out in the snow. It looks the exact same.
