#26 |
Re: Intake Ducting
That was the one I considered as well. The coupler and filter I bought only totaled $35 so I figured if it didn't work at least I'd only have to buy an elbow and tube
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
#27 |
Collector of Projects
Re: Intake Ducting
here is another option... haven't used them, just had the link saved .... http://www.siliconecouplers.com/
#28 |
Re: Intake Ducting
Update: I got the ebay cold air intake and it won't work for me, but it does give me some parts and pieces to do some mocking up and see what I really need. It MAY work for someone else with a slightly different setup. I have a 49 Chevy truck on an S10 frame with a 5.3. Because of frame interference, I have Kwik Performance brackets and will have a Sanden compressor mounted high on the passenger side. That's one of my clearance issues.
Another clearance issue is that the stock AD inner fenders don't leave much room in the engine compartment for other stuff. They were fine for a carb'ed 216, but for an EFI 5.3 they leave a lot to be desired. Building new inner fenders has been in the plans for a while, and is starting to take shape. I think I will likely be sourcing components from some of the links folks have posted up, so in the interest of public sharing thank you! Here's my pictures: ![]() I really need to go out farther from the TB before I turn: ![]() Original inner fender, very little room: ![]() Here's the beginnings of the new...looking like there will be about 5" more room, plus space in front of and behind the tire for things like air box, ECM, overflow tank, squirter tank, etc. Starting with 36" trailer fenders and will roll sheetmetal to close it up some more. ![]() The goal for the filter location is about here, but on the passenger side: ![]()
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 09-10-2013 at 09:09 PM. |
#29 |
Re: Intake Ducting
Thanks for the update. Just a thought...couldn't you switch that 90* elbow around to get the curve farther away from your TB? It looks to me like there is more material on the end that the pipe is on.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#30 |
Old member
I know it's not a LSx motor yet! But this is how my TPI is setup.
Here is my setup in my 1971 Chevy truck. 1990 Caddy air box modified by me. I first sealed the normal intake opening up which in the first picture has the sheet metal screw showing. I used gasket sealer also and then used a 4" hole saw to drill a nice opening in the bottom of the box. I then took a PVC coupling from lowes and cut the threads off but left enough pipe to attach the 90 elbow then took another coupling and cut the threads off of it. Took the 4" hole saw to the radiator support where the old V regulator was mounted and put the coupling through the hole to the other end of the 4" ninety. True cold air straight in from the grille area. ![]() ![]() U can see the coupling in the support in this one. U can see the 4" hole beside the drivers side head light. All installed with K&N filter
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#31 | |
Re: Intake Ducting
How did you get the filter to fit the hose?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#32 |
Re: Intake Ducting
#33 |
Re: Intake Ducting
Hey billet what's up with that trans dip stick are you compensating? And where do I get one? Hahaha!
Posted via Mobile Device |
#34 |
Re: Intake Ducting
Haha the engine is out of an express van so that's the dipstick it came with. I was going to buy a new one but that one works so why bother? I honestly have to take two steps back though to get it all the way out of the tube haha
#35 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Intake Ducting
get you an Fbody trans dipstick, follows the same line as yours but stops halfway of the VC
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#36 |
Re: Intake Ducting
Now what fun would that be?
#37 |
Re: Intake Ducting
I was using the same as everyone else from ebay, but did not like the placement, so I picked up this from Airraid and made my own custom. It is all abs and you just cut and silicone adapters.
Air Raid U-build-it ![]() ![]() |
#38 |
Re: Intake Ducting
Update on this thread. When my MAF is connected the idle is going pretty crazy so I may need to toss and elbow in there and separate the MAF and TB a bit.
#39 | |
Old member
![]() Quote:
#40 |
Re: Intake Ducting
I believe by the filter. Most of the kits I see have the MAF by the filter not the TB, same goes with the stock setup.
#41 |
Re: Intake Ducting
#42 |
Re: Intake Ducting
Oops, just noticed, I don't have a rubber elbow. The rubber sleeve at the throttle body is from Intakehoses.com.
#43 |
Re: Intake Ducting
Does your MAF still have the honeycomb in it?
#44 |
Re: Intake Ducting
Yeah it does.
#45 |
Re: Intake Ducting
Has anyone used the ebay 5.3 one with a 67-72 body style? I'd like to not have to relocate the battery for an intake...
#46 |
meowMEOWmeowMEOW
Re: Intake Ducting
Fir reference, the maf should be sitting HORIZONTAL with the plug between roughly 10 and 2 withe 8+ inches before the tb
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#47 |
Re: Intake Ducting
How can you tell what's 10 and 2 if its horizontal?
#48 |
![]() Join Date: Sep 2005
Re: Intake Ducting
casn u post the link?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#49 | |
meowMEOWmeowMEOW
Re: Intake Ducting
![]() If you look straight at the MAF, the sensor/wiring should be sitting clocked roughly between 10-2. So Billet, your MAF is facing the correct clock, just in the wrong position. In eagle's and saltyone's pictures, the large horizontal run of tubing between the air box/filter and the TB is a more ideal place.
#50 |
Re: Intake Ducting
Dangit, BR3W, now you tell me. Next time I'll submit pictures when its just tack welded up. LOL. Oh well. Probably 12,000 miles this way and no known problems. My ignorance is my bliss.
