Old 12-08-2013, 01:03 PM   #26
OldCreek
OldCreek's Avatar
Re: LQ9 Build for 1972 Blazer
My LQ9 setup in my K/5 is all stock. It feels good/good enough for me. It's relatively fast and sounds great. With 4" lift springs, 35" tires and the top down I really don't feel the need for more speed. There's plenty of torque steer and a little twist when the setup downshifts and kicks in hard. The MagnaFlows scream when this happens.
It's actually a little unsettling when you're not prepared for it….
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 12-09-2013, 08:44 PM   #27
Justin G
Pulled the trigger on the 6L80e transmission and 6.2L engine accessories today from RetroLS. Shawn gave me a little bit of a price break so I'm satisfied with the deal we made. Got a ton of work to do but at least I'm moving forward. To date here is what I've got:
2009 LY6 Block (144,000 miles)
L92 Heads Cleaned, Valve Job, & Milled .015, PAC 1218 springs installed.
Mast Motorsports VVT HO cam
6l80e
ECM
Wiring Harness - Still need to send off to be modified....Seller recommended Speartech?
Pedal
Power Steering Bracket & Pump
Water Pump
AC Compressor
Alternator
Intake
Injectors
Fuel Rails
Throttle Body
Coil Packs w/Plug Wires
MAF
Next items on the list:
Send off harness for modication.....suggestions welcome?
Getting hydraulic lifters or Stock LS7 lifters....RetroLS recommended this since the heads were off.......what do you guys think.....worth the $150?
Cam Phaser Limiter Kit....Read I need this to ensure no interference between pistons & valves due to installing VVT cam?
Headers
Fuel Tank
Radiator
Dirty Dingo 67-72 4x4 LS Swap Crossmember
And the list will go on......I'll stop here tonight so I don't overwhelm myself!
Justin G is offline   Reply With Quote
6.0l, l92 heads, ly6
