Old 12-19-2013, 06:34 PM   #26
crazy longhorn
Fabricate till you "puke"
Re: LSx Lessons Learned.
Don't pour oil down the back of the lifter valley, before the flywheel is bolted on....( you will be chasing an oil leak , that isn't there when it "blurps" out 1 of the bolt holes in the crank flange ) Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-19-2013, 06:48 PM   #27
Special-Ed
Special-Ed's Avatar
i think the biggest trend is to make sure the engine/trans/ecm is out of the same vehicle.... most problems i have seen is because trans/motor/ecm were from different years and thats when the problems started.
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 12-19-2013, 10:19 PM   #28
crazy longhorn
Originally Posted by BR3W CITY View Post
Lesson #6
Your are 90% drunker in the garage environment than a bar. 6 beers in a bar is a good buzz, and maybe some over-sharing....
6 beers in the garage, usually results in 2-3 extra hours of work the next day, fixing all those "good ideas" you had the night before.
Donno? I do some of my best work , about 1/2 lit At that point I am not afraid to experiment a tad? I chopped the top on my old truck....as you guessed, about 1/2 lit? 1 of the oldest kids buds came in , & goofed on the old truck...(hey can you chop one for me?)....buy all the booze you want AFTER you are done! The kid just piped right up..."if you want the pro job on that top....get him lit 1st" Maybe I should not talk about breaking the cam in on a bro inlaws Olds....yup, she is running 2500. One of his buds walked in to see the old man & the oldest kid passing a dubie , across the motor. Tried to pass it to him.....but I guess he was not into it Longhorn
Old 12-20-2013, 03:53 AM   #29
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
lol. Hence why I specified beer. I wouldn't have accomplished anything in the last 12 years without herbal encouragement. Everytime I start drinking in the garage, I have to pee before I get anything done, and when I get back...I forgot what I was doing before l left.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-20-2013, 08:53 AM   #30
solidaxel
solidaxel's Avatar
The area right before the tb is subject to fast changes in air velocity from the turbulence and opening and closing of the throttle blade. It can make for some wacky readings.
The maf should be 8-14" away from the tb, mounted between the 10 and 2 oclock positions on the pipe, with no pinching of its electrical leads, no immediate obstructions like a nitrous nozzle or external IAT, and not mounted directly after a sharp bend in the path.
........Duly Noted !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-21-2013, 02:10 PM   #31
Houston Ben
Houston Ben's Avatar
Hey all, Here is a helpful part number list and location to buy that really helped me. I got it from board member Glock.
I hope this helps others as well.
Houston Ben is offline   Reply With Quote
Old 12-21-2013, 11:11 PM   #32
Billett
Billett's Avatar
I posted a similar list on my build thread. I'll see if I can post it here too...
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 01-27-2014, 03:01 PM   #33
AMERICAN PICK-UP
to the top
AMERICAN PICK-UP is offline   Reply With Quote
Old 01-27-2014, 04:22 PM   #34
Hart_Rod
Hart_Rod's Avatar
Build your air intake or pick whatever breather/intake tube you are going to use BEFORE you have your motor tuned.....
Hart_Rod is offline   Reply With Quote
Old 08-14-2014, 04:29 PM   #35
Roz
Sub'd for future reference!
Roz is offline   Reply With Quote
Old 08-14-2014, 11:20 PM   #36
rwade
rwade's Avatar
Subscribed
Wade
rwade is offline   Reply With Quote
Old 08-15-2014, 12:02 AM   #37
Xeen
Xeen's Avatar
Originally Posted by Matt Cramer View Post
The issue wasn't the frame - it was that part of the engine stands that sticks up. I had been using the 3" set-forward mount style, and pulled the engine stands back to the six cylinder spot - that gives pretty limited clearance at the front of the manifolds.
Yep and CPP has since released a new sheet metal style engine stand that addresses all clearance issues and you can use TBSS and Camaro exhaust manifolds and factory location adapter plates with them.
Then you can buy the Holley A/C compressor relocation kit and all your worries magically disappear.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-15-2014, 09:11 PM   #38
siggyfreud
siggyfreud's Avatar
Just as an FYI because the original post mentions it, but you can almost always find coupon codes for ALLDATADIY. Most of the time you can get it 50% off or better for a few month or year subscription for a vehicle.
Just Google ALLDATADIY coupon code and the first few hits usually have good ones.
siggyfreud is offline   Reply With Quote
Old 08-18-2014, 05:29 PM   #39
NEWFISHER
NEWFISHER's Avatar
Bump...Just starting my collection of items and the lists mentioned are great---thanks
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-23-2014, 09:35 AM   #40
lowlyfec10
anyone know the physical positioning differences between the cpp sliders......standard and low ac mount style?
lowlyfec10 is offline   Reply With Quote
Old 11-14-2014, 02:25 PM   #41
H20cooled
Is the engine and tranny year match the same on the 4l60e trannys the same as the 4l80e ones? I already picked up a 4.8l from a 2000 truck but no tranny, so now I'm on the search for a 4l60e. I know that it should be out of a 2000 + and 2wd but didn't know about matching the year, defiantly makes it harder to find the right tranny.
Thanks,
Rich
H20cooled is offline   Reply With Quote
Old 11-14-2014, 09:53 PM   #42
yossarian19
If you don't have V8 mounts to begin with, just slam it as far back as you can. It'll make setting up a cooling fan a lot easier.
If you are going to mod your own wiring, two steps: One, pick your computer location first. Two, giving yourself enough reach from engine to computer, cut / solder / stretch / shorten your wires with the engine & trans out of the truck & on a pallet. It *sucks* trying to make it lay flat & look good while it's in the truck and you can't reach much.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 11-14-2014, 10:28 PM   #43
clinebarger
Thanks,
Rich
Any 4L60E from behind a Gen III engine will work.
'07 & '08 4L60E's from behind Gen IV engines will work with a Internal Harness swap (Using a '03-'06 harness).
In '09 the 3-2 downshift solenoid was eliminated, Will not work with your set-up. 4L60E production stopped soon after this.
clinebarger is offline   Reply With Quote
Old 11-14-2014, 10:54 PM   #44
H20cooled
Thank you for the update it cuts through some of the confusion.
How about using a 4l60e from a v6 vehicle?
Rich
Old 11-15-2014, 02:36 AM   #45
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Input shafts are different, so that and the convertor would need to be changed. At that point its better just to source the correct trans.
Old 11-15-2014, 02:38 AM   #46
H20cooled
Thanks.
