02-01-2014, 09:03 AM | #26 | |
Re: MORE lsx wiring questions
02-01-2014, 11:29 AM | #27 |
That would be correct.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-02-2014, 10:56 AM | #28 |
02-03-2014, 09:10 AM | #29 |
EPIC FAIL.....tried to start the LS on sunday (yes the pressure was on with all my buddys standing around watching football and heckling me)..At first i had the starter wired through the Current Performance fuse/relay as per their instructions...turn the key..NOTHING...then i rewired the starter the standard way and the starter turned over but was very weak as if i had a dead battery...(battery was at full charge) Any thoughts?
Also, isnt the fuel pump suppose to kick on then the key is turned? During several attempts to turn the key only once did i hear the pump turn on and it ran continuously until it switched the key to the off position. The system is new do i need the purge the lines somehow? Any thoughts? |
02-03-2014, 09:15 AM | #30 |
And another couple questions....
I dont have the TCC wired up yet per lt1swap.com but im not tring to drive it yet just start it, does that matter? And when wired correctly should the pedal (DBW) move the throttle body butterfly (for lack of a better term) when pressed while the key is on? Because mine does not.. |
02-03-2014, 10:18 AM | #31 | |
Fuel pump should come on when the key is turned on and run for two seconds unless the engine starts, then it should run constantly. You shouldn't need to purge the lines, the injectors will open and let any air out. TCC doesn't need to be wired up for the engine to start. Usually the butterfly will work with just the ignition on, but I've seen some where it only works when the engine is running.
02-03-2014, 10:25 AM | #32 | |
02-03-2014, 12:14 PM | #33 |
You need a ground from the engine to the frame, and you could do it that way, but you'd be better off to hook your negative battery cable directly to the block (preferably as close to the starter as possible) and then run another ground strap to the frame.
02-03-2014, 02:17 PM | #34 | |
meowMEOWmeowMEOW
If you don't hear that, then your DBW isn't wired properly. If you DO hear that, but then lose throttle control at the first input, then you probably have a component mismtach.
02-03-2014, 09:26 PM | #35 |
Made sure the block was grounded to frame. I do get continuity throuout the whole truck whentesting ground..My battery is in the rear of the truck, Should i run a ground from battery to block?
02-03-2014, 09:29 PM | #36 | |
02-03-2014, 10:33 PM | #37 |
The further away you mount the battery the more important it becomes to have good battery cables, both positive and negative. Sure you'll generally get continuity through out the whole vehicle, but it has to be able to handle the amp load the starter draws. You could have a very small wire that's giving you continuity, I once had an engine ground it's self through the metal oil pressure line, definitely not good. You can run your ground to the frame from the battery, but a steel frame isn't as good of a conductor as a heavy gauge copper battery cable. But if you don't have at least a big ground cable from the frame to the engine block, it's not going to start as well as it should, and the hotter the starter gets the harder it will get to start.
02-04-2014, 10:39 AM | #38 | |
02-04-2014, 02:22 PM | #39 |
meowMEOWmeowMEOW
Strangely, my optima is rear mounted, and I don't run an extra cable from battery to block.
I have heavy gauge cable grounding to the frame, then my big 3 grounded up front.
02-04-2014, 09:36 PM | #40 |
So i put a 4 gauge ground strap from the frame to the block and it still didnt change the fact that doesnt want to turn over..trys a little like the battery is almost dead but i know the battery is solid..Could it have anything to do with the engine harness? My thoughts are NO..it should still crank hard just might not start.
02-04-2014, 10:10 PM | #41 |
I might be an idiot...please chime in if so..So my battery is located in the rear of my truck...What gauge wire should i run from the battery to the starter? Rather not say what i ran..might be a tad inadequate
02-04-2014, 10:20 PM | #42 |
The longer the cable length the bigger the diameter should be. With a battery mounted in the rear of the truck I wouldn't go any smaller than 0 gauge. Have you heard this engine run before? Maybe pull the plugs and see if it cranks over fast?
02-05-2014, 10:43 AM | #43 |
I have never heard the engine run. I did however pull the heads to inspect things and all seemed well, had good compression with no leak down after valves were lapped. Put on new head gaskets, head bolts, new plugs, new wires...etc..
02-05-2014, 01:52 PM | #44 |
Who did yours?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-05-2014, 02:07 PM | #45 | |
meowMEOWmeowMEOW
02-05-2014, 02:38 PM | #46 |
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-06-2014, 09:34 AM | #47 |
Then that is how ill do it.
02-08-2014, 05:08 PM | #48 |
OK....so i run a 2 gauge from the battery to the front of my truck. BINGO! One problem solved. The truck now turns over like it should but does not start. Next problem to take on...must be some wire issues. The fuel pump doesnt kick on for that first 2 seconds or any time after for that matter.
02-08-2014, 09:29 PM | #49 |
if the fuel pump is not priming the fuel system as it should, check your fuel pump relay to ensure its wired correctly. Also, check the fuel pump signal wire with your test light. I hope your pcm had the vats removed.
02-08-2014, 09:45 PM | #50 | |
I still haven't looked into changing the way the current performance harness is wired like you have suggested..So far I just hooked up the wires as suggested in there instructions...I think I need to call you...am about to just throw my hands up and have bill at BP make me an idiot proof harness |
