Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-17-2014, 05:12 PM   #26
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Oh , i would love to have this truck with A/C and a 76 mm single .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-18-2014, 06:31 AM   #27
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Hood should be here friday . This truck has just kinda hung around . After the rule change i didnt need the truck , so it has sat . Kinda getting fired up about it . My oldest daughter showed a bit of interest in trying to run a bracket race . Might just put her in this thing and let her go at it .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-18-2014, 10:26 PM   #28
POPO1984
POPO1984's Avatar
Re: 89' s-10 5.3
Nice square body. I'm considering buying a square body s15 with 40000 miles and doing the swap too. Do you know if he used a kit or fanned up the stuff.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 06-19-2014, 07:30 AM   #29
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
I think the mounts and headers are a kit . The wiring is a modified factory harness . I need to figure out the pin arrangment to cycle one of the fans .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-19-2014, 08:08 AM   #30
POPO1984
POPO1984's Avatar
Re: 89' s-10 5.3
Thanks. Good luck with the build.
South Houston
Old 07-08-2014, 11:05 PM   #31
TheBlueBomber
TheBlueBomber's Avatar
Re: 89' s-10 5.3
Looks like he did a good job with the swap. Clean truck suuuuubscribed!!
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 07-09-2014, 01:47 AM   #32
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Well , the truck intake is tall enought you have to use a cowl hood . Truck has been completely stripped and is in the body shop . He told me today it looks like next monday or so . Also price a custom turbo kit from trick performance at $4500 plus tune and fuel upgrades . Probably just put the 224 cam and a nice conveter in it .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-11-2014, 05:25 AM   #33
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Im thinking the Yank truck thruster would be ok for a converter like 25-2600 . I also am having the 4L60E built . I bought a pair of 165 radials and a pair of 275/60's and had them monted on a set of weld draglites that match the ones i have a set of 28 x 10.5 s on . The guy that bought my Black 88'back half truck called me the other day and he pulled all the interior out of his truck and gave it to me . ill get a few pics up soon .
Also they just posted the div 4 bracket final rules and my other truck(yellow luv) is not legal on 3 counts . Tranbrake , 2 step and electric shift . This is the only race of the season like this for me and the original reason i bought the truck . Good thing it stuck around . I will be footbraking this truck in no-e slow or et sportsman at the bracket finals as i now have no choice but to finish this truck in a hurry and test every friday night i can .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-13-2014, 11:31 AM   #34
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Here are the new tires .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-13-2014, 02:09 PM   #35
TheBlueBomber
Re: 89' s-10 5.3
Sweet!
Austin
Old 07-27-2014, 05:16 AM   #36
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Truck is still in the body shop . Bed is ready and cab almost done . Ended up with a 3200 lock up converter and adding a Corvette servo with fresh fluid . Ill try and get some pics up soon .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-04-2014, 11:32 PM   #37
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Went to look at it today and it is in full primer . Body looks good . He had it ready to be wet sanded . Said i could pick it up thursday . I also ordered all new door and window gaskets . Truck looks good .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-06-2014, 12:29 AM   #38
TheBlueBomber
Re: 89' s-10 5.3
Can't wait. Did you grab any pictures while you were there?
Austin
Old 08-06-2014, 12:46 AM   #39
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
i will tommorow . So ready to have this back . Almost 3 weeks past original finish date . I went by 2 days ago and the bed was off . Truck always leaked fuel when the tank was full . One of the three fingers on the in tank pump wasnt hooked on the pump install . got that fixed while the bed was off .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-07-2014, 06:45 PM   #40
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Here is where it is at paint wise :
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-07-2014, 08:04 PM   #41
71Dragtruck
71Dragtruck's Avatar
Re: 89' s-10 5.3
May have missed it, but what colour will it be?
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 08-07-2014, 10:42 PM   #42
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
It will be white with a silver metallic two tone broken with a black border and dark charcoal grey gears airbrushed on the silver side and on the hood .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-12-2014, 10:52 PM   #43
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Well this is exactly what i ask him for the black break up strip has not been added yet , and might not get added . We will try it in tap and if it works we will add it . It is definately different . Let me know what you think good or bad . I wanted different and took him the stencil and colors . Here is the pics :
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-13-2014, 01:00 AM   #44
POPO1984
POPO1984's Avatar
Re: 89' s-10 5.3
Nice.I like it
South Houston
Old 08-14-2014, 04:30 PM   #45
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Thanks , it is different that is for sure . The Luv is solid Yellow , My 49' i spent way to much on and is a classic 2 tone , My daily has a cowl hood with a smaller strip on the side of the hood , my powerstroke is plain jane , i wanted to think outside the box on this one . Kinda wanted a modern version of these . Any guesses on what this cost me with a new windsheild installed ?
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-14-2014, 10:55 PM   #46
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Her are the currents . Should be ready saturday around noon . Probably the last pics until i get it back together .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-18-2014, 10:43 PM   #47
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-18-2014, 11:23 PM   #48
71Dragtruck
Re: 89' s-10 5.3
Looking good, just finishing touches left?
Sponsored by:
Hard Candy Customs
Old 08-19-2014, 06:57 AM   #49
POPO1984
POPO1984's Avatar
Re: 89' s-10 5.3
Nice. Now get it to the strip.
South Houston
Old 08-19-2014, 09:26 AM   #50
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 89' s-10 5.3
Just finishing touches left . Trans rebuild and a 3200 lockup converter and a 224R cam and a tune . About to finish up reassembly and put a vette servo in it today.
Im going to footbrake it saturday this weekend in points meet . If it does good i'll run it sunday . If not ill go back to the yellow truck . I went out first round both days last weekend in the Yellow truck . Need a change for some reason .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
