11-11-2013, 11:24 PM | #26 |
Re: What exhaust are you guys running with your swap?
11-13-2013, 02:18 AM | #27 |
Depends on the motor, if the 5.3 then out the turbo and split under the rails. 6.0L Texas Speed 1 3/4" headers to SS pipes to Borla XR-1's to holes in the quarter panels just ahead of the rear wheel well opening.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
11-14-2013, 11:21 AM | #28 |
If you have not bought your manifolds, you may want to look into FAST motorsports used TBSS cast iron manifolds.................... shipping was more than the cost of the parts!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
11-14-2013, 12:36 PM | #29 |
I bought my Trailblazer SS manifolds and heat shields from GM parts direct.com for $154.00 shipped to my door.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
11-16-2013, 12:43 AM | #30 |
I run those manifolds with ece mounts. This might give you an idea how they look mounted. They actually tuck in tight<a href=http://s1055.photobucket.com/albums/s501/Daaaanz67/?action=view¤t=8a519411.jpg target=_blank><img src=http://i1055.photob<a href=http://s1055.photobucket.com/albums/s501/Daaaanz67/?action=view¤t=16a43f91.jpg target=_blank><img src=http://i1055.photobucket.com/albums/s501/Daaaanz67/16a43f91.jpg border=0 alt=></a>ucket.com/albums/s501/Daaaanz67/8a519411.jpg border=0 alt=></a><a href=http://s1055.photobucket.com/albums/s501/Daaaanz67/?action=view¤t=3f3c2a29.jpg target=_blank><img src=http://i1055.photobucket.com/albums/s501/Daaaanz67/3f3c2a29.jpg border=0 alt=></a>
11-16-2013, 12:48 AM | #31 |
Oops here are the photos
11-16-2013, 01:02 AM | #32 |
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
11-16-2013, 09:00 AM | #33 |
Thanks very much for the pics....those Hooker manifolds would not have worked with the CPP mounts....Doug Thorley it is.....$$$
11-17-2013, 01:47 AM | #34 |
I am having the same issue as you flynavy! FML.
Are these the same CPP mounts you have? I was told that there is like two different types of CPP tubular mounts. Those ECE ones look so much more spacious. DAMN CPP!!!!
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's Project "Huckleberry" 68 GMC K1500 1/2 ton L83/6L80e |
11-17-2013, 11:46 AM | #35 |
Yup! Those are the ones. They work really well, but you have no option other than the Doug Thorley headers. On the plus side, they're really nicely made headers....on the minus side, they're $600. I got mine from Summit Racing and they fit really well. The only down side, if you're running a column shifter for the transmission, you need to also swap the shift linkage to the Lokar kit that Summit sells as well....its $57.
11-17-2013, 11:48 AM | #36 |
As an aside, I also ordered the Flowmaster "choose your own adventure" C10 exhaust kit. Its set up to work with long tubes and allows you to choose whether to turn the exhaust out in front of the rear wheels, behind the wheels at a 45, or straight out the back.
11-18-2013, 04:27 PM | #37 |
heres my ls1/4l60e setup
sanderson 1 3/4 headers with ECE/dirtydingo mounts Gibson 2.5 dumped after the axle |
11-18-2013, 09:29 PM | #38 |
2" primary Texas Speed 2010 Camaro headers to a 3" x-pipe with dual electric cutouts and 3" turbo mufflers
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
11-18-2013, 09:57 PM | #39 |
I was going to say that your setup was crazy but then I saw who posted it. Seems about right for you haha
11-20-2013, 12:31 AM | #40 |
here is mine 3rd gen f body ebay headers, 3" summit kit with x pipe and summit turbos
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
11-20-2013, 11:47 AM | #41 |
BBC sells a stainless steel set of shorty headers for the 2010+ Camaro for around $500.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-04-2013, 09:28 PM | #42 |
I started with the TBSS Manifolds. Then had some headers made with x pipe and 10 series dumped.
12-04-2013, 09:55 PM | #43 |
12-05-2013, 03:30 PM | #44 |
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
12-09-2013, 02:33 AM | #45 |
I just picked up a set of '07 trail blazer SS manifolds this weekend for my '76 project. I got in a hurry and tried to stuff the 4.8l in the truck with the stock manifolds on it and I can see why they don't fit, to wide. Now the SS manifolds tuck tight and are more rear dump. I also got about a foot of the down pipe and flanges with my new to manifolds.
12-09-2013, 11:19 AM | #46 |
Boosted Member
Picked up some trailblazer SS manifolds for the 4x4 build I'm doing.
No dice. The solution: Planning to weld some pipe to these to get the outlets away from the frame, and then a couple of 2.5" V-bands to connect to the rest of the exhaust.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
12-09-2013, 03:50 PM | #47 |
What year 4x4?
12-09-2013, 05:24 PM | #48 |
Boosted Member
It's a 72 frame.
12-09-2013, 07:17 PM | #49 |
Hollister Road Co.
5.7 6.0 CADILLAC CTS 2004 2005 2006 2007
6.2 CTS-V 2009 12578029 Manifold 12578030 Manifold 6.0 Trailblazer SS 2006 12600526 MANIFOLD 12600527 MANIFOLD 12597916 SHIELD 12597917 SHIELD Both are tighter to the engine than the stock truck. The CTS dumps higher above the frame rails and about the middle of the last two ports. I am using these on an LC9 in a 1950 truck, its similar in frame width to a 67-72. I tried the Trailblazer ones but they dumped at the frame on the left side and had no room for the studs. |
12-09-2013, 11:34 PM | #50 |
I found this out myself about a month ago, TBSS manifolds won't clear a 4l80.... Looks like headers are in my future.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
