01-31-2014, 12:23 PM | #26 |
Re: Parting out 72 C20 350 AT a few nice parts
01-31-2014, 12:33 PM | #27 |
Tom - 350 block and heads condition? Any idea how many times bored? If decent, pls post the numbers for it - the stamp pad, and Eng suffix code. Thank you!
01-31-2014, 01:41 PM | #28 |
Junior Member
Put me in line for door panels if bertvert passes.
01-31-2014, 06:10 PM | #29 |
Hi. Are you selling the windsheld mounted rear view mirror? I would like it if you are.
02-01-2014, 01:53 AM | #30 |
"Junkyard Dog"
CUSTOM/10 Gary, I'll get a shipping cost and this door relay is bad too.
sflem61, THANKS! Tigg, The column looked very nice but it didn't seem to shift correctly. I have another in my next truck to part which is a 72 as well. It is also black. 100.00 shipped. jocko, The block is standard and never been apart till now. It is 4 bolt main and has nodular main caps. I have hot tanked it and ready for the machine shop. The heads are not original to the 72 as they have a 73 date code. They are 1.72-1.6 valves. The heads look to be just fine. I have many more blocks and heads if this is not what your looking for. pics below muckmuck, Ok terry b Terry, I sold the cab and forgot to save it.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 02-01-2014 at 02:12 AM. |
02-01-2014, 02:10 AM | #31 |
"Junkyard Dog"
block pics
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
02-01-2014, 02:51 AM | #32 |
How's the battery tray?
02-01-2014, 03:32 AM | #33 |
Tom..how much for left hand (drivers side) Window Regulator? Im interested if it rolls up/down smooth. I also need the left hand window handle that rolls it up/down.. broke mine..again. (think its time to change the regulator and stop breaking handles!)
Cost for both shipped to 98439 |
02-01-2014, 08:43 AM | #34 |
Interested in the pair of rotor stone shields. How much to ship to 48060
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
02-01-2014, 08:45 AM | #35 |
Just noticed this is from a C20 are the rotor shields the same for a C10?
02-01-2014, 11:22 AM | #36 |
If the tail light housings haven't been spoken for I'd like a quote shipped to 37043. Could you check the bulb sockets/screw holes to see if they're good too? Thanks. Chuck.
pm me as I may forget to check back. thx
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
02-01-2014, 03:58 PM | #37 |
Do you have a hood latch part that bolts on the hood itself?
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
02-02-2014, 02:58 AM | #38 |
"Junkyard Dog"
Juarez823, Looks good so far. I put put in the dip tank to remove the rust in the tray. I'll post pics hopefully Monday.
72CampSpecial, 43.00 shipped. Good rollers and works just fine. Kennuck, The C20 is different from the C10. I have the C10 shields as well same cost. thelonerife Chuck, 17.50 for the pair 10.00 shipping jeh, Yea lots of them. 10.00 plus 6.00 shipping.
02-02-2014, 03:45 AM | #39 |
I am up in Yakima, WA. I am looking for a radiator to fit my 71 k20. Also, interested in your steel wheels. What size are they? (will they fit over front disc brakes)
02-02-2014, 04:17 AM | #40 |
could I get some more pics of the rear patch panels? May take both.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-02-2014, 04:22 AM | #41 | |
"Junkyard Dog"
4 core original Harrison 100.00 plus shipping 3 core large tank original Harrison 80.00 plus 3 core small tank original Harrison 80.00 plus The wheels off this truck have been scraped. Are you looking for 16" stock wheels? Thanks, Tom
02-02-2014, 04:23 AM | #42 |
"Junkyard Dog"
Sure but it would be monday before I can get pics.
02-02-2014, 10:14 AM | #43 |
Cost to ship C10 disc brake stone shields to 48060 please.
02-02-2014, 12:33 PM | #44 |
I have a four core cross flow now, but its leaking and may be cheaper to replace vs repair.
I am looking for a steel wheel that I can powder white and put stainless beauty rings on. I like the idea of 16-17", but it needs to be 8 lug and pretty wide to fit 33x12.5 tires. I am also interested in the linkage to operate the passenger side fresh air vent and knobs for both, and whatever bench seat cables/springs connect from the driver side seat slide adj handle over to the passenger side. |
02-02-2014, 01:16 PM | #45 |
"Junkyard Dog"
Kennuck, My bad I should have posted that last night. Half asleep I guess. 30.00 on the shields and 13.00 shipping.
ChevyChaser, I send all my radiators out to a rad shop to have them tested and given a clean bill of health. Just LMK I don't have any steelies right now for the 33x12.50 tires. Yes on the vent pull and both knobs. 7.00 with both knobs. They are pictured in post 7 of this thread. I do have the cable/rod but only with seat tracks. Thanks, Tom
02-02-2014, 04:27 PM | #46 |
I found mine thanks for the quote.
02-02-2014, 04:44 PM | #47 |
"Junkyard Dog"
CUSTOM/10, Shipping on the shields is 13.60
02-02-2014, 07:46 PM | #48 | |
02-02-2014, 08:16 PM | #49 |
I'm interested in the steering intermedate shaft, will it fit my 72 4x4 blazer ?
02-02-2014, 08:46 PM | #50 |
"Junkyard Dog"
Kennuck, PM coming
warbucket, Yes, It is the same. Thanks, Tom
