Old 11-23-2013, 12:02 AM   #26
clinebarger
Re: Torque Converter lock up
P0606 is an Internal ECM failure code for the 5-volt reference voltage performance.
5-volt reference generally runs a little under 5 volts, 4.95 as an example.
I would use a Tech 2 & review failure records or data log with EFI live/HPtuners & see what the reference voltage does.
Possible causes..
ECM cant control reference voltage, Produces too high or low voltage.
Short too 12 volt source....Pulling the reference "High".
Short too Ground....Pulling the reference "Low"
Shorted sensor....Pulling the reference "Low"
Programming Error....Tuning/tuner, Mismatched OS, Incomplete "Write" to the ECM....Not getting any other codes leads to believe this is the case.
clinebarger is offline   Reply With Quote
Old 11-23-2013, 01:12 AM   #27
jorgensensc
jorgensensc's Avatar
Thanks guys. My tuner seems to think that when I got the replacement ECM from PSI (who got it from another company) that they either took an incorrect year ECM, and tried to write a 2011 OS to it, or took a 2011 ECM, wrote the wrong OS to it, then rewrote the 2011 OS over it, which would have messed up the ECM also. I bought a new 2011 ECM that was sent to the tune shop to program with the dyno tune he already did for me. Hopefully he will get it sent back to me soon. He was at SEMA last week, so it's a little delayed.
Let's hope that fixes this pesky p0606 code.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-12-2013, 05:56 PM   #28
Billett
Billett's Avatar
Originally Posted by Houston Ben View Post
Here is how I hooked my relay up, is it correct?
Is this the correct way to wire a gen iii then?
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 12-12-2013, 08:45 PM   #29
Hart_Rod
Hart_Rod's Avatar
Yes
Hart_Rod is offline   Reply With Quote
Old 12-13-2013, 05:07 PM   #30
Billett
Billett's Avatar
Can't get this to work on my 68... Wired it up just like shown, grounded out at one of the steering column bolts, ign power from the unfused source in the fusebox, brake lamp power is from white wire, but it keeps blowing the brake light fuse for some reason. Any thoughts?
Will
2024 Toyota Sienna
Old 12-13-2013, 06:58 PM   #31
hotrodwest
hotrodwest's Avatar
I am having the same issue using a relay and blowing the brake light fuse. I'll be interested in hearing what the experts have to say on this.
http://www.hotrodswest.com
hotrodwest is offline   Reply With Quote
Old 12-14-2013, 11:53 AM   #32
Billett
Billett's Avatar
Turns out I was using a relay with a diode in it. Didn't pay attention when I grabbed it out of the drawer. You can tell by the schematic on the side of the relay. The kind you want is on the right side of the first pic and the bottom of the second.
Hopefully this solves your problem!!
Will
2024 Toyota Sienna
Old 12-14-2013, 12:27 PM   #33
hotrodwest
hotrodwest's Avatar
Thanks for the info, I will check my relay.
Old 05-08-2014, 10:48 AM   #34
Hart_Rod
Hart_Rod's Avatar
Bringing this back to the top. Well I thought I had the TCC brake switch lockup wiring figured out on my 2013 Camaro GEN IV 6L80, but no I'm not so sure.
I know the torque converter is locking and unlocking based on paramaters within the tune (MPH) as I have been data logging and and you can see the pressure increase (lock) or go to back 0 (unlock). However, if I hit the brake when I know the TCC is locked (pressure greater than 0), it does not cause the converter to unlock (pressure drop to 0). Am I missing something here? Here'a diagram of how I have the TCC wired up (keep in mind Gen IV's are opposite of Gen III's).
HELP!!!
EDIT: When the brakes are not applied, I measure 8vdc on the TCC wire. When the brakes are applied the voltage goes to 12vdc.
Old 05-08-2014, 02:51 PM   #35
First c10
First c10's Avatar
Rob I am with you on this. I don't have a way to log it but I too feel something is not right.
I will be waiting to see how we can fix it.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-08-2014, 08:32 PM   #36
Houston Ben
Houston Ben's Avatar
Idk either Rob, I'm only running a 4 pin relay, lemme go check the vdc
Houston Ben is offline   Reply With Quote
Old 05-08-2014, 08:42 PM   #37
Houston Ben
I measure .08 to .010 when brakes are not applied and 11.85 when brakes applied. I have no idea what the pressure is, can scan guage ii read this?
Old 05-08-2014, 09:17 PM   #38
Houston Ben
Forgot to have ignition on when test so I did another one.
# Brake No brake
30 11.85 9.61
85. 11.72 .017
86. .049 .036
87. 12.00 11.75
Hope this helps any
Old 05-09-2014, 08:49 AM   #39
Hart_Rod
Hart_Rod's Avatar
# Brake No brake
30 11.85 9.61
85. 11.72 .017
86. .049 .036
87. 12.00 11.75
Hope this helps any
Thanks guys. Still working on an answer....
Old 05-09-2014, 10:07 AM   #40
ls1nova71
ls1nova71's Avatar
Hey Rob, I have no insight on the TCC issue, but here's the schematic you asked about in my build thread a couple of days ago. I kept forgetting to look it up until I was getting ready to leave, so I left myself a note in my toolbox so I would remember it last night. I would just PM you this, but I can't figure out how to add an attachment in a PM. Hope this is what you're looking for.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-09-2014, 10:46 AM   #41
Hart_Rod
Hart_Rod's Avatar
Thanks LS1Nova71. Is that for a Camaro or a Corvette?
Old 05-09-2014, 11:57 AM   #42
ls1nova71
ls1nova71's Avatar
2013 Camaro. Did you need the Vette too? Also, it's a lot better on the copy I have than what it looks like on here. Maybe I should email it or something?
Old 05-09-2014, 12:21 PM   #43
Hart_Rod
Hart_Rod's Avatar
I need them both. Can you email them to robhartley@aol.com? Thanks!
Old 05-16-2014, 12:51 PM   #44
First c10
First c10's Avatar
Rob any luck?
GO GO!!!
Old 05-16-2014, 01:36 PM   #45
Hart_Rod
Hart_Rod's Avatar
Rob any luck?
No one seems to be able to give a yes or no answer on how to determine if it's working or not. So, I just wired mine directly to the wire that goes to my brake lights. Seems like it works the same as before.
Old 05-16-2014, 02:26 PM   #46
hotrodwest
hotrodwest's Avatar
I finally isolated my fuse blowing to an intermittent short in the brake light.
Old 05-16-2014, 02:40 PM   #47
First c10
First c10's Avatar
Rob does your trans downshift smooth or hard? mine I can feel it down shift through all the gears when I slow to a stop. If I put the shifter in the manual position before slowing down to a stop I don't feel it downshift when I came to the stop, but I only tried it once and noticed it by accident.
GO GO!!!
Old 05-16-2014, 02:55 PM   #48
Hart_Rod
Hart_Rod's Avatar
That sounds like the TCC unlock settings in the tune need to be adjusted.
Old 05-16-2014, 03:00 PM   #49
First c10
First c10's Avatar
Isn't that controlled by the brake switch or the blue/white wire?
GO GO!!!
Old 05-16-2014, 03:10 PM   #50
Hart_Rod
Hart_Rod's Avatar
Partially. Most of the lock/unlock on the 6L80's is controlled by tables in the tune. Check this out.
