Old 12-10-2013, 01:59 PM   #26
nekkidhillbilly
Re: LS Swap for dummies???
well doesnt a 208 have a vss output? the truck has to get its speedo drive from some wheres.
nekkidhillbilly is offline   Reply With Quote
Old 12-10-2013, 02:12 PM   #27
nekkidhillbilly
http://coloradok5.com/forums/showthread.php?t=258890
Old 12-10-2013, 02:22 PM   #28
nekkidhillbilly
looks like you can buy what you need to make it work for under 300 from aa or use the stock one off a newer truck for 70 bucks. if your parting a newer truck you should be able to grab the adapter and everything. changing to a 241 you going to still need the adapter. or you would have to swap pre 96 4l60e which is going to be harder to do. you can adapt a th350 for the vss in ls1 so you should be able to add the vss you need for this. will need a electric speedo though.
Old 12-10-2013, 04:57 PM   #29
83GMCK2500
There are adapters that create a VSS signal out of a mechanical speedometer drive.
Jaguars That Run
PATC
Dakota Digital
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-10-2013, 05:28 PM   #30
Jonboy
Slots go on anything!
That Dakota Digital piece looks trick. That should work, but I would try to mate a 4L60E to your 208 case.
I used the JTR 2PRS when I did the TBI swap in my old '74; it worked well.
1974 Jimmy- 5.3/4L80e/NP241
