Old 01-15-2014, 09:12 PM   #26
84GMC15tepside
84GMC15tepside's Avatar
Re: Project 66: Stickin' With The Stepside
Here's the engine and the transmission. Shifter is now on the transmission and the engine is being put together as of now...
MY6 Stepside
84GMC15tepside is offline   Reply With Quote
Old 01-16-2014, 08:33 PM   #27
Hankster
Hankster's Avatar
Nice looking build you got going! I like the story!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 01-17-2014, 12:09 PM   #28
walkerb
walkerb's Avatar
Just found your thread. Nice work
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 08-26-2014, 10:01 PM   #29
84GMC15tepside
Alrighty, Haven't posted here for awhile, some updates:
My main focus this summer has been to get the engine/tranny in the truck and test run it by the end of the summer. So I got many parts from summit, local shops, etc to button up the engine. I think I have more pics but this is currently what I have: Engines in!
MY6 Stepside
Old 02-04-2015, 07:41 PM   #30
84GMC15tepside
Definitely posting updates soon, engine is close to running. I also bought suspension bushings, balljoints, etc. I decided on lowering the truck with spindles and cut springs up front and a flip kit in the rear. Slowly but surely getting there.
MY6 Stepside
Old 03-10-2015, 09:32 PM   #31
84GMC15tepside
I am putting the finishing touches on the fuel systems, installing the rubber connection lines, and now I am working on the cooling system. Mocked up the core support to test fit the fan shroud.
The fan shroud seemed to fit really well with half of the fan in and half of the fan out. Nothing has been bolted down, ordering proper hardware from LMC this week.
Will get in some updates on the suspension once I take pictures of course
MY6 Stepside
Old 03-12-2015, 10:56 AM   #32
gmclowsierra
what are the measurements of the fan shroud. height wise or do you know what size your radiator is?
gmclowsierra is offline   Reply With Quote
Old 03-12-2015, 03:20 PM   #33
NewType72
NewType72's Avatar
Looking forward to the engine fire video! Someone must be excited
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 03-12-2015, 05:55 PM   #34
84GMC15tepside
It is a v8 blazer fan shroud. Backside:
Measuring the "box": 27.5"width at the top X 20.25"height. On the backside, from top to bottom is 21" for height.
I am temporarily using (trying to at least...) a new 1 row (6cyl) radiator that I got for the truck when it had the inline, and did not install before tearing down the truck. I am having some problems configuring a v8 shroud and a 6cyl radiator, more explaination here: http://67-72chevytrucks.com/vboard/s...d.php?t=663011 . I may need to just buy a v8 radiator and call it a day. I don't want anything to look like a hack job.
Radiator measurements, not including the plastic ends: 28"width X 18.5"height
Let me know if you need more measurements.
Absolutely! It's been a long time coming. My plan is to get it running within a month.
MY6 Stepside
Old 03-12-2015, 06:09 PM   #35
84GMC15tepside
Here are some pictures of the truck as it sits currently:
...my garage is relatively large so I put this tarp up to hold heat in when running the wood stove. Worked pretty good!
Took the suspension apart and got Mcgaughy 2.5" drop spindles, and will cut the springs to get the front down around 4.5"... I got a western chassis flip kit for the back, not running a c-notch either.
Some of the parts I got recently:
Going all polyurethane for all of the suspension bushings, front and rear. The chassis had decent enough rubber bushings, but I figured I would just replace them. Rather do it now than in a couple of years.
MY6 Stepside
Old 03-12-2015, 06:19 PM   #36
84GMC15tepside
Garage is a little messy! I usually keep it clean but haven't had the chance recently. Here are some pictures of the engine right now, and how the fan shroud fit over the fan when I mocked it up.
It has a Holley 600, and will be mounting up some Doug Thorley long tube headers soon. Then goes on the steering pump, more of the cooling system, electrical, and that is about it before I can test run it.
...My phone is not taking the best pictures, need to take HDR photos for now on.
MY6 Stepside
Old 03-12-2015, 10:23 PM   #37
Hankster
Hankster's Avatar
Man that thing is clean! I have a 6 cylinder rad hooked to my bbc , it actually does well.
Current Build
Old 03-14-2015, 02:51 PM   #38
84GMC15tepside
Thank you, and I wouldn't expect that wow
MY6 Stepside
Old 03-14-2015, 03:08 PM   #39
84GMC15tepside
I made a shift ball for the A833 in a machining class last fall. Turned down some 2 inch round stock and drilled/tapped the bottom. Drilled a hole in a flat plate and bolted into the shift ball from the bottom side. Then I milled the shift pattern... pretty close and I am happy with it. I need to polish it more too!
Name:  IMG_20141110_075338189_HDR - Copy.jpg
MY6 Stepside
Old 03-14-2015, 11:14 PM   #40
dragonball98312
dragonball98312's Avatar
That's an awesome shifter!
dragonball98312 is offline   Reply With Quote
Old 03-15-2015, 11:06 AM   #41
mattcrp1
mattcrp1's Avatar
Nice shifter.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-15-2015, 01:06 PM   #42
84GMC15tepside
I remeasured the radiator according to the LMC guide. My radiator measurements are actually: 18-3/8" high X 28-1/4" wide X 1-1/4" deep.
MY6 Stepside
Old 03-15-2015, 01:09 PM   #43
84GMC15tepside
Originally Posted by mattcrp1 View Post
Nice shifter.
Thank you.
Here is an interior pic, not much in there lol. Haven't put on the new shift ball yet.
MY6 Stepside
Old 03-15-2015, 02:08 PM   #44
NewType72
NewType72's Avatar
Killer shifter ball I love fresh new CNC parts
- Dylan
(209)-985-7721
Old 03-15-2015, 05:16 PM   #45
Shucks
Shucks's Avatar
Love seeing another student working on a truck, I'm working on a stepside as well as a student in high school, check out my build thread!
Truck is looking solid dude, glad you didn't give up on it.
C H E V R O L E T
Check out my build thread!
Shucks First Build
Shucks is offline   Reply With Quote
Old 03-15-2015, 05:26 PM   #46
Hankster
Hankster's Avatar
Looks like things have been going good, I just skimmed thru real quick, I like that shifter you made!
Current Build
Old 03-26-2015, 09:14 PM   #47
84GMC15tepside
Thanks everyone. Got some updates... I ordered radiator/fan shroud mounting brackets and related hardware, got a summit racing distributor, and a few other small parts. I also got my control arms back from the shop... they pressed in the new polygraphite bushings.
This one of the parts from LMC. Guess this is the new way of spelling "made" lol
I will be repainting the control arms and also need to paint the core support soon. Needs to warm up around here though! Last year I got a instrument cluster with a tach/gas gauage unit and I want to throw an original style clock in the empty space too.
MY6 Stepside
Old 03-26-2015, 09:54 PM   #48
MalibuSSwagon
Nice truck and awesome work! I need to get mine going again needs a new heart..
MalibuSSwagon is offline   Reply With Quote
Old 03-27-2015, 09:59 PM   #49
Hankster
Hankster's Avatar
Originally Posted by 84GMC15tepside View Post
Thanks everyone. Got some updates... got a summit racing distributor,
Attachment 1383045
How much was the distributor, and Lucky, I'd love that tach set up
Current Build
Old 03-29-2015, 07:30 PM   #50
84GMC15tepside
Thank you! I have seen your build before, any plans yet for a motor?
It was $90, couldn't beat the price and I've heard good things about it. Here's the link: http://www.summitracing.com/parts/sum-850001r/overview/
MY6 Stepside
