01-04-2014, 04:20 PM | #26 |
Re: Project remove my sunroof
Thanks Scott, figured it was time to get it done.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi 1997 C2500 Ext Cab 5.7 Liter 1955 3/4 ton 1st series w/ 235 straight six Sold it |
01-04-2014, 04:29 PM | #27 |
You could always weld the seem solid across the back..... IMHO it looks better that way.
01-04-2014, 04:33 PM | #28 | |
02-03-2014, 10:38 PM | #29 |
Quick update: Stripped and sanded the paint off the donor top and fitted it in place. Will epoxy paint the inside once it warms up.
02-03-2014, 10:56 PM | #30 |
Very Nice...
02-03-2014, 11:22 PM | #31 |
Rusty Nuts
Very nice, you make it look easy.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
02-04-2014, 08:47 PM | #32 |
Thanks guys
02-04-2014, 08:56 PM | #33 |
mad skills!
Figure out what you want--then figure out what you are willing to give up to get it. |
02-04-2014, 09:07 PM | #34 |
nice job on the roof!!!
05-13-2014, 01:53 PM | #35 |
Ok, so I finally got some time to finish the roof. I stripped and primed the inside of the roof, then installed the original insulation inside before buttoning it up. I ended up welding the front lip of the roof and using 3M panel adhesive on the back edge. I clamped it all together and let it sit over night. The results turned out great.
05-13-2014, 02:28 PM | #36 |
Congrats! Looks way better without the sunroof hole.
05-13-2014, 03:59 PM | #37 |
Great work!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-13-2014, 10:38 PM | #38 |
Thanks, I only have to smooth out a small dimple in the rear of the panel. Which I should have done by this weekend.
05-13-2014, 11:29 PM | #39 |
Awesome job !!! I also don't like sunroofs in theses trucks ! Great workmanship !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
05-14-2014, 04:54 AM | #40 |
That's some good work! Congrats, so when's the new sunroof going in?
05-14-2014, 09:39 AM | #41 |
Rusty Nuts
That was a nice job well done!
