Old 07-24-2013, 09:05 PM   #26
Lugnutz65
Lugnutz65's Avatar
Re: newb needs advice
You might not need all of this stuff, but it's just a quick budget for brakes. Using Autozone, NAPA, Advance parts etc.
Front and Rear brake shoes = $50
All new Spring Kit Front and Rear = $20
Wheel cylinders X4 = $50
Brake hoses X 3 = $50
New Master Cylinder = $20
Brake fluid = $10
So far that's $200
O'Reilly's can turn drums if they are in good enough shape to turn. Otherwise add another $30 per new wheel drum.
New brake lines and fittings will add quite a bit of cost too, but you may not need them. Pre-bent brake lines will run about $240 but if you can make your own, you could do it for under $80.
Also, I'd recommend upgrading (when you can) to a safer dual master cylinder.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-25-2013, 05:22 PM   #27
X Army MP
Originally Posted by 19666Trucker View Post
Welcome to board, and when get to phx, az hit me up man.
When I find a good enough job ill be moving. I'll deff will hit you up
I have TBI, PTSD, & no regrets
X Army MP is offline   Reply With Quote
Old 07-25-2013, 05:30 PM   #28
X Army MP
I still can't figure out how to post pics from my phone. I think my fuel pump crapped out on me right after I drove 90+ miles back home. No fuel is getting to the carb. I removed fuel line that connects to the fuel filter and I'm getting nothing. I pulled the cover off the fuel pump and it is full of fuel. Fuel pump is on order and won't be here till at least Tuesday. This sux. I just get a new toy and I don't get to play with it for a few more days. I've been looking around and I suppose no one carries 48 year old fuel pumps.
Old 07-25-2013, 05:43 PM   #29
JWheeler331
JWheeler331's Avatar
Hope you figure out the pics soon. The link don't show it anymore and is love to see it. Congrats on the new truck.
JWheeler331 is offline   Reply With Quote
Old 07-25-2013, 07:12 PM   #30
cortcomp
cortcomp's Avatar
"Pre-bent brake lines will run about $240 but if you can make your own, you could do it for under $80."
Inline tube has the entire pre-bent brake line kit for about $140 shipped. That's standard, you can pay more for stainless, and that's not including the three flex hoses.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-25-2013, 07:45 PM   #31
Sharps40
Nice stepper. Looks like it'll make a fine daily driver. Small six with AC might be slow though.
That looks like a V8 radiator, like I put in mine.
Also looks like a V8 air cleaner on the intake...make sure it fits the carb right/seals up so it actually filters.
Tell us how it runs.
Enjoy!
Sharps40 is offline   Reply With Quote
Old 07-25-2013, 09:56 PM   #32
R_W
R_W's Avatar
Could also be junk in your tank. Sometimes crud pulls up and gathers around the screen on the intake inside the tank. Fuel pump is easier if that fixes it...
______________________
"Daddy, that truck's not red"
Build Thread: TN 20 Build
R_W is offline   Reply With Quote
Old 07-26-2013, 06:17 PM   #33
X Army MP
Brake fluid = $10
So far that's $200
thanks
Old 07-26-2013, 06:58 PM   #34
X Army MP
at first i got no fuel to the carb so i checked the fuel filter. it was clean
so i pulled the fuel line to the filter. i tried to start it and no fuel was flowing. so i followed fuel line to the fuel pump. i removed the fuel line on the back side of the fuel pump. no fuel was leaking from the pump. so i took off the fuel pump cap and fuel was in it. i removed and took apart the fuel pump. i cleaned a little and put it back together. after i hooked the inbound fuel line i was getting fuel leaking from the out bound side. i put the fuel line back on and tried to start it and still im not getting fuel to the carb. any advice or tricks? i have a new fuel pump on the way. it will be here tuesday
Old 07-28-2013, 08:09 PM   #35
X Army MP
I hope this works. This the truck i bought
Old 07-28-2013, 08:10 PM   #36
X Army MP
https://m.facebook.com/home.php?refs...ser=1087242776
Old 07-28-2013, 08:11 PM   #37
X Army MP
Old 07-28-2013, 08:44 PM   #38
jtrichard
Don't see any pics ... as for fuel prob you started at the wrong end ....first pull the line off of the inlet end of the pump take the gas cap off and blow in the tank and see if any gas runs out of the line to the pump if none then your dip tube in the tank is plugged if the screen is still on the dip tube it is most likely plugged.... i have a 63 C60 dump truck with 396 and some kids threw some balloons in the tank and there is no screen on the dip tube and the pump pulled the balloons up the tube about 2" till it could not pull any more and it stopped running)
jtrichard is offline   Reply With Quote
Old 07-28-2013, 09:02 PM   #39
X Army MP
I got fuel to the fuel pump inlet. If I remove the fuel line it flows through the pump onto the ground. I removed the line to the filter and I filled a water bottle and poked a hole in the cap and forced water through the line and it was clear. I've done all I could think of to get fuel to the carb. I got a pump coming tomorrow from rockauto.com. let me know if I'm missing something
Old 07-28-2013, 09:21 PM   #40
jtrichard
if it flows through the pump (with out pressuring the tank) then you have no valves left in the pump .. a new pump should solve it all for you
Old 07-28-2013, 10:08 PM   #41
X Army MP
Thumbs up Re: newb needs advice
Ya im not pressuring the tank just gravity feeding. Thanks for confirming. I'm glad my first part I have replace is going to be easy.
Old 07-29-2013, 08:59 AM   #42
X Army MP
the fuel pump that's causing the problems
http://s1285.photobucket.com/user/XA...cb4c8.jpg.html
high speed low drag 6 hamster powered engine
http://s1285.photobucket.com/user/XA...2d206.jpg.html
http://s1285.photobucket.com/user/XA...tml?sort=3&o=1
http://s1285.photobucket.com/user/XA...tml?sort=3&o=0
at the dealership
the finance guys college world series ring when he played for OU. he was a one armed right handed pitcher/outfielder. way cool guy.
after the test drive
Old 07-29-2013, 09:53 AM   #44
MitchFloyd
MitchFloyd's Avatar
Nice truck! Sorry to hear bout the fuel pump problems, but should be a quick & cheap fix for you. And let you get your hands dirty on the lil girl. That six is a great motor, with a little tuning, points / coil / plugs it'll run practically forever & gas milage won't be too bad either! Check out John Lee's thread on tuning a 6 cyl.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 07-29-2013, 08:40 PM   #45
19666Trucker
19666Trucker's Avatar
That rear bumper is awesome that is nice truck.
19666Trucker is offline   Reply With Quote
Old 07-29-2013, 08:55 PM   #46
X Army MP
I've seen a bumper like this last week in Norman on a 2nd gen c10. If someone tries to rear end my they will get the smelly end of the stick. I have been thinking of replacing it with a stock one from lmc. I don't know. I'll leave it on for a while and see if it grows on me
Old 07-31-2013, 07:53 AM   #47
X Army MP
Yesterday the fuel pump came in and now she's running like a champ.
Old 07-31-2013, 10:32 PM   #48
R_W
R_W's Avatar
Old 07-31-2013, 10:38 PM   #49
19666Trucker
Awesome, leave the bumper or at least till down in phx.
