10-16-2013, 05:01 PM | #26 |
Re: Track70 Build!!
do you have any photos and info on your rear shock setup? is there a arm that goes from trailing arm to trailing arm?
10-16-2013, 05:45 PM | #27 |
Re: Track70 Build!!
Really liking this build. I might have to borrow your radio delete idea as well.
So that style of radio will fit right in the heater control area... hmmmm... Might just have to take a page out of that book as well..lol
71 swb 350/4sp manual 5/7 static drop |
10-17-2013, 02:34 AM | #28 | |
Re: Track70 Build!!
And Thanks guys..I really having fun with it..It will be going under the knife again soon for stage 2 of my build.
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761 King's Speed Shop |
10-18-2013, 10:18 AM | #29 |
Re: Track70 Build!!
Very cool truck! I see you've added a sway bar out back. Details on that? Gonna do a rear shock relocate? Check out post #311 on this thread...
http://67-72chevytrucks.com/vboard/s...te#post6290439
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
10-18-2013, 12:34 PM | #30 |
Re: Track70 Build!!
Truck looks great! I didn't see you at CTC.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-19-2013, 01:23 AM | #31 |
Re: Track70 Build!!
Rob, I was only there all day Friday and we spent most of are time at the swap meet..only cruised around and stopped at the Mall for a couple hours..Was on the look out for you though and Bucks68 C-10!
12-28-2013, 08:41 PM | #32 |
Re: Track70 Build!!
Well guys it's been a little awhile..I have been busy moving into a new home with a garage so i can really get some stuff done! Anyways i have also been busy on Track70 also getting it ready for Stage 2 of my build which you will see what that is shortly.
Got the truck up in the air and pulled the drivetrain out for a rebuild! Got the motor torn apart and ready for new goodies! And a little sneak peek of what's to come! Now i just have to start cleaning up everything and get it put back together before the show season starts back up in March!
12-29-2013, 02:13 AM | #33 |
Re: Track70 Build!!
Lookin good bro! Keep the pics coming...
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
01-26-2014, 08:22 PM | #34 |
Re: Track70 Build!!
NEW UPDATE!!
Got my power steering pump ready for install..thought id take a pic of the difference! LETS BUILD A MOTOR I fully tig welded up my Melling oil pickup just so i can sleep better at night lol Got the bottom end buttoned up and installed new rebuilt heads. Cam specs are Comp Cams .490 Lift and .224 Duration. And of course ARP head bolts! She always tells me i need to wash the dishes..so i did Got the new rockers and pushrods in..I went with Comp Cams 1.52 Magnum Roller Tip Rockers and one piece pushrods. After i got the valves adjusted i installed the intake and set the carb and valve covers on for a picture! Still got a lot more to do before it gets dropped back in..Will keep y'all updated!
01-26-2014, 10:52 PM | #35 |
Re: Track70 Build!!
Bee Eee Aye youtiful!
Is that antifreeze on the heads?
01-27-2014, 12:50 AM | #36 |
Re: Track70 Build!!
No that is Oil mixed with some royal purple assembly lube.
02-01-2014, 09:39 PM | #37 |
Re: Track70 Build!!
Well since the motor is about complete i thought id start on the suspension!
Got the bed off and ready for some cutting. Also got my newly rebuilt pedal assembly with Clutch pedal installed..I Did a little pretend shifting with motor sounds to get full affect hahahaha!! Next I'll get the notches installed and mock up the air bags.
02-01-2014, 11:10 PM | #38 |
Re: Track70 Build!!
Looking Good, going to be a nice ride when you're done....
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
02-24-2014, 12:07 AM | #39 |
Re: Track70 Build!!
Been busy with work and side jobs but finally got some work done on Track70
Got the frame cut for the notches and ready to weld, And since of course I'm a welder by trade..I thought id weld them completely up..Plus it looks cleaner with no bolts showing! After all that welding i got the Slam RE7's mounted up and seen how low she's gonna go..Might have to cut the bed floor! And While working on the rear the front bag brackets showed up from thorbecke brother's.. More work for me i guess!!
02-24-2014, 11:24 PM | #40 |
Re: Track70 Build!!
Some gorgeous welds there!
02-25-2014, 12:40 AM | #41 |
Still Learning
Re: Track70 Build!!
Love all the new parts. Very nice progress on the chassis too.
02-25-2014, 01:37 AM | #42 |
Re: Track70 Build!!
Very clean work dude! Motor looks awesome and the c-notch job is perfect! What are your thoughts on strength at the notch? I'm not sure If I'll need to notch mine or not. I've got the upper shock mounts behind the axle on both sides so I feel like I shouldn't notch it if I don't have to.
02-25-2014, 06:41 AM | #43 |
A day late and $1 short...
Re: Track70 Build!!
Sweet build bro! Making some great progress, keep it up.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
02-25-2014, 01:37 PM | #44 | |
Re: Track70 Build!!
Thanks!
Yea new parts always makes me happy until i have to install them. Quote:
Thanks Buck! Hopefully i can get the front bags in and somewhat plumbed up this weekend..Then i can take the jackstands out and lay her out
02-25-2014, 07:55 PM | #45 |
Re: Track70 Build!!
Coming along nice... Good looking welds by the way.
04-06-2014, 02:35 PM | #46 |
Re: Track70 Build!!
Well it's been a couple months but Track70 has been seeing a lot of love!
Got the Frame completely cleaned and painted and finally installed everything back on for the final time. Also got the front suspension done with the new blue powder coated MMW arms and the thorbeck bros. air bag brackets. New Ram Clutch and Flywheel were installed..Along with a aluminum Camaro bellhousing! Now my Favorite part..Motor going back in. After motor was dropped in i went and picked up the transmission from the rebuilder..all new on the inside and a fresh coat of paint on the outside!
04-06-2014, 02:54 PM | #47 |
Re: Track70 Build!!
Looking good! PM me a contact number and next time some board members from the area get together I'll shoot you a text.
04-06-2014, 03:11 PM | #48 |
Re: Track70 Build!!
Thanks!...And will do that sounds great.
04-06-2014, 06:31 PM | #49 |
Re: Track70 Build!!
Looks like your making good progress.
04-06-2014, 07:43 PM | #50 |
Re: Track70 Build!!
Nice build, keep up the great work!
Scott Daily Driver:2010 Z71 Ext Cab Project:1972 C10 SWB |
