Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-07-2013, 01:23 AM   #26
swamp rat
swamp rat's Avatar
Re: 71 4X4 Frame off Restoration
Now that is brave cutting out the pillar like that, I'd be pretty worried i'd be looking for a new cab before it was all over..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-07-2013, 11:52 AM   #27
DWilbur
It is scary cutting it out. I have been removing small sections at a time as I only have 1 chance to get it right. I will be installing it next week end. I just have to remove some metal at the top of the quad cab started on it last night and should have it ready for next week end.
DWilbur is offline   Reply With Quote
Old 10-07-2013, 06:42 PM   #28
swamp rat
swamp rat's Avatar
Good luck! I hope to start my sheet metal next summer, i don't have a large enough garage so i have to work under a car cover in the side of my garage for that part.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-07-2013, 06:54 PM   #29
DWilbur
I don't have much room either. part of 2 car garage and my driveway. Right now the Suburban and truck take up the driveway and my daily driver is parked in the street. do you have the option to inclose your carport for the build.
Old 10-07-2013, 10:22 PM   #30
swamp rat
swamp rat's Avatar
I wish i had a car port! I have one of the vinyl 10X20 car covers you get at auto parts stores, its on the side of my garage, it does have the side skirts on it. I have contemplated having a permanent car port built but i don't think it would look right with having 2 single car garage doors.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-07-2013, 10:51 PM   #31
In The Ten Ring
Function over form man. I'm thinking about building my own shed (with wood floor) behind my garage to store my gasoline cans, mower, yard tools, etc and that will free up a lot of space in my rather small garage.
A car port can look nice if it's spiffed up a bit. Be creative and show us some pics. :-)
In The Ten Ring is offline   Reply With Quote
Old 10-07-2013, 11:12 PM   #32
swamp rat
swamp rat's Avatar
Yea, the only problem with a car port it it blocks my access to that side of the yard, which is where i park my trailers, and normally my rat. My lot and house are not perfectly parallel. I have been thinking about adding another shed in the back corner for the same reason, clear out that garage! and also run power to it, move my compressor out there and some of my bench power tools ect.. But it all takes money
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-08-2013, 04:38 PM   #33
DWilbur
I built a shed in my back yard it 9'X15' and it did not put much of a dent in freeing up space in my house and garage. my yard is small in the back yard about 28' deep and 45' long with the shed in one corner. next summer I will have to unload some things. to make room.
Old 10-11-2013, 10:11 PM   #34
DWilbur
After dinner I worked on the quad cab and finaly removed the top of the A pillar. Spent 2 hours removing it.
Old 10-11-2013, 10:15 PM   #35
DWilbur
Pick of the peice I removed and the part removed from the truck cab. you can see how it is sanwitched in side the top post. my plan for Saturday is to meadia blast the rust prime and fit the Apillar in the quad cab.
Old 10-11-2013, 10:16 PM   #36
swamp rat
swamp rat's Avatar
Had to slow down a little and think it out huh?? happens to me every time i work on my truck.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-11-2013, 11:48 PM   #37
ole dollor
ole dollor's Avatar
I like what you are doing, going to hang around and see how it turns out.. good luck on your project..
ole dollor is offline   Reply With Quote
Old 10-12-2013, 12:08 AM   #38
DWilbur
Hi ole dollor
Thanks for checking out my build. after getting the A pillar installed I can get started on the modifications with the cab and the frame.
Old 10-12-2013, 11:20 AM   #39
AirSpeed
AirSpeed's Avatar
Very cool. Can't wait to see it done!
AirSpeed is offline   Reply With Quote
Old 10-12-2013, 04:05 PM   #40
DWilbur
Finally I got the new A pillar installed for trial fit. It will take some massaging to get as close to perfection as possible. Now I can see the end of the tunnel. ROT be gone.
Old 10-12-2013, 06:21 PM   #41
swamp rat
swamp rat's Avatar
Awesome! That repair would scare the lights out of me! I have never done any body work yet with the exception of trying to pop a dent, learning here as much as possible before i start on mine.. Keep up the great work!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-12-2013, 07:58 PM   #42
RustySunShine
RustySunShine's Avatar
This is cool stuff!
RustySunShine is offline   Reply With Quote
Old 10-12-2013, 08:15 PM   #43
DWilbur
Boy I'm beat worked all day finaly got the rot out of this rig. I meadia blasted the rust and the area's I will be welding in the A pillar. This has been one hell of a lot of work. Sunday I will final fit the parts and start welding them in place.
Old 10-12-2013, 08:18 PM   #44
swamp rat
swamp rat's Avatar
Keep it up!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-13-2013, 07:34 AM   #45
sboris
sboris's Avatar
Looking good! Will be watching this
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 10-13-2013, 07:37 PM   #46
DWilbur
Finally sucess the Apillar is tack welded in place and looking good. My brother stopped by and helped me install the door, dash ans set up some strap clamps to do some final possisioning of the top part of the A pillar. I tack welded it and removed the clamps. All is fitting good. just have to weld off the rest and fit the parts for the floor. we did notice the inner part of the door is bent I have another door but it is rusted real bad on the bottom.
Old 10-13-2013, 07:43 PM   #47
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
keeping the olives on this build.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 10-13-2013, 09:47 PM   #48
swamp rat
swamp rat's Avatar
Humm, need more lighting in that garage! LOL! Nice progress anyway!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-19-2013, 02:31 AM   #49
Vova
South Bay build. Cool!
Vova is offline   Reply With Quote
Old 10-19-2013, 08:26 AM   #50
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
This guy is close to you and has alot of good original doors.
http://www.vintagechevytrucks.com/index2.html
Tom Vogel is offline   Reply With Quote
